Snobrdrkid's WJ Build Thread - Page 379 - JeepForum.com
post #5671 of 6786 Old 12-23-2012, 06:58 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by CowboysYJLT1 View Post
How are your HIDs working for you and are you just running stock 100w bulbs for your highs?
They've been great, running the projectors and HID's are a great combo. The high beams are halogen bulbs so there is no warm up time with flashing your high beams.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5672 of 6786 Old 12-23-2012, 07:13 PM
JerzeyBoyWJ
2003 WJ
Didn't think you could run premium fuel unless you ran a tuner ...well I mean I guess you can run it but the safe way is with a tuner
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #5673 of 6786 Old 12-23-2012, 07:24 PM
EMS WJ 2000
EMS WJ 2000's Avatar
I have the stock housings and I was wondering if there would be a problem running the 55w HIDs for both low and high beam with the stock housings?
Danny
2000 WJ Laredo (Daily Driver)
4.0 I-6 4x4 186,000+ miles and still going strong.
2007 Tahoe (Wife's truck)
Fully loaded
Only two defining forces have ever offered to die for you:
...Jesus Christ and the American Service Members....One died for your soul; the others for your freedom.
EMS WJ 2000 is offline
post #5674 of 6786 Old 12-23-2012, 07:25 PM Thread Starter
snobrdrkid07
WJ for Life
I've never heard that before. We've ran premium in all our ATV's, Motorcycles, Jet Skis, Boats, lawn equipment, generators, and other toys. Then Dad and I have always ran premium in the Jeeps on occasion. All the other cars we have require premium, the Jeeps are the only 2 that don't "require" it. I know for all the "toys" he will only put premium in them for whatever reason. Again I've never heard it as "bad" to run premium without a tune.
-Michael-
post #5675 of 6786 Old 12-23-2012, 07:27 PM Thread Starter
snobrdrkid07
WJ for Life
That's a very bad idea, running HID's in stock halogen housings is not the way to go. I don't want to get into it all. There are dozens of threads on Jeepforum explaining why. The glare of HID's in halogen housings is terrible. Basically don't do it.
-Michael-
post #5676 of 6786 Old 12-23-2012, 07:30 PM
EMS WJ 2000
Darn.
Dont really want to dump a few hundreds of dollars into new housings, the ones I have are aftermarkets (not from Jeep). With the projectors could you run HIDs in the low and high beams?
Danny
Fully loaded
post #5677 of 6786 Old 12-23-2012, 07:39 PM Thread Starter
snobrdrkid07
WJ for Life
Darn.
Usually, only in the Low Beams. The highs are usually just halogen reflectors. The HIDs take some time to warm up and aren't good for high beams when you need to flash someone. Id only recommend halogens in the high beams.
-Michael-
post #5678 of 6786 Old 12-23-2012, 07:40 PM
EMS WJ 2000
Cool thanks.
Can you PM me where and how much your projectors were?
Danny
Fully loaded
post #5679 of 6786 Old 12-23-2012, 07:45 PM Thread Starter
snobrdrkid07
WJ for Life
Cool thanks.
Sent.
-Michael-
post #5680 of 6786 Old 12-25-2012, 08:30 AM Thread Starter
snobrdrkid07
WJ for Life
Merry Christmas Everyone! Hope its all going really well for everyone and enjoying the time off.
-Michael-
post #5681 of 6786 Old 12-25-2012, 02:00 PM Thread Starter
snobrdrkid07
WJ for Life
Opinion time!
1. What bushings in the front take the most beating? The uppers or the lowers?
2. Should I get new stock rear lower control arms to help keep the rear stable?
3. Stock upper control arms and bushing replacement an okay way to go? Compared to like IRO type arms?
-Michael-
post #5682 of 6786 Old 12-25-2012, 03:59 PM
compcrasher86
Opinion time!
1. Uppers on the WJs seem to take the most beating. Granted my lowers are much more beat up but I think that has to do with the New England road salts.
2. If you can budget it, sure. They're VERY easy to replace so its purely budget. Focus on the front first though sounds like you want a tight front end more than anything.
3. Yes. Especially if you're going to have a freshly rebuilt driveshaft you're probably unlikely to encounter driveline vibes from less than perfect front pinion angle under 3" lift.
Matt
compcrasher86 is offline
post #5683 of 6786 Old 12-26-2012, 12:34 PM Thread Starter
snobrdrkid07
WJ for Life
Well the good new continues. I am FINALLY getting major work done to the WJ! Here is everything that is getting done.
Front Related:
  1. Front Lower IRO CA's - Caster set to 6.5*
  2. Front Upper Control arms - Mopar
  3. Front Axle Upper Bushings - Mopar
  4. Ball Joints
Rear Related:
  1. A-Arm - Mopar
  2. Ball Joint - Mopar
  3. Rear Lower CA's - Mopar
Fluids:
  1. Brake Fluid Replace and Bleed
  2. Power Steering Flush and new Fluid, the Mopar Spec
  3. Drain and Replace Coolant with Zerex G05 or whatever it is
Misc Parts:
  1. Front Drive Shaft Rebuild
  2. Front Output Yoke is getting checked
  3. Tranmission Crossmember Replaced
  4. Emergency Brake Fix
  5. Electric Fan Replaced
  6. New U-Joints for Rear D.S.
  7. Rear Brake Rotors and Pads - if needed
I think that is most of it. Parts are being ordered this week and its getting dropped off on the 3rd!
-Michael-
post #5684 of 6786 Old 12-26-2012, 12:50 PM
JerzeyBoyWJ
2003 WJ
What's wrong with your crossmember ?
post #5685 of 6786 Old 12-26-2012, 12:51 PM
ChrisHager
Administrator
ChrisHager's Avatar
That's a pretty good list! I bet you'll notice some improvements when it's done.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
