Snobrdrkid's WJ Build Thread - Page 323 - JeepForum.com
post #4831 of 6785 Old 07-22-2012, 05:56 PM
wj4play
Originally Posted by snobrdrkid07 View Post
I also want to cut off that dam on the green line. Now that is questionable for water intake issues. I ended up NOT doing this
I chopped this off years ago and have never had an issue..
wj4play is offline
post #4832 of 6785 Old 07-22-2012, 06:03 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Oh no kidding? Did you also do the air box mod?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4833 of 6785 Old 07-22-2012, 06:04 PM
wj4play
The lower control arm bushings not wide enough for the WJ LCA mount?
misalignment bushings,, and also IRO uses the same adjustable control arm for front/rear. normal stock use is fine but what I just found out is that when you move your rear axle back 2-3+ inches they are adjusted to far out (even tho they say they have 6+ inches of adjustment). If I would do it again (and I might anyway) I would go with IRONMan adj lowers with the bend and tell him to make then a few inches longer. and IRO adjustable rear -arm..
I can post a few pics if you want.
Edit:
No I did not do the other mod as you did.... but i might just do it now
4.5in up front/5.5in in rear on short arms
Adjusted to rear stock length
Adjusted all the way out
The reason I am moving the axle back so far is for my 37's
Front test fit
wj4play is offline
post #4834 of 6785 Old 07-22-2012, 07:03 PM Thread Starter
snobrdrkid07
I'd like to see the pictures of the IRO arms. I'm only at 3 inches of lift so the axle wouldn't have to be pushed all that far. Control arms are probably in the fairly distant future. But that'd be another vote for the iron man control arms. Posting pictures is always good.
The air box mod was easy and probably helps haha. I'm not sure if ill cut that tube part out.
-Michael-
post #4835 of 6785 Old 07-22-2012, 07:19 PM
wj4play
updated previous post with pics
wj4play is offline
post #4836 of 6785 Old 07-22-2012, 07:52 PM Thread Starter
snobrdrkid07
Yeah you got a lot of lift and had to push the axle wayyyy back. I guess that's why the started to max out. Thank you for the pictures man.
-Michael-
post #4837 of 6785 Old 07-22-2012, 10:32 PM Thread Starter
snobrdrkid07
Okay guys, another Jeep buddy needs some help.
Specs/Details:
-1994 YJ
-2.5 Liter 4 Cyl
-Was running fine last year (about 10 months ago)
-Did not run for that entire time
-Jump started it and then started up with out much issue.
-Will rev up with out an issue, BUT the issue is ---> under load it will fall on its face and stall out.
-Has fresh gas
-He had put Iridium spark plugs in it. (I had told him that copper plugs would be best, though)
I have told him to check:
-Fuel Filter
-Fuel Pressure
-Run some cleaner through it.
Anything else you guys can think of or suggest?
-Michael-
post #4838 of 6785 Old 07-23-2012, 10:09 AM Thread Starter
snobrdrkid07
Here is the front drive shaft. Those pieces fell off immediately when I took the straps off the front. No beating or hammering at it. Just unbolted and it fell. The rzeppa joint is basically maxed out. When it is on a lift and the axle droops, it goes into ultra death mode. I will have the front drive shaft out for while so more pics can be taken if needed. I have class and then I will do some highway speed test driving later this afternoon.
-Michael-
post #4839 of 6785 Old 07-23-2012, 11:00 AM
Cowboyup94
Specs/Details:
-1994 YJ
-2.5 Liter 4 Cyl
-Has fresh gas
-Fuel Filter
-Fuel Pressure
I would take that over to the YJ thread. We could guess all we want but really those guys would be able to help faster. I would definetly check the fuel pressure.
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #4840 of 6785 Old 07-23-2012, 11:09 AM
Larryftmfw
Damn dude your u joint was in bad condition
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4841 of 6785 Old 07-23-2012, 11:52 AM
Cowboyup94
With that bad U joint were you getting vibes at all? I know when mine went 60+ was not possible.
JEEP
post #4842 of 6785 Old 07-23-2012, 12:28 PM
99WJdan
Time to call Carolina Driveshaft
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4843 of 6785 Old 07-23-2012, 01:56 PM Thread Starter
snobrdrkid07
1. What happened to that u-joint?
2. Can I just put that back in there?
3. I do not know 100% if that was causing the vibes yet. I was only able to get to about 50 mph today. I think that the vibes are actually still there. It may be a wheel still out of balance. *mad*
4. Still can not confirm 100% on vibes because I have not been on the highway.
-Michael-
post #4844 of 6785 Old 07-23-2012, 02:31 PM
Larryftmfw
I'm sure that bad seal did it in, see how it was cracked? Probably had no grease in it did it?
post #4845 of 6785 Old 07-23-2012, 02:33 PM Thread Starter
snobrdrkid07
There really was not an grease in it. Guess there was supposed to be grease in there. The CV Boot is also a little cracked up too.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
