Snobrdrkid's WJ Build Thread - Page 327 - JeepForum.com
post #4891 of 6785 Old 07-25-2012, 07:35 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I've done sooooo much only a few things left. Track bar bushings too soft or tires worn incorrectly and causing issues.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4892 of 6785 Old 07-25-2012, 07:38 PM
99WJdan
I have that pop too!
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4893 of 6785 Old 07-25-2012, 07:40 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah. Idk what it is man. Track bar?
-Michael-
post #4894 of 6785 Old 07-25-2012, 07:49 PM
Thomahawk
Maybe its just the Money poping sound, lol,
sorry guys.
Buildthread
Thomahawk is offline
post #4895 of 6785 Old 07-25-2012, 07:49 PM
99WJdan
No idea. Mine sounds like its coming from passenger side front. Also a pop noise when braking sometimes.
Im just shot gunning it now in hopes of fixing it. Im not 100% positive on this but when i replaced the axle shafts in october it went away for a little. Going to replace ball joint next i guess. Maybe jks bushings. I doubt the axle shafts went bad in like 4 months.
99WJdan is offline
post #4896 of 6785 Old 07-25-2012, 07:55 PM Thread Starter
snobrdrkid07
WJ for Life
sorry guys.
Yeah I am busted haha.
It sounds like the TB on my because it happens when I go into the drive way on an angle and one tire hits the bump then the other and Ill hear it.
-Michael-
post #4897 of 6785 Old 07-25-2012, 07:58 PM
99WJdan
Yup. At a certain angle right? Mine does it almost a full lock turning right. About when the drivers side goes off the curb and the passenger side is on top still.
99WJdan is offline
post #4898 of 6785 Old 07-25-2012, 08:02 PM Thread Starter
snobrdrkid07
WJ for Life
My sound is always from the same spot, turning either way. But it doesnt have to be full lock going to the drive way for that to make the sound. weird...
-Michael-
post #4899 of 6785 Old 07-25-2012, 08:06 PM
99WJdan
Oh well if you find out what it is let me know and vise versa haha.
99WJdan is offline
post #4900 of 6785 Old 07-25-2012, 08:08 PM Thread Starter
snobrdrkid07
WJ for Life
You got it. Getting my other set of rims/tires tomorrow. Didn't have any issues with them when I had them on before the lift. Gonna find out whether or not my tires are worn badly.
-Michael-
post #4901 of 6785 Old 07-26-2012, 06:59 AM
squashman702
1994 ZJ
Sounds a lot like a trackbar issue. Are you running double shear on the body side?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #4902 of 6785 Old 07-26-2012, 07:03 AM Thread Starter
snobrdrkid07
WJ for Life
I'm not sure what that is? I'm running a regular old JKS bar.
-Michael-
post #4903 of 6785 Old 07-26-2012, 07:11 AM
ChrisHager
Administrator
ChrisHager's Avatar
Mine made noise because the jam nut worked loose. I'm sure you checked it but it wouldn't hurt to check it again. Also, make sure your track bar end links are tight. They will make a clunk as you describe.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4904 of 6785 Old 07-26-2012, 07:13 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah my jam nut is tight. I checked last night.
I lowered the PSI of the tires and torqued down the track bar bolt yesterday and now its feeling like it wants to dw at 50 MPH. I'm thinking the tire pressure did that. Ill put them back up to 33-34 and see what that does.
I still may get the KOR bushings, what do you think?
-Michael-
post #4905 of 6785 Old 07-26-2012, 07:15 AM
squashman702
1994 ZJ
Double shear means that the bolt is set up as follows:
Bolt head> bracket > trackbar bushing > bracket > nut.
Single shear factory setup on a ZJ/TJ/XJ/etc (not sure about the WJ) is:
Nut> bracket > TRE end of trackbar.
The quick explanation is that double shear is typically what most aftermarket setups utilize because it's stronger and splits the force on the bolt across two metal brackets instead of one.
If you're not able to get the torque wrench to click on 90 lb/ft on the axle side, I'd be willing to bet that it's not tight enough. Trade the torque wrench for a breaker bar and cheater bar if you can't physically put enough force on the torque wrench. Also, did you pull the bolt and trackbar entirely then run the bolt back through to see if the hole has wallowed out at all?
Think Twice Garage
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
