Snobrdrkid's WJ Build Thread - Page 317 - JeepForum.com
post #4741 of 6785 Old 07-15-2012, 07:49 AM
Larryftmfw
I'll look into different horn locations but I'm going to mount my compressor in the spare tire wheel well.
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4742 of 6785 Old 07-15-2012, 11:08 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Akrobatiks (spelling?) Jamie's WJ, he has train horns in his Jeep. If you can find his build thread, he has pictures of them under his Jeep somewhere.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4743 of 6785 Old 07-15-2012, 10:47 PM Thread Starter
snobrdrkid07
WJ for Life
Got mulch today, fun.
- Jeep towed it very well
- Springs handled the weight great
- Bilsteins were amazing
- Tail wag with crap a-arm was horrible (Very close to just buying the IRO a-arm)
- Transmission didn't skip a beat. (Kept it out of OD the entire time)
- Brakes were spot on and took the load with out an issue.
After doing all that work, was to lazy to get to the track bar. I was messing around JF and looking at other Jeep models and I do have to say that the "fully-boxed" WJ control arms are pretty dang stout compared to the TJ/XJ/ZJ for example.
Also ordered a Blackstone Labs Oil Analysis Kit, interested to see what is going on internally. Hope to get that in the next week or so, around the time I am going to change the oil.
-Michael-
post #4744 of 6785 Old 07-15-2012, 11:40 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
That's the truth! The hydroformed control arms are immensely stiff compared to the open, stamped steel arms used in anything else. It's a shame that the aftermarket's approach to making replacement parts was to take the open style arm and weld in an additional plate. Either go Mopar on these or go with something tubular.
~Richard
billzcat1 is offline
post #4745 of 6785 Old 07-16-2012, 08:30 AM Thread Starter
snobrdrkid07
WJ for Life
It is! Good job Jeep on that one! Shame on aftermarket people, haha. If I do go aftermarket arms one day, I do like the IRO arms. I'd like to share my friend's TJ front upper CA and LCA after a wheeling trip. I don't know what it would take to do that to a WJ Control Arm.
-Michael-
post #4746 of 6785 Old 07-16-2012, 09:09 AM
JerzeyBoyWJ
2003 WJ
IRO arms are very nice ..very heavy duty ,nice welds , and bushings are nice aswell ...only thing is with the IRO arms you have to use washers/spacers on the outside of the bushing in order to bolt up and mount the arms to the bracket ...but its no biggie and doesn't harm the performance of the arm
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #4747 of 6785 Old 07-16-2012, 09:25 AM Thread Starter
snobrdrkid07
WJ for Life
Unacceptable. Suing the bug for damage. Muhahaha. Thought that was funny, usually bugs like that get stuck in the radiator. Never seen one stuck like that :P
-Michael-
post #4748 of 6785 Old 07-16-2012, 09:26 AM Thread Starter
snobrdrkid07
WJ for Life
The lower control arm bushings not wide enough for the WJ LCA mount?
-Michael-
post #4749 of 6785 Old 07-16-2012, 09:55 AM
billzcat1
2003 WJ
Yeah, they make them the "normal" size to fit everything else. The WJ control arm mounts are like .100" wider than all other Jeeps. My only problem with the IRO arms is the solid bushings and the price. They look cheap until you make them adjustable. At that point, you might as well get the Iron Man arms.
~Richard
post #4750 of 6785 Old 07-16-2012, 09:56 AM
billzcat1
2003 WJ
And that TJ... looks like he was going too fast and hit a rock with the lower axle mount. Ripped it right off the axle tube and collapsed the UCA to boot. Oops!
~Richard
post #4751 of 6785 Old 07-16-2012, 10:03 AM Thread Starter
snobrdrkid07
WJ for Life
It was 180 dollars for WJ Adjustable Front LCA's from Iron Rock. Is that a fair price? I thought that was a decent price. Adding a washer shouldn't be a big deal.
As for the Guy in the TJ, he is in our off road club and he is the nicest redneck you'll ever meet. He is also in architecture school at Tech, which take alot to get into haha. But he wheels hard and has fun with it. Rock would be the most likely cause.
-Michael-
post #4752 of 6785 Old 07-16-2012, 10:08 AM
billzcat1
2003 WJ
It's not a bad price, but the Iron Man arms are the same price and built with solid stock. And from there it's just a little more for a single-Johnny Joint arm (which is ideal if you take it off-road). We had this discussion before - solid rubber bushings have no place on a solid axle. Bushing compliance is required for flex.
~Richard
post #4753 of 6785 Old 07-16-2012, 10:35 AM Thread Starter
snobrdrkid07
WJ for Life
Solid stock meaning a solid piece of tubing? I haven't seen iron man arms before. Heard of but, haven't seen. Will look them up after class.
And the JJ were road capable and Daily Driver capable verison compared to the heim joints.
I do recall most of this from your talk about new control arms for your WJ
-Michael-
post #4754 of 6785 Old 07-16-2012, 10:45 AM
ChrisHager
Administrator
ChrisHager's Avatar
It's funny you bring this up. Hypothetically, if my father-in-law dropped off some adjustable control arms for a TJ in my garage this past weekend, would they fit on the WJ assuming a washer was placed in the mount to snug everything up?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #4755 of 6785 Old 07-16-2012, 10:53 AM Thread Starter
snobrdrkid07
WJ for Life
Get the wrenches out, and find out!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
