Snobrdrkid's WJ Build Thread - Page 338 - JeepForum.com
post #5056 of 6785 Old 08-14-2012, 09:44 AM
compcrasher86
Dint know IRO bushings are like stock, I did hear they don't use crown or Omix ada due to quality control issues, that's just the word of the grapevine though idk. I'm curious who rough country uses. Also, anybody know the price on the RC arm? I've gotten a couple IRO products that are nothing but quality and I've heard of some not so great stories about WJ specific RC items (erhem shock relocation brackets)
Matt
compcrasher86 is offline
post #5057 of 6785 Old 08-14-2012, 09:53 AM
JerzeyBoyWJ
2003 WJ
those shock relocation brackets are the worst ...like idk how they even thought they were gonna work ....your cant relocate where the shock mounts in only one spot ..then its gonna cause a serious angle where you didnt relocate ..then you say buh bye to your bushings in like 3 weeks
happened to me ..so i know from experience ..sadly ive had the whole RC experience ...i should make a youtube documentary
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #5058 of 6785 Old 08-14-2012, 04:13 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Waiting on a price for the rough country a-arm.
Not if its a similar price, IRO will still be a winner no doubt.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5059 of 6785 Old 08-14-2012, 06:48 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
The difference in the mount is so that the RC arm can be longer without requiring the axle to move back. Remember it is supposed to come with their LA kit.
Lengthening the upper A-arm without lengthening the lower arms will increase antisquat a lot if your rear a-arm is angled upward (axle to body) more than your lower arms. It'll decrease anti squat if you are angled less than your lower arms. So the height adjustment/varied mounting positions may be key here. Is there even enough room above the axle at this lift height to accommodate the taller mount for either of the AM A-arms?
~Richard
billzcat1 is offline
post #5060 of 6785 Old 08-14-2012, 06:54 PM Thread Starter
snobrdrkid07
WJ for Life
I do know that the IRO a-arm can work with 2-7" inches of lift. I actually don't know about the rough country arm, like the minimum lift. I did talk on the phone to an IRO rep asking what happens when I load the jeep and my lift height dips just below two inches and he said it'd be okay. Now the other thing is that I need to adjust any after market arm to the length of my current a-arm to keep the pinion angle in check.
The rough country axle mount looked like it mounted closer towards the front of the vehicle from my perspective.
-Michael-
post #5061 of 6785 Old 08-14-2012, 07:02 PM
billzcat1
2003 WJ
Yeah, no. Check this out.
It would move the mount to the rear of the axle centerline.
And you'd only match A-arm to OEM arm length if you were certain the pivot were in the same spot. If you install any of the adjustable A-arms, you'll have to set the pinion angle with it installed.
~Richard
post #5062 of 6785 Old 08-14-2012, 07:05 PM Thread Starter
snobrdrkid07
WJ for Life
You know what. I was looking at it backwards. My bad. But what was that picture supposed to show? The a-arm spacer?
The two bolts go in the rear and the 1 bolt goes in the front. Oops!
Edit: you're right, makes sense, different mounting point, can't be the same length.
-Michael-
post #5063 of 6785 Old 08-14-2012, 07:07 PM
billzcat1
2003 WJ
No just show the layout of the triangular bolt pattern.
~Richard
post #5064 of 6785 Old 08-14-2012, 07:13 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah, got that now haha. Little slow tonight, haha.
What do you think? RC or IRO?
-Michael-
post #5065 of 6785 Old 08-14-2012, 08:02 PM
billzcat1
2003 WJ
I dunno. Send your money to China or USA?
~Richard
post #5066 of 6785 Old 08-14-2012, 08:05 PM Thread Starter
snobrdrkid07
WJ for Life
America any time and any day. IRO quality and reputation says enough.
-Michael-
post #5067 of 6785 Old 08-15-2012, 02:36 PM Thread Starter
snobrdrkid07
WJ for Life
Can I get a pic request of the Moog TRE on the pitman arm? For some reason I think mine is not tight enough. I will grab a picture of mine later on.
-Michael-
post #5068 of 6785 Old 08-15-2012, 02:42 PM
billzcat1
2003 WJ
Just retorque it to spec and you'll know for sure.
~Richard
post #5069 of 6785 Old 08-15-2012, 02:46 PM Thread Starter
snobrdrkid07
WJ for Life
That's a better idea, lol. What is the torque spec? I could not find it on the WJ info thread sticky.
-Michael-
post #5070 of 6785 Old 08-15-2012, 02:50 PM
ChrisHager
Administrator
ChrisHager's Avatar
WJ Torque Specs
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
