Snobrdrkid's WJ Build Thread - Page 325 - JeepForum.com
post #4861 of 6785 Old 07-24-2012, 03:41 PM
alwaysHI
2003 WJ
Originally Posted by snobrdrkid07
were a good store until the manager changed. Then quality and customer satisfaction went out out door with the previous manager....
Reminds me of work..
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #4862 of 6785 Old 07-24-2012, 03:44 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
I'm gonna go back and get my way with their shotty work. I'm just wondering if I need to go to ANOTHER shop for them to do it "right"
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4863 of 6785 Old 07-24-2012, 03:45 PM Thread Starter
snobrdrkid07
I couldnt work for an *** of a manager. Or would have a hard time doing so.
-Michael-
post #4864 of 6785 Old 07-24-2012, 03:51 PM
alwaysHI
2003 WJ
Gotta do what you gotta do
Build Thread -
SOLD
alwaysHI is offline
post #4865 of 6785 Old 07-24-2012, 03:53 PM Thread Starter
snobrdrkid07
Oh I know it. I'm sure ill have to deal with a bad boss at least once in my working times. In this case I'm not sure if the new manager doesn't care about quality or is a push over to employees there. Either way, its not that great.
-Michael-
post #4866 of 6785 Old 07-24-2012, 05:02 PM Thread Starter
snobrdrkid07
On another note. The JKS bar sounds like its clunking. Need to check the jam nut. When I pull in the driveway the sound is simultaneous with the steering wheel bump. I'm betting the sleeve is bumping into the bolt because its not tight enough. Haha
-Michael-
post #4867 of 6785 Old 07-24-2012, 06:32 PM
compcrasher86
I don't think loose jam nut would cause a lot of clunking the threads shouldn't have any play in them really. Never heard of Merchant tire but the local NTB up here has a very lazy reputation. My buddy works for them and he says he is often rushed when doing oil changes because they pay him flat rate per oil change and he gets yelled at when he takes too long. IMO if someone else changed my oil, which I wouldn't really let happen to begin with, they can take their sweet time and do it right. Agh gettin sidetracked. Wheels often don't balance out if at all without weights so check out another reputable shop in the area. I brought my tire to Firestone when I needed a valve stem replaced and they did a great job and rebalanced the tire perfectly. I've never felt a single imbalance related vibe or wobble. Again, it all depends on local management, tires, tire wear, etc I guess.
Matt
compcrasher86 is offline
post #4868 of 6785 Old 07-24-2012, 06:38 PM Thread Starter
snobrdrkid07
Jam nut is tight. Gotta be the end bolts. Again probably the frame side. JKS bar.... why you cause me so much hassle! Makes me want to get a new factory bar. Going to get the big ol torque wrench out tomorrow again. Maybe an impact gun.
I am going to go in the morning tomorrow and causally ask why my just balanced tire has no weight on it. Then go from there is you know what I mean. I will either have them rebalance if they don't give me my money back and if they do. Ill go somewhere else. I mean how freaking hard can it be to balance a 30 inch tire. You put it on a machine and it tells you exactly where to put a weight.
-Michael-
post #4869 of 6785 Old 07-24-2012, 09:08 PM
Larryftmfw
New steering box is in! Steering is billion times better!!! The steering wheel doesn't roll from side to side over bumps! Still binding when turning it left tho : / idk what's causing that
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4870 of 6785 Old 07-24-2012, 09:32 PM Thread Starter
snobrdrkid07
That's great man. Its much tighter now from what it sounds like?
-Michael-
post #4871 of 6785 Old 07-24-2012, 09:36 PM
Larryftmfw
Just how I like it ; ), still need new 3 new tie rod ends and a ss! Maybe that will fix my binding when turning the wheel left when not moving?
post #4872 of 6785 Old 07-24-2012, 09:49 PM Thread Starter
snobrdrkid07
Binding would be in the gear box. Possible air in the line?
-Michael-
post #4873 of 6785 Old 07-24-2012, 10:07 PM
Larryftmfw
That's impossible
post #4874 of 6785 Old 07-24-2012, 10:29 PM Thread Starter
snobrdrkid07
I don't know! I am just thinking of things!?!
-Michael-
post #4875 of 6785 Old 07-25-2012, 09:15 AM Thread Starter
snobrdrkid07
Sure enough that one tire was out of balance. I watched them do the other 3 and the machine said they were 'OK'. When they got to the one that had NO weights on it. It was 0.25 oz out of balance on the one side. Vibes are mostly gone. Going to rotate the tires and put the one remaining tire that was worn wrong in the rear.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
