Snobrdrkid's WJ Build Thread - Page 328 - JeepForum.com
post #4906 of 6786 Old 07-26-2012, 08:24 AM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
The way its is on the WJ is: bolt head, frame, tb, frame, nut. The nut isnt shifting around so I would not think that it is wallowed out. I took a impact gun to it yesterday and its around 100 ft-lbs now.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4907 of 6786 Old 07-26-2012, 08:40 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by snobrdrkid07 View Post
I still may get the KOR bushings, what do you think?
The KOR Bushings may help. It's hard to say really. If you've ruled everything else out, they're worth a try!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4908 of 6786 Old 07-26-2012, 08:49 AM Thread Starter
snobrdrkid07
Yeah the might. I just drove it again at 34 psi cold and its much better then it was. It doesn't want to try and dw automatically at 50 MPH. Im wondering if my tires wore funny...
-Michael-
post #4909 of 6786 Old 07-26-2012, 09:07 AM
squashman702
1994 ZJ
Did you pull everything and check it like I said? Best way to be sure.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #4910 of 6786 Old 07-26-2012, 09:17 AM Thread Starter
snobrdrkid07
I've had it out a few times now. The holes look fine. I will take a video if the noise later today after work. Ill put the camera under the front and just turn the wheels back and forth to x2 check everything. I don't understand how it wallow out when I havent had any actual full out DW.
-Michael-
post #4911 of 6786 Old 07-26-2012, 11:06 AM
squashman702
1994 ZJ
It could wallow out but not be big enough to allow for enough movement for full-on deathwobble.
If you're not getting death wobble, you need to get under yourself while someone else moves the wheel and touch all of your joints (TRE, trackbar, etc) to make sure that things are not moving. The slight movement you get probably won't be readily apparent without doing so.
Think Twice Garage
post #4912 of 6786 Old 07-26-2012, 11:13 AM Thread Starter
snobrdrkid07
Man, that sucks. :/ how do you fix it?
I am probably going to do that today. I will have my video camera under there and check for things. Especially the track bar. Because fortunately I am not getting full out death wobble
-Michael-
post #4913 of 6786 Old 07-26-2012, 11:16 AM
ChrisHager
Administrator
ChrisHager's Avatar
You can fix it by welding on some proper sized washers...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4914 of 6786 Old 07-26-2012, 11:24 AM Thread Starter
snobrdrkid07
This is true. You know what guys. I forgot about my friends who own a performance/offroad shop. Ill call them later today and I'm sure they could help me out with this track bar situation. (I have not confirmed that it is wallowed, I doubt it is, but they can look at it too and fix if needed)
-Michael-
post #4915 of 6786 Old 07-26-2012, 12:10 PM
squashman702
1994 ZJ
This is the best solution. Done it on a couple of Jeeps and worked every time.
Think Twice Garage
post #4916 of 6786 Old 07-26-2012, 12:19 PM Thread Starter
snobrdrkid07
I think I am going to weld in some washers. Regardless if the bolt holes are bad or not. Just for good measure. Any chance anything is wrong with the axle side mount?
I am going to give my friends a call about welding that in there. The guys hat own the off road shop. They should be able to help me out.
I need to know what size washers to get. Thickness, material, inside diameter and outside diameter. Also I may get a new grade 8 bolt.
Sorry I've been extra 'stressed out'. Between the jeep giving me crap and one of my best friends and roommate being in the hospital. I've been really just been over my stress limit.
Still working on getting that video of the track bar later today.
Planning on doing an oil change and having the ball joints professionally looked at this weekend
Future note, if all goes well I may get some rough country adjustable lower control arms. Because my friends who own the off road shop are a rough country dealer and may be able to hook me up with some arms for cheap.
-Michael-
post #4917 of 6786 Old 07-26-2012, 12:22 PM
Larryftmfw
The only thing I'm thinking is my track bar holes are very wallerd! But it hasn't caused a death wobble yet
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4918 of 6786 Old 07-26-2012, 12:47 PM
squashman702
1994 ZJ
You need to check the axle side of the mount the same way as the body side. Odds are, the axle side is the issue. The metal for the mount is thinner and I have only seen the hole wallowed out on that side.
In terms of hardware, the stock bolt size on a ZJ is an M10 IIRC. Never owned a WJ, but the D30 is fairly similar between the two. Go to HD/Lowes/Tractor Supply and track down a washer that is tightest on this bolt- it won't neccesarily be an M10- may be M8 or a standard size, and use that to weld in place. I would definitely replace the bolt at this point as well.
No need to waste the money to get the ball joints looked at. Jack up one side with the wheel still on the Jeep, and wedge a pry bar under the tire. If you have anything more than a CH of play vertically in the tire, you probably need to do ball joints. The allowable standard is somewhere around 1/32-1/16" of movement.
Think Twice Garage
post #4919 of 6786 Old 07-26-2012, 12:59 PM Thread Starter
snobrdrkid07
I'd be really surprised if the axle side was the issue. Usually on the WJ it is the frame side where I see people weld washers onto it. None the less ill have them both checked out. Not sure, wonder if someone else can say.
Ill see if someone can chime in on the bolt and washer size. Ill need to get all of these parts prior to starting to take things apart.
Alright maybe ill do that too when I get a chance later today.
-Michael-
post #4920 of 6786 Old 07-26-2012, 01:19 PM
AgitatedPancake
Without being able to hear it myself the pop is hard to diagnose, but lets see how recently you've inspected/replaced things on this checklist:
Frame side CA bushings (upper and lower)
Axle side CA bushings (upper and lower)
Track bar bushings (sounds like it's a new JKS?)
Tie Rod Ends (on drag link and tie rod)
Balljoints
Unit bearings
If everything on that list is in good running condition and bolts are tight, you'll have a jeep that rides and feels as tight as stock.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
