Snobrdrkid's WJ Build Thread - Page 319 - JeepForum.com
post #4771 of 6785 Old 07-17-2012, 12:53 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Just grease where the sleeve goes and the faces of the poly bushings. Not the face where the bushing slides into the bar.
~Richard
billzcat1 is offline
post #4772 of 6785 Old 07-17-2012, 12:56 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
So only where the red bushing touches the sleeve. Just to x2 check. I really want to start doing things right the 1st time, or at least by the 2nd time in this case Keep learning every day.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4773 of 6785 Old 07-17-2012, 12:57 PM
billzcat1
2003 WJ
And the faces where the red bushing rubs on the body/axle mounts.
~Richard
post #4774 of 6785 Old 07-17-2012, 01:00 PM Thread Starter
snobrdrkid07
WJ for Life
Greased the inside part where the sleeve goes.
Can I add some grease to the outside face to where it hits against the TB mounts to keep dirt out and squeaks gone?
-Michael-
post #4775 of 6785 Old 07-17-2012, 01:03 PM Thread Starter
snobrdrkid07
WJ for Life
I must have been posting pics as you replied. Thank you Richard.
-Michael-
post #4776 of 6785 Old 07-17-2012, 01:29 PM Thread Starter
snobrdrkid07
WJ for Life
Track bar successfully greased and torqued back down. Will check the torque again in like 20 or 30 miles.
Edit: heyyy, look at that. Greasing the track bar bushings got rid of the squeaks and clunks. Yay.
-Michael-
post #4777 of 6785 Old 07-18-2012, 07:52 AM Thread Starter
snobrdrkid07
WJ for Life
Since I have the suspension at about 98% complete, I figured I'd start another cheap mod for something to do. I am good at those
I am gonna steal this off WDYDTYWJT thread. I had the idea when I saw an H.O. air box and then sure enough it popped up the next day on that thread. Id like to basically do what this guy did and cut that tube out to make it look like the H.O. Box. Then I can also 1, get the mud out of it, and 2 put my new WIX Paper filter in!
-Michael-
post #4778 of 6785 Old 07-18-2012, 10:34 AM
billzcat1
2003 WJ
I would just cut it straight, and cut it a little further back than the deepest part of that ellipse.
~Richard
post #4779 of 6785 Old 07-18-2012, 11:03 AM Thread Starter
snobrdrkid07
WJ for Life
I just got back home from bring the trailer back from storage and put some blowers on the Jeep to try to cool it down a little faster so I can start this. I drew two different options in blue, I think you are saying something like option 2.
*I had my torque app hooked up today to keep an eye on temps, coolant never went over 210* in stop and go traffic with the trailer and its about 105 here today. Air intake temp was another story, peaked at about 155* when stopped. Wish I had a temp gauge on the trans, curious to see what it is running at.
-Michael-
post #4780 of 6785 Old 07-18-2012, 11:25 AM
billzcat1
2003 WJ
Nope, just option 1. Not all the way to the box edge but close. Fancy shapes don't work unless you shape it as a venturi which isn't really possible.
~Richard
post #4781 of 6785 Old 07-18-2012, 11:50 AM Thread Starter
snobrdrkid07
WJ for Life
Okay cool. I am going to get my hot knife out and see if that'll do it. (Because I can use that inside. Haha)
Little dirty...
-Michael-
post #4782 of 6785 Old 07-18-2012, 12:21 PM Thread Starter
snobrdrkid07
WJ for Life
I also want to cut off that dam on the green line. Now that is questionable for water intake issues. I ended up NOT doing this
-Michael-
post #4783 of 6785 Old 07-18-2012, 02:07 PM Thread Starter
snobrdrkid07
WJ for Life
Final mod. Cleaned it up. Smoothed out the edges. The cutting tool for the soldering iron worked great (200 watt iron). So that's why I cut it like I did.
-Michael-
post #4784 of 6785 Old 07-18-2012, 02:55 PM
ChrisHager
Administrator
ChrisHager's Avatar
Why are you cutting it like that? Better air flow? I must have missed something earlier.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #4785 of 6785 Old 07-18-2012, 02:57 PM Thread Starter
snobrdrkid07
WJ for Life
Chris, the WJ H.O. air box does not have that pipe as part of the air intake system. The H.O. engine supposedly has a "low-restriction" intake. So I "modded" mine to be more similar to the H.O. box. Pics should be above ^
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
