Snobrdrkid's WJ Build Thread - Page 381 - JeepForum.com
post #5701 of 6785 Old 12-27-2012, 09:44 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by ChrisHager View Post
I can understand that. I probably need an entire weekend (or at least a full Saturday) for tinkering on mine and I'm not not seeing that happening for a while...
Yeah dude. Just extremely fortunate that it can be handed off like that.
Crazy. Never seen that happen before. Must've been moisture/mud/something in there for a long while.
Maybe some mud blocked the drain hole and water was able to sit up in there. But yeah, it needs replaced haha.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5702 of 6785 Old 12-27-2012, 02:03 PM Thread Starter
snobrdrkid07
WJ for Life
Well I finally got a chance to clean the dang thing! It has been forever!
-Michael-
post #5703 of 6785 Old 12-27-2012, 03:55 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Buy a camera! Your Droid phone is not doing your beautiful Jeep any justice!
~Richard
billzcat1 is offline
post #5704 of 6785 Old 12-27-2012, 04:00 PM Thread Starter
snobrdrkid07
WJ for Life
Ahhh i know, we have got a two at home. I just never have it on me! And they are not mine.
-Michael-
post #5705 of 6785 Old 12-30-2012, 10:58 AM Thread Starter
snobrdrkid07
WJ for Life
Tried to install the heated/auto dim mirror. Turns out I need some sort of harness that's long enough to connect the mirror to the door panel.
-Michael-
post #5706 of 6785 Old 12-30-2012, 11:01 AM
compcrasher86
And I just got rid of my spare door panels a coupke weeks ago
Matt
compcrasher86 is offline
post #5707 of 6785 Old 12-30-2012, 11:14 AM Thread Starter
snobrdrkid07
WJ for Life
http://www.wjjeeps.com/mirror_autodim_wiring.jpg.
One of those.
-Michael-
post #5708 of 6785 Old 12-30-2012, 04:06 PM Thread Starter
snobrdrkid07
WJ for Life
So the Jeep went on huge troll mode again leaving Dad's house. Rolled the window down and then it would not go back up. Open the and closed the door and then it went back up. That ground wire in the driver door boot. *tisk tisk* Secondly the trunk would not shut, twice, then on the 3rd time it went. Need to grease the latch again I guess. Weird. Dad was just standing there having a little laugh as I am screwing around with the Jeep.
I drove the Rubicon around today and the WJ is much smoother aside from what is mostly likely the rear tires in need of balance on the WJ. (I do not know what else it could be!?) I did notice that the Rubicon does a little steering shimmy on bumps at "highway" speeds although it did feel "firmer" and not "losey gooesey" (Ya that sounds childish but that was the first thing to come to mind.) I guess new control arm bushings and a heim in the track bar have less room for play.
Lastly the WJ is finally getting that work done later this week. I am going to draft up what all is going to be done in more detail on a word document and will prbably post a link to a google doc later.
-Michael-
post #5709 of 6785 Old 01-01-2013, 12:47 PM Thread Starter
snobrdrkid07
WJ for Life
I found this video on youtube and was pretty interesting. I've just been wondering what causes the tires to shimmy a few times back and forth on a pothole or something like that. That is all my Jeep will do, just shimmy back and forth for a second then go away on those decent holes that jostle the suspension. But no full out DW. I don't get why it does it.
What the video shoes in the first minute or so shows, what I am guessing the WJ does when I hit a pot hole (I usually try to avoid) similar to the size in the video.
Note: Thursday the 3rd, Jeep is going in for new front upper control arms and bushings, then also installing the IRO lowers to put caster around 6.5* (Along with a ton other stuff, however the stuff upfront was worth mentioning again)
-Michael-
post #5710 of 6785 Old 01-01-2013, 01:54 PM
compcrasher86
Your SS is most likely what's keeping it from going into full out DW. In that video he added new shocks and dual SS.. he probably didnt get rid of the source of his DW he just masked it :/
Matt
post #5711 of 6785 Old 01-01-2013, 01:55 PM Thread Starter
snobrdrkid07
WJ for Life
Right, I get that. Maybe I did not phrase it right, I was wondering why it wobbles over bumps and stuff?! haha
-Michael-
post #5712 of 6785 Old 01-01-2013, 02:24 PM
wj4play
Caster angle .. I really hope you are installing adjustable lowers otherwise you won't be able to adjust your caster at all.... Fixed uppers and fixed lowers will suck if you need to tweak your caster at all. Even if they say caster will be about 6.5* you will be disappointed
IRO write up recommends 4.5* with their long arms. I am at 4.5" lift on my front with short arms and set my caster at 4* before DW stopped.
Picture a bent shopping cart wheel that wobbles back and forth.
Take my advice as you want but I hope the best to you.
Hope u work out your DW.
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #5713 of 6785 Old 01-01-2013, 02:44 PM Thread Starter
snobrdrkid07
WJ for Life
Hey thank you for the reply. The front uppers will be stock and the lowers will be ADJUSTABLE from IRO. I was planning on setting caster to around 6.5* which is stock spec for caster. I do not know exactly why IRO suggests 4.5* other then to avoid drive line issues with the front pinion angle.
-Michael-
post #5714 of 6785 Old 01-01-2013, 05:02 PM
wj4play
Sorry if you posted before that adjustable CA but i miss a lot of detail due to being on my iPhone.
I adjusted mine to 6.5 for factory spec but it was horrible. I read IRO manual for long arms and re adjusted to 4.5 and eventually settled on 4
More caster will bring the steering wheel back to center faster than less castor, I have heard most dodges solid axle front eventually suffer DW and same with factory WJs with no lift but worn out steering components.
Just letting you know what worked for me but seem that everyone has different results on different jeeps. I wouldn't worry about pinion angle as much as I would for caster.
DL vibes can be cured with a double Cardon if you end up with that happening
wj4play is offline
post #5715 of 6785 Old 01-01-2013, 05:09 PM Thread Starter
snobrdrkid07
WJ for Life
I'm curious to why you would have issues with that much caster. What did it do when you had 6 or so degrees of caster?
I mean I don't understand how or why more caster would negatively affect it.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
