Snobrdrkid's WJ Build Thread - Page 336 - JeepForum.com
post #5026 of 6786 Old 08-07-2012, 02:13 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Not a problem man. I really trust Eric the car guy. He has great videos and great info.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5027 of 6786 Old 08-10-2012, 12:33 PM Thread Starter
snobrdrkid07
Finally. Going down to the shop on Monday.
-Michael-
post #5028 of 6786 Old 08-10-2012, 02:17 PM
Dusk53
Youre taking your jeep to the shop to get your track bar bushings swapped out? Did i miss something?
Mah build
East Carolina University
Dusk53 is offline
post #5029 of 6786 Old 08-10-2012, 02:19 PM Thread Starter
snobrdrkid07
Going down to the shop because they are also going to road force balance the tires. Then also double check the track bar bolt holes.
-Michael-
post #5030 of 6786 Old 08-10-2012, 02:23 PM
Dusk53
Ahh i see... I need to get my tires balanced too. I hope those holes aren't ovaled out bud.
Mah build
Dusk53 is offline
post #5031 of 6786 Old 08-10-2012, 02:35 PM
ChrisHager
Administrator
ChrisHager's Avatar
If they are, your friends helping you out at the shop should be able to weld on a couple washers pretty easily. Shouldn't be too big of a hassle.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5032 of 6786 Old 08-10-2012, 02:46 PM Thread Starter
snobrdrkid07
Yeah they should be able to do that without any issue. My Jeep is trolling me, I've got to get the new bushings in. Too much axle movement currently. Its causing some oscilation on bumps. I swear, greasing the bushings made them go to sh**. Oh well, thankfully those new bushings are in. Like those JKS bushings are bad. I mentioned before that the bar is over a year old, maybe they had a bad run way back when.
-Michael-
post #5033 of 6786 Old 08-10-2012, 11:33 PM Thread Starter
snobrdrkid07
Hey guys, I did a walk around of my Jeep for fun today. Please take a few minutes to watch and tell me what you think in the comments on YouTube! It is currently the featured video, here is a link to my channel, don't forget to subscribe please!
http://www.youtube.com/user/Snobrdrkid07/featured
-Michael-
post #5034 of 6786 Old 08-12-2012, 01:52 PM
Larryftmfw
You did a good job on the video! Jeep is looking good
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #5035 of 6786 Old 08-12-2012, 03:42 PM Thread Starter
snobrdrkid07
Thanks man! It was a quick and fun little video!
-Michael-
post #5036 of 6786 Old 08-12-2012, 03:51 PM
Larryftmfw
Yea, those shocks look good! But I'd ditch the boots if I were you, they tend to hold water and dirt in them and will ruin You'r shocks quickly
post #5037 of 6786 Old 08-12-2012, 08:40 PM Thread Starter
snobrdrkid07
Removing the boots voids the warranty. Also, there are drain holes in these boots if something gets in there. The seal at the top is spot on too
-Michael-
post #5038 of 6786 Old 08-12-2012, 10:01 PM
Larryftmfw
That's crazy
post #5039 of 6786 Old 08-12-2012, 10:03 PM Thread Starter
snobrdrkid07
Only way water cab get in there is if its submerged for a long period of time. The boot seals on the top and bottom are very tight.
-Michael-
post #5040 of 6786 Old 08-12-2012, 10:12 PM
Larryftmfw
I guess if you don't ever plan on flexing your ok
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
