Snobrdrkid's WJ Build Thread - Page 326 - JeepForum.com
post #4876 of 6785 Old 07-25-2012, 08:47 AM
Larryftmfw
Very good
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4877 of 6785 Old 07-25-2012, 11:23 AM
99WJdan
Glad you got that settled.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4878 of 6785 Old 07-25-2012, 11:26 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Yeah its mostly fixed now. What's left is a strong feeling that the little remaining vibes are the road and the worn tire that's still in the front.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4879 of 6785 Old 07-25-2012, 02:16 PM Thread Starter
snobrdrkid07
WJ for Life
Gonna rotate that one tire and stuff later today. I tried to tighten the track bar bolt by hand again. Set wrench to 90 and I couldn't get it to even click. Can't get enough leverage. Gonna take an impact gun to it, is that an ill-advised move? I'm trying to get it tight enough to where the sleeve won't move around.
-Michael-
post #4880 of 6785 Old 07-25-2012, 03:23 PM
99WJdan
I used my impact on the track bar, on the highest setting.
99WJdan is offline
post #4881 of 6785 Old 07-25-2012, 03:34 PM Thread Starter
snobrdrkid07
WJ for Life
LOLOLOL. I just hit mine with an impact gun turned up pretty dang high and hit it 3 times. So it should be pretty tight. Test drive later. Also my front tires were at 37 PSI!? So I dropped them down to 33 PSI.
-Michael-
post #4882 of 6785 Old 07-25-2012, 03:39 PM
AgitatedPancake
tighten your track bar bolts till you think you're going to break them. If you do break them, replace with grade 8 and repeat
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #4883 of 6785 Old 07-25-2012, 03:43 PM Thread Starter
snobrdrkid07
WJ for Life
Hey AP thanks for posting. I hit it pretty good so ill see what happens when I drive it later. Can you correct me if I'm wrong here. The sleeve in the JKS bar is supposed to be held in place against the frame mounts and clamped down via the tightness of the track bar bolt? Also, do you know what grade the factory track bar bolt is?
-Michael-
post #4884 of 6785 Old 07-25-2012, 04:09 PM
99WJdan
I did that a few months ago and they eventually work their way loose. The previous owner had my tires inflated to 44psi i keep my treadwrights at 37psi.
99WJdan is offline
post #4885 of 6785 Old 07-25-2012, 04:12 PM Thread Starter
snobrdrkid07
WJ for Life
I freaking hate track bars and their bolts. Ill keep mine at 33, its only a 29.5 inch tire.
-Michael-
post #4886 of 6785 Old 07-25-2012, 05:02 PM Thread Starter
snobrdrkid07
WJ for Life
Jeez, its so hard not to give up on this jeep. Even with the track bar tighter. I'm still getting a 'pop' sound when moving and turning then when I turn the other way while driving it'll do that pop again. Not loud but noticeable and I can feel it a little bit. I don't know what it is. I had a wobble feeling that was set off by a bump and didn't stop. It wasn't full out dw but it took 5 seconds for it to go away. I'm just so close to going back to stock. I just do not know what else to do.
-Michael-
post #4887 of 6785 Old 07-25-2012, 06:29 PM Thread Starter
snobrdrkid07
WJ for Life
Well latest update is that lowering the pressure to about 33 PSI and tightening the TB bolt with an impact gun has brought about the beginning of DW. It is shimmying like it wants to go to DW at 50 mph. I am so lost here in what to do. Ive done almost everything.
-Michael-
post #4888 of 6785 Old 07-25-2012, 07:11 PM
Thomahawk
You got the lift on. I did not Even knew, seems like you had a great amount of work and progress to your project lately, thumbsup.
Buildthread
Thomahawk is offline
post #4889 of 6785 Old 07-25-2012, 07:13 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah man. Alot of progress. I'm trying to track down death wobble now. Kinda making me want to go back to stock. Lol.
-Michael-
post #4890 of 6785 Old 07-25-2012, 07:30 PM
Thomahawk
Ha ha ha, i see, keep digging into it, you Will find the reason for the DW.
NO Way back!!!
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
