Snobrdrkid's WJ Build Thread - Page 361 - JeepForum.com
post #5401 of 6786 Old 11-02-2012, 10:03 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
You have to watch out for those parts monkeys. I asked for Power Steering Return hose (in stock at $1.29/ft per AZ webpage). They give me fuel injection hose at $4.09/ft. Parts Monkey says "yes it's compatible, and higher pressure rating". I go home and google it. Fuel Injection Hose? BAD IDEA. Transmission cooler/Power steering return hose is a different compound and is rated for 4 times the pressure.
~Richard
billzcat1 is offline
post #5402 of 6786 Old 11-02-2012, 10:12 AM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Well it does in fact say cooler on it. I don't know what it says before that because its tucked away. So that's a "start" in the right direction, right? Maybe?
I'm not sure why the one would be leaking and the rear are fine.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5403 of 6786 Old 11-02-2012, 10:17 AM
Thomahawk
2006 XK Commander
Originally Posted by snobrdrkid07
Yeah, no kidding. I'm not sure what they freaking sold me. "Cooler" is a start. Maybe I'll go back and ask for transmission line and see what they give me. What's different between like transmission cooler and like other "cooler" type line?
When its labeled cooling, my first thought is Coolant fluid, might be good enough, i dont know, i just know there Are Oil/fuel specific Lines, also due to temp and pressure, check it out, make sure you have the right one.
Buildthread
Thomahawk is offline
post #5404 of 6786 Old 11-02-2012, 11:46 AM
leadsled jeep
I just KNEW I liked Jeepers! I am a 1911 guy as well. Stock Springfield Loaded stainless here. I did just order some XS tritium sights for it however.
Just starting IDPA matches here.... Once a month. Good stuff!!
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #5405 of 6786 Old 11-02-2012, 01:31 PM Thread Starter
snobrdrkid07
Hmmm. Will have to check it out more. Could replace that whole hose with the "transmission cooler" hose that came with the cooler itself? (I still have that spare hose and the factory hose just in case for these situations)
-Michael-
post #5406 of 6786 Old 11-02-2012, 01:41 PM
Thomahawk
2006 XK Commander
If you have the line that came with the cooler and its the right size and length needed, i would just swap that in with a good clamp and not think of that any more.
Buildthread
post #5407 of 6786 Old 11-02-2012, 02:16 PM
compcrasher86
It could be that the clamp chewed through the hose I've seen that before. Cut an inch off the hose like tomahawk said and slip it on and re-clamp. Make sure inside of clamp is smooth and doesn't have any sharp edges.
Matt
compcrasher86 is offline
post #5408 of 6786 Old 11-02-2012, 02:19 PM
Thomahawk
2006 XK Commander
Exactly what i pictured in my mind, ha ha
Buildthread
post #5409 of 6786 Old 11-02-2012, 02:59 PM Thread Starter
snobrdrkid07
I'll cut off a section and recap and try that first before I replace everything. Would try that first.
-Michael-
post #5410 of 6786 Old 11-03-2012, 08:58 PM Thread Starter
snobrdrkid07
Hope to put in the drive shaft tomorrow. We shall see. Also get that seeping auxiliary line taken care of.
Realizing today how bad I need that a-arm fixed. Had 5 people on board on the highway, the Jeep was line bouncing and steering felt oddly loose. Errhh. Maybe because of the weight it was making it feel like that.
-Michael-
post #5411 of 6786 Old 11-04-2012, 03:28 PM Thread Starter
snobrdrkid07
New front yoke went on without issue. Drive shaft fit just fine... BUT, too bad it vibrates?! 35+ it has a noticeable vibration. Not to the point where the Jeep is shaking apart but enough to not be acceptable. Will be seeing who is local around here to get it rebalanced/rebuilt.
-Michael-
post #5412 of 6786 Old 11-04-2012, 07:03 PM
compcrasher86
Ugh that's obnoxious dude maybe a weight got knocked off or something? Check the u-joints thoroughly on the DC and axle end?
Matt
post #5413 of 6786 Old 11-04-2012, 07:06 PM Thread Starter
snobrdrkid07
All the weights look to be there. I am thinking the 3 u-joints need replaced. The double cardon end was a bit sloppy.
Would bad u-joints or center "Ball" thing cause vibes?
-Michael-
post #5414 of 6786 Old 11-05-2012, 01:46 AM
Thomahawk
2006 XK Commander
I would believe thats possible, hope you got it sorted out soon.
Buildthread
post #5415 of 6786 Old 11-05-2012, 09:12 AM Thread Starter
snobrdrkid07
Yeah. Me too. If there is play in the joints.
Anyone recommend anything on how to rebuild?
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
