Snobrdrkid's WJ Build Thread - Page 362 - JeepForum.com
post #5416 of 6786 Old 11-06-2012, 09:21 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Pulled out the driveshaft. While I had a Jeep friend ride with me and tell me, they weren't "bad" but something was "up". So, with that being said I'm just going to leave the shaft out until I can re build it or have it rebuilt.
Yoke is seeping a little bit of fluid. Didn't put the new seal in yet.
There was something I noticed, I was pushing up and down on the shaft and noticed a bit of movement. Turns out that ever so slight movement was coming from the yoke on the output shaft... errrrr is that a problem???
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5417 of 6786 Old 11-06-2012, 02:21 PM
squashman702
1994 ZJ
Sounds like a bad U joint, which would definitely cause your vibrations.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #5418 of 6786 Old 11-06-2012, 02:37 PM Thread Starter
snobrdrkid07
WJ for Life
See my original thought was a U joint too, which I intend to replace them all anyways.
But, the yoke was able to move every so slightly up and in down. Just barely. Not sure how to describe it. Kinda like the output shaft was just slightly too small for the hole it goes through??
-Michael-
post #5419 of 6786 Old 11-06-2012, 02:38 PM
squashman702
1994 ZJ
Yoke on the axle? Pinion bearing may be on it's way out.
Think Twice Garage
post #5420 of 6786 Old 11-06-2012, 02:43 PM Thread Starter
snobrdrkid07
WJ for Life
Yoke on t=case. Sorry.
-Michael-
post #5421 of 6786 Old 11-06-2012, 02:50 PM
squashman702
1994 ZJ
Same deal still- bearing may be on it's way out.
Think Twice Garage
post #5422 of 6786 Old 11-06-2012, 02:52 PM Thread Starter
snobrdrkid07
WJ for Life
Well damn. Ant correlation to me swapping the yokes and the bearing deciding to go "bad"
Also if this is loose could that cause vibes? And when I mean loose, I'm talking like a half of a millimeter of movement.
-Michael-
post #5423 of 6786 Old 11-06-2012, 03:14 PM
compcrasher86
Make sure the shaft is actually moving as well and its not just the yoke moving on the shaft/not tight enough.
Matt
compcrasher86 is offline
post #5424 of 6786 Old 11-06-2012, 03:17 PM Thread Starter
snobrdrkid07
WJ for Life
This is still possible. Yet its cranked down to 110 foot pounds at the moment. Gonna have another Jeep Club friend check it out sometime this week and go from there.
-Michael-
post #5425 of 6786 Old 11-10-2012, 12:45 PM Thread Starter
snobrdrkid07
WJ for Life
Hmmm what is this. Haha
-Michael-
post #5426 of 6786 Old 11-10-2012, 12:51 PM
Thomahawk
Idk, but look sweet, drool....?
Buildthread
Thomahawk is offline
post #5427 of 6786 Old 11-10-2012, 12:52 PM Thread Starter
snobrdrkid07
WJ for Life
Rubicon is getting some new poly bushings apparently.
-Michael-
post #5428 of 6786 Old 11-10-2012, 06:14 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Attachment 504896
A bad idea? Poly bushings have no place in those control arms.
~Richard
billzcat1 is offline
post #5429 of 6786 Old 11-10-2012, 06:51 PM Thread Starter
snobrdrkid07
WJ for Life
And this is why I wish dad would have told me that he was going to do that. I believe they are from energy suspension. I would have told him just to order IRO adjustable control arms, again if I knew prior too.
How bad of an idea is it to have those there... *sigh*
-Michael-
post #5430 of 6786 Old 11-10-2012, 08:58 PM
billzcat1
2003 WJ
Not too bad if it's a mall crawler. I would not want them for trail use. Those bushings need some level of compliance for axle articulation. This will put all the stress normally absorbed by a flexible bushing into the mounts. I have read of body-side mounts cracking. It's why JKS made their arms specifically with a center pivot and firm bushings - to give positive control with good bushings but allow the pivot needed to preserve the mounts.
~Richard
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
