Snobrdrkid's WJ Build Thread - Page 346 - JeepForum.com
post #5176 of 6785 Old 09-07-2012, 03:43 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by Thomahawk View Post
Go Mopar specific PS fluid....
I'd like too, however that would require the entire system to be flushed to get the ATF out.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5177 of 6785 Old 09-08-2012, 12:58 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Originally Posted by compcrasher86 View Post
I know on the V8 WJs with the hydro system that you need the special fluid but I haven't heard of any problems running ATF in the i6 WJs. I read somewhere that in 04 Chrysler started using ATF in their PS systems so I wouldnt be surprised if that what Michael has had in there all along.
Here's the deal - the I6 and the V8 both use the same power steering pump with a different reservoir attached. They both use the same steering box. And for 1999-2000, there was no hydraulic cooling fan on the books whatsoever. Power steering fluid was specced MS-5931 for the entire range of WJ production before the hydro fan was even conceived. And yes, for the WK, the MS-10838 spec is ATF. But it was never claimed to be backward compatible. There would be a TSB for that if it were true.
Stick with what is right. What is guaranteed to work. And don't trust dealers. They *should* know what is right, but shoot, my dealer-maintained Overland came with ATF in the TC, 80W90/no FM in the diffs, and an oil pan drain plug tightened to 150 ft-lbs just to keep it from leaking (rather than replace a $3 plug).
~Richard
billzcat1 is offline
post #5178 of 6785 Old 09-08-2012, 10:15 PM Thread Starter
snobrdrkid07
WJ for Life
Alright, well after looking at all my records, the ATF4 has been in there from the factory. So I'm not sure what to do here. I'll probably just suck some out and replace with more ATF4 and see if that helps. If not, I'll just have the dealer drain, flush, and refill with Mopar spec p.s. fluid.
-Michael-
post #5179 of 6785 Old 09-09-2012, 01:43 PM
billzcat1
2003 WJ
No way that's original fluid at 108k if it's that color.
~Richard
post #5180 of 6785 Old 09-09-2012, 04:02 PM Thread Starter
snobrdrkid07
WJ for Life
Have been thinking about that more and more there just no way the dealer didn't do it. I'll look through it again.
Edit: @78k miles records show that the power steering and among other fluids were "inspected"
-Michael-
post #5181 of 6785 Old 09-09-2012, 04:03 PM
billzcat1
2003 WJ
Dealers make mistakes all the time. As I said before... my WJ came with ATF in the transfer case and no FM in the diffs.
~Richard
post #5182 of 6785 Old 09-09-2012, 04:06 PM Thread Starter
snobrdrkid07
WJ for Life
Note above edit.
Well since I can't do the Turkey baster method cause can't mix fluid. So how do you drain all fluid, flush with new fluid, drain it again, and then fill with new fluid? Haha
-Michael-
post #5183 of 6785 Old 09-09-2012, 06:26 PM
Larryftmfw
Originally Posted by snobrdrkid07
Note above edit.
I'd say pull the return line and put a shop vac to it
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #5184 of 6785 Old 09-10-2012, 10:36 AM
compcrasher86
So I've been talking with Michael and it seems as if we have near identical steering/lift combos aside from his JKS trackbar. As such I figured I'd hop on a rough highway and mounted up my camera to take a video to show you guys what we both are experiencing by steering shakes/wobbles. I sent this video to Michael and this is apparently just like what he's getting. It really only does this when you hit a pothole or a deep drainage ditch on the side of the road, and only above 45mph.
Matt
compcrasher86 is offline
post #5185 of 6785 Old 09-10-2012, 11:35 AM Thread Starter
snobrdrkid07
WJ for Life
Thank you Matt for posting this here as well. Yes, this is the amount of wobble that I am getting when I hit a pothole, indented manhole cover, or something really rough where just one side is deflecting. And that what was shown above is the extent of it. That's what Matt and I are trying to get rid of. Maybe when you see it, you will think, "ohhh that's what you're experiencing, that's something to not worry about." Or, "ohh, that shouldn't be happening" Not sure, but now since there is a video you all can see what we have been trying to describe haha.
Same suspension stuff:
OME HD's
Bilstein 5100's
Moog HD TRE's
Moog HD Adjusting Sleeves
I have the JKS TB and thats pretty much it on the differences.
Matt and I were throwing around some ideas:
- The Moog Adjusting sleeves are too thick and causing that. Too much "punch" to the steering
- Need more caster.
-Michael-
post #5186 of 6785 Old 09-10-2012, 02:02 PM Thread Starter
snobrdrkid07
WJ for Life
On another note, found this out today:
Originally Posted by qualmanj View Post
I've had the same problem with my JKS bushings. I've used the IRO bushings for a year and a half and it's just now starting to get a bit of play in the frame side. And they are only $5 for one end instead of the $60 or whatever the KOR one is.
Originally Posted by snobrdrkid07 View Post
Are you saying that you used the IRO TB Bushings in your JKS track bar?
Yes, I contacted IRO about it and they said they were the same size. Got them and put them in and they fit perfectly.
I now extremely regret buying KOR bushings....
Well, if those KOR bushings ever go bad... I know where I am getting my next set! (So mad right now)
-Michael-
post #5187 of 6785 Old 09-10-2012, 07:36 PM
billzcat1
2003 WJ
So the IRO bushings DO fit the JKS track bar. Interesting...
~Richard
post #5188 of 6785 Old 09-10-2012, 07:37 PM
billzcat1
2003 WJ
"Oh no! My steering is too communicative!"
Yes, when you hit bumps, you will feel it in the steering wheel. The firmer you make everything, the more you'll feel.
~Richard
post #5189 of 6785 Old 09-10-2012, 08:19 PM
compcrasher86
Lol... Well now that Richard has seen that and has not freaked out telling me to get my Jeep off the road because its going to kill me.... I feel alot better . It doesnt really bother me all too much but if theres something wrong I'd rather take care of it sooner rather than let it wreak havoc on the rest of the system. That aside I am now saving for adjustable front arms now that the A-arm is all paid for. Michael I advise you take the same route.
Matt
post #5190 of 6785 Old 09-10-2012, 09:14 PM
billzcat1
2003 WJ
I still think both your caster specs are way too far out for 2.5-3". I'd suspect something like the UCAs or upper axle-side bushings being shot.
~Richard
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
