Snobrdrkid's WJ Build Thread - Page 329 - JeepForum.com
post #4921 of 6785 Old 07-26-2012, 12:33 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I took videos again of the Track bar movement. But in these videos it did not make the sound that I am hearing and feeling. Don't know if I had mentioned that before, but I can also feel that pop in the pedal/floor...
For your Checklist:
1. What am I looking for in the control arm bushings? How do I check?
2. Here are videos of the JKS Track Bar that has about 500 miles on it. I do not seen any movement in the bolts. Just a lot of movement in the bushings. Again, the popping sounds that I hear while driving around, did not occur in either of these videos. Weird.
Watch in HD. Video of the Frame Side JKS Bar #2
Again, watch in HD. Video of JKS Bar Axle side #2
3. I have 4 brand new Moog HD Tie rods with new heavy adjusting sleeves. So I'd doubt those are an issues.
4. Ball joints - I have not looked at them yet. Could those make a pop sound that id feel in the floor?
5. Unit bearings? Is that something to do with axle shafts?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4922 of 6785 Old 07-26-2012, 12:44 PM
Larryftmfw
For your #4 yes they would
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4923 of 6785 Old 07-26-2012, 01:28 PM Thread Starter
snobrdrkid07
WJ for Life
I am taking the Jeep into the off road shop with my friends on Tuesday. We are going to look at ball joints, track bar bushings, track bar holes, control arms, all of that. Hopefully that will get me on the right to track.
-Michael-
post #4924 of 6785 Old 07-26-2012, 03:27 PM
alwaysHI
2003 WJ
Your frame side has a lot of movement
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #4925 of 6785 Old 07-26-2012, 03:45 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah it does. I'm not sure if that's all bushings or the sleeve is moving around too
-Michael-
post #4926 of 6785 Old 07-26-2012, 04:07 PM
alwaysHI
2003 WJ
Take your bolt out on the unibody end, drop the track bar down, put just the bolt in the mount and see if you can wiggle it in there. If it has play, it's wallowed. Mine had quite a bit of play, give it a shot, and if need be weld a washer.
Build Thread -
SOLD
alwaysHI is offline
post #4927 of 6785 Old 07-26-2012, 04:30 PM Thread Starter
snobrdrkid07
WJ for Life
You got it man. That's exactly what I'm going to look for. I'm just not going to touch it until I take it down to the shop on Tuesday and then we are going to ***** everything.
- Track Bar
- Track Bar bushings
- Track Bar mounting holes
- Ball Joints.
- Control Arms.
- Broken u-joint on front drive shaft.
-Michael-
post #4928 of 6785 Old 07-26-2012, 04:32 PM
compcrasher86
Bronson man I did what you were saying with mine and there was a decent bit of play but nothing was wallowed... like the inside of the holes still had white paint on em from the factory spray so i dunno if that all works
I'm pretty much with Greg on this one figure out your trackbar (way too loose looking from the video on the frame side) and also get your ball joints professionally checked out and see whats up. Yes bad balljoints will transmit clunks through the floor (mine do) and it sometimes sounds like its coming from the back. Unit bearings are the wheel bearing hub assemblies on the front axle one on each side and axle shaft passes through them. Not hard to replace... requires less removal than ball joints.
Matt
compcrasher86 is offline
post #4929 of 6785 Old 07-26-2012, 04:49 PM
compcrasher86
I would say you have a bit too much movement on the frame side. This is my Jeep. Excuse the meowing... my power steering isnt too quiet.
Matt
post #4930 of 6785 Old 07-26-2012, 04:56 PM Thread Starter
snobrdrkid07
WJ for Life
Video Link: http://www.youtube.com/watch?v=RCE3G8r2FO0&list=UUpI5_Oyci4_qSPr73OrE9yA& index=1&feature=plcp
Just watched your video. That is the amount of play that'd I'd like to see with the JKS bar. Don't think its going to happen with the stock JKS bushings either. My bolt hole doesn't really show a sign of wallowing. But then I'm not 100 percent sure. Will find out next week.
My nut on the bolt doesn't move...
Greg is a boss, he knows what's up. I'm going to run down that list for sure.
-Michael-
post #4931 of 6785 Old 07-27-2012, 07:06 AM
squashman702
1994 ZJ
Way too much movement on the frame side IMO.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #4932 of 6785 Old 07-27-2012, 07:16 AM
Larryftmfw
What could cause that tho? Maybe something's binding and causing it?
post #4933 of 6785 Old 07-27-2012, 07:23 AM Thread Starter
snobrdrkid07
WJ for Life
Not sure what's causing it to have that much play. Or if anything is binding. The steering has felt stiffer recently, don't know if that's related.
-Michael-
post #4934 of 6785 Old 07-27-2012, 08:15 AM
squashman702
1994 ZJ
Bolt may not have been tight enough when the bar was installed originally, which would cause premature wear on the bushings. Could also be that the ID of the sleeve was too big for the bolt, again causing premature wear.
Think Twice Garage
post #4935 of 6785 Old 07-27-2012, 08:31 AM Thread Starter
snobrdrkid07
WJ for Life
When I put it in, I had forgot to grease the bushing, yet didn't have that much play. When I took it out and greased it, the bushings were still very tight and had to press the sleeve out. Then I greased it then put it back. Now I'm getting that much play... idk.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
