Snobrdrkid's WJ Build Thread - Page 314 - JeepForum.com
post #4696 of 6785 Old 07-13-2012, 08:52 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
JKS Track Bar Videos
Okay Guys. Here we go. Tell me what you all think. Give the videos some more time to process if they do not load. They are also shot in 1080 for extra viewing pleasure.
Frame Side First.
Axle Side.
Found a video of Kevin's WJ with his bushings (and what looks like the upgraded bolts)
Some good news is that is that I DID NOT see any indication on the bolts moving around.
I also lowered the front tire pressure from 34 to 32 PSI.
Edit: I got an appointment for an alignment "check" that includes a printout of the specs. Which ill post. Then I am getting all 4 tires re-balanced for 40 bucks.
WOW Kevin Sucks on shipping...
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #4697 of 6785 Old 07-13-2012, 09:04 AM
ChrisHager
Administrator
ChrisHager's Avatar
Looks like your bolts are good. That's quite a bit of movement on the frame side bushing though...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #4698 of 6785 Old 07-13-2012, 09:07 AM Thread Starter
snobrdrkid07
WJ for Life
Sigghhhh of relief on the bolts. Now I thought that as well with the frame side. Think I should just go ahead and get the KOR Bushings?
-Michael-
post #4699 of 6785 Old 07-13-2012, 09:35 AM
ChrisHager
Administrator
ChrisHager's Avatar
It wouldn't hurt... If the rest of the steering is in good shape and you have a shimmy, that bushing might be causing it.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4700 of 6785 Old 07-13-2012, 09:40 AM Thread Starter
snobrdrkid07
WJ for Life
I have also been emailing the JKS tech and I've also sent them the videos that I posted and am waiting to here what they say as well.
Did I make it clear that the shimmy/little death wobble feeling at 50 Ish is constant? Not just when I hit a bump?
I'm getting an alignment check and tires re-balanced and see what that does too. That amount of moment is just too much. So I guess ill anti up and get the bushings.
-Michael-
post #4701 of 6785 Old 07-13-2012, 09:49 AM
ChrisHager
Administrator
ChrisHager's Avatar
Hmmm. Since it's constant, I'm thinking that's an alignment/balance issue. I'd wait to order the bushings until after you can test out the new changes.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4702 of 6785 Old 07-13-2012, 09:51 AM Thread Starter
snobrdrkid07
WJ for Life
Okay will do, I have an time slot at 2 pm to get tires balanced and the alignment check. So I will see what that does. I will also post the alignment specs when I get them. Compcrasher86 also said the same thing because it was a constant thing. Even a tire out of balance can make it feel like it is going to DW?
-Michael-
post #4703 of 6785 Old 07-13-2012, 09:58 AM
ChrisHager
Administrator
ChrisHager's Avatar
It'll make the steering wheel/vehicle vibrate...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4704 of 6785 Old 07-13-2012, 09:59 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah, its doing that. So hopefully we can get some resolution today.
-Michael-
post #4705 of 6785 Old 07-13-2012, 12:10 PM Thread Starter
snobrdrkid07
WJ for Life
At Merchants Tire now, they are putting the rear tires on the front, balancing all 4 tires and checking out the alignment. While I am currently waiting JKS responded back to me via email after they looked at the videos.
Here is what they said.
"Michael,
The amount your bushings are flexing is completely normal and acceptable for you trackbar. I have actually owned a WJ for a while and had a small vibration similar to the one you’re describing.
What I had found is that the tires were balanced improperly. The WJ uses the lugnuts to center the tire/wheel on the hub. Most tire and wheel shops you a hubcentric balancing machine (balances off of wheel hub). This throws off the wheel balance and caused me to have a shutter when cornering at higher speeds. I was able to find a ship to do a road force balance (blance off of the lugnut holes). And that cured my issue.
Not saying that is your problem, just know it was for me. I can tell you that your bushings are performing as intended.
JKS"
I was very happy with JKS tech support. They have been very helpful and supportive.
-Michael-
post #4706 of 6785 Old 07-13-2012, 12:24 PM
Larryftmfw
Good to hear, keep us posted
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4707 of 6785 Old 07-13-2012, 12:29 PM Thread Starter
snobrdrkid07
WJ for Life
Will do man. I may try to just put some more torque on the frame side bolt if need be.
-Michael-
post #4708 of 6785 Old 07-13-2012, 12:39 PM
Larryftmfw
I doubt that'll do much good
post #4709 of 6785 Old 07-13-2012, 12:41 PM
Dusk53
Thats what I had to do. I had some movement, just cranked down the bolt a bit more and it took some of the slop out, however its not 100% gone.
Mah build
East Carolina University
Dusk53 is offline
post #4710 of 6785 Old 07-13-2012, 01:20 PM Thread Starter
snobrdrkid07
WJ for Life
Dusk - how much torque did you put on it??
They did have to put new weights on the front tires, so I guess they were not perfectly balanced... that may be a good sign.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
