Snobrdrkid's WJ Build Thread - Page 333 - JeepForum.com
post #4981 of 6785 Old 07-31-2012, 09:28 AM
Thomahawk
Niiiiiceeeeeee!
Buildthread
Thomahawk is offline
post #4982 of 6785 Old 07-31-2012, 11:33 AM
AgitatedPancake
Cool, sounds like he did a quick look at things for you. If you still have any slop at all after the track bar bushing replacement I'd inspect the control arms a little more thoroughly than just looking. The upper control arm bushing that I showed you a picture of is tucked up in the body and not something you can get a very good look at for inspecting. I'm suspect of them in any high mileage WJ, even if not death wobbling.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #4983 of 6785 Old 07-31-2012, 11:40 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I agree, if it is still swaying around after the track bar is tightened up. We will have to pull control arms and look more closely at them. At least I now know the ball joints don't have any play in them. And the the control arms don't have any noticeable movement during the "front end shakedown" that's what he called it lol.
Like I said previously, I am going to take it back and we are going to the track bar install and we will closely look at the track bar hole etc. There was no point to take it off today to turn around and do the same thing a few days later and install the new bushings. (Hope the bushings will be here Friday or Saturday)
At least for now I have some more peace of mind that its not going to fall apart on me.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4984 of 6785 Old 07-31-2012, 11:43 AM Thread Starter
snobrdrkid07
WJ for Life
Ouch rust. :
Found that hiding behind a piece of trim plastic. Driver side rear tire fender.
Scraped the bubbled paint and scraped the rust off to clean sheet metal and painted over w/ touch up paint. Going to clear coat it later.
ForumRunner_20120731_134307.jpg   ForumRunner_20120731_134314.jpg   ForumRunner_20120731_134332.jpg
-Michael-
post #4985 of 6785 Old 07-31-2012, 12:32 PM
wj4play
Originally Posted by snobrdrkid07 View Post
Ouch rust. :
will come back it you at least did not blast it or use some rust eating primer Just FYI
EDIT: fixed it
wj4play is offline
post #4986 of 6785 Old 07-31-2012, 12:35 PM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by wj4play
will come back it you at least did not blast it or use some rusting primer Just FYI
Umm. Not sure what you mean. Can't read the text haha
-Michael-
post #4987 of 6785 Old 07-31-2012, 12:42 PM
squashman702
1994 ZJ
It's not clean enough- should have sanded down some of the area. That will last for a bit but the rust will bubble back through.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #4988 of 6785 Old 07-31-2012, 12:49 PM Thread Starter
snobrdrkid07
WJ for Life
Well if it will hold for a bit that's fine. If someone would like to share the correct way to do it, that'd be great. Sounds like I need to rough it up more? I had scraped it down to bare silver sheet metal and then went over it with the touch up. Needs primed first?
-Michael-
post #4989 of 6785 Old 07-31-2012, 01:26 PM
wj4play
http://www.rustoleum.com/CBGProduct.asp?pid=40
wj4play is offline
post #4990 of 6785 Old 07-31-2012, 01:32 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks man. Ill pick up a can of that and redo it
-Michael-
post #4991 of 6785 Old 07-31-2012, 01:35 PM
compcrasher86
Ouch! That's how it all starts. Mud and water and gunk gets held back there and it just starts eating away. Sucks. Funny because mine is spotless up until the rockers and then it's like Hooooooly moly. Still gotta decide what to do about that. I may just cut them out the overland sliders pretty much take their place.
Matt
compcrasher86 is offline
post #4992 of 6785 Old 07-31-2012, 01:39 PM Thread Starter
snobrdrkid07
WJ for Life
I knowww I hate it. Really makes me upset. Thankfully that is the ONLY spot on the entire painted surface that I have an issue with. If it comes back ill have a shop take a look at it. But what are you gonna do about it, other then fix it, its just going to happen. The entire under body frame doesn't have a spec of rust on it. The only other issue with rust was where the coil perch was. That is virtually it. I've taken care of all other spots with "rust-killer" primer and black paint.
-Michael-
post #4993 of 6785 Old 07-31-2012, 01:40 PM
compcrasher86
Rust is a killer it really sucks man. Mine never had a single problem till I moved up north the salt they have in upstate NY chews metal apart vs in my hometown salt is banned so we only get sanded which is awesome
Matt
post #4994 of 6785 Old 07-31-2012, 01:43 PM Thread Starter
snobrdrkid07
WJ for Life
Ugh... terrible. Salt is a killed. I wish the whole uni-body was dunked in like multiple layers of primer to get into every last crack.
-Michael-
post #4995 of 6785 Old 07-31-2012, 01:46 PM Thread Starter
snobrdrkid07
WJ for Life
Other then some specs here and there. Then the muffler. Its pretty clean underneath.
ForumRunner_20120731_154526.jpg   ForumRunner_20120731_154612.jpg   ForumRunner_20120731_154632.jpg
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
