Snobrdrkid's WJ Build Thread - Page 330 - JeepForum.com
post #4936 of 6785 Old 07-27-2012, 09:11 AM
wj4play
trackbars with bolts other than stock will always have a little "play" unless you go with a JJ - urethane and rubber wear out and squeaks... A JJ may transmit road noise which would be an annoyance with some folks as well. IMHO
Personally I am looking to do this with a TRE on my HP JK30....
pic stole from MR Baine on Pirate
Originally Posted by snobrdrkid07 View Post
When I put it in, I had forgot to grease the bushing, yet didn't have that much play. When I took it out and greased it, the bushings were still very tight and had to press the sleeve out. Then I greased it then put it back. Now I'm getting that much play... idk.
Also I was told JKS sent out a bunch of trackbars with weak bushings - I was also told if you call them they will send you replacements for free depending how old they are. My JKS did this as well but I never replaced them, just figured I was going to replace it with some KOR hard bushings to prevent them from wearing out. ALSO try drilling a pilot hole for a grease zerk so you can periodically grease them to prevent wear.
wj4play is offline
post #4937 of 6785 Old 07-27-2012, 12:47 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Right, they will have "some" play. Compcrasher posted his WJ with the stock track bar with a little bit of play. Then compared to my JKS the play was "excessive". I dont want to go JJ's because that is probably too much. I may have to go with KOR bushings because they are stiff and should give only slightly, because they are harder. On tuesday I am going to make sure the bolt hole is okay. And if the hole is okay, that means is basically all bad bushings. Then I will go for the KOR hard bushings, that should give me the stock track bar stiffness.
I just drove about 70 miles to my dad's house, about 60 miles on the highway at about 65 mph average speed. Jeep road pretty solid and was able to stay in control while going over bumps. Which is impressive with how much play I currently have. BUTTTT, I was swaying all over the road, was so hard to keep the Jeep straight, I KNOW that has to be because of the Track Bar. Am I right? I have GOT to get my play down to stock amount if not less.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #4938 of 6785 Old 07-28-2012, 09:36 AM Thread Starter
snobrdrkid07
WJ for Life
What do I need to do to fix this? New u-joint, new seals? Or do I just put it back together and call it a day?
-Michael-
post #4939 of 6785 Old 07-28-2012, 12:34 PM
Larryftmfw
New moog u joint for sure! Don't forget that boot too
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4940 of 6785 Old 07-28-2012, 12:50 PM Thread Starter
snobrdrkid07
WJ for Life
All the money I'm putting into that front drive shaft. 10 bucks. That's it.
-Michael-
post #4941 of 6785 Old 07-28-2012, 12:58 PM
Larryftmfw
Should of got the moog! What about that cv boot?
post #4942 of 6785 Old 07-28-2012, 01:07 PM Thread Starter
snobrdrkid07
WJ for Life
Moog joint was 50 bucks. Sorry, didn't wanna blow that on a p.o.s. d.s. anyways. As for the boot. Ill smear some grease on the boot and hope that will keep it from becoming any more stressed. When the c.v. goes. Ill switch over to a double cardon. Can't afford to do it now and my current one will still work for now.
-Michael-
post #4943 of 6785 Old 07-28-2012, 01:16 PM
Larryftmfw
50?? I paid 18 for mine where did u go
post #4944 of 6785 Old 07-28-2012, 01:21 PM Thread Starter
snobrdrkid07
WJ for Life
Must have looked at the wrong thing. Idk. But that's all they had there. 10 bucks for a lifetime warranty on it. Good enough.
-Michael-
post #4945 of 6785 Old 07-28-2012, 01:38 PM
Larryftmfw
It'll have to be lol
post #4946 of 6785 Old 07-30-2012, 01:45 PM Thread Starter
snobrdrkid07
WJ for Life
KOR super hard track bar bushings are on their way along with a tube of mineral oil for the bushing lube.
Kinda excited to get those in, and tighten up the track bar. In conjunction with the new tight tie rods, should only have to move the steering wheel a slight amount to translate down to the tires.
Going down to the off road shop tomorrow to check out, bolt holes and ball joints and control arms.
-Michael-
post #4947 of 6785 Old 07-30-2012, 01:53 PM
Larryftmfw
Did you order the set with the sleeves?
post #4948 of 6785 Old 07-30-2012, 01:55 PM Thread Starter
snobrdrkid07
WJ for Life
No, there was no need to.
-Michael-
post #4949 of 6785 Old 07-30-2012, 02:03 PM
AgitatedPancake
Sorry it took me a while to get back to your thread! You definately have some excess movement at that frame side track bar bushings, I have no experience with Kevins but harder bushings should help out for sure. The pop in the floorboard/gas pedal....if I had to throw a shot in the dark I would say control arm bushings. The sway you describe sounds a LOT like how my jeep used to drive on short arms, the upper control arms had never been removed from the jeep let alone had a bushing replaced. Needless to say, the frame side bushings were SHOT when I pulled the short arms out to install claytons so long ago.
You might need to unbolt the control arms to see the frame side bushings, but if they are anything like mine were 6 years ago, it's worth it! If you have any slop in the balljoints also, that will cause wandering as well so good thing you're getting it all checked out. Unit bearing is the term for your front wheel bearing assemblies. They wear out like wheel bearings on any vehicle, and have to be replaced if they start to have slop, causing wandering similar to shot balljoints.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #4950 of 6785 Old 07-30-2012, 02:04 PM
Larryftmfw
That's what you think! You'll need em
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
