Snobrdrkid's WJ Build Thread - Page 313 - JeepForum.com
post #4681 of 6785 Old 07-12-2012, 05:09 PM
Larryftmfw
Originally Posted by snobrdrkid07
Either the JKS bushings are just too soft and I guess I can try KOR stuff. Maybe I can try torquing them down more?
Or my bolt holes are wallowed out and Id have to get someone to attempt to fix that. I didn't notice it but who knows.
I still want my video
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4682 of 6785 Old 07-12-2012, 05:19 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I guess ill have to do that man. I only have 80 foot pounds on my stock bolts with my JKS at the moment. If they are wallowed, FFFF
Larry - I know man. I've been busy though :/
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4683 of 6785 Old 07-12-2012, 05:21 PM
alwaysHI
2003 WJ
Tighten them first to see if it helps, bubba tight. Then go from there to see if it still has play when you turn the steering wheel left to right.
I cant see you giving up and taking the lift off.....not unless your going higher anyways haha. Don't give up, I've been there, but fixing it is worth it
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #4684 of 6785 Old 07-12-2012, 05:24 PM Thread Starter
snobrdrkid07
WJ for Life
How much can I put on them before starting to get close to breaking. The frame end looked like it had the most or more play in it then the axle side. The frame bolt was in good condition too.
-Michael-
post #4685 of 6785 Old 07-12-2012, 05:28 PM
alwaysHI
2003 WJ
Idk man, it can take quite a bit cause I was really, Really, REALLY yanking on it before it snapped. Go as much as you can, shoot for 100 I guess. Mine was the same as yours, axle end had no play, frame side did
Build Thread -
SOLD
alwaysHI is offline
post #4686 of 6785 Old 07-12-2012, 05:30 PM
Larryftmfw
I know I'm just gonna bug u till u do it
post #4687 of 6785 Old 07-12-2012, 05:38 PM Thread Starter
snobrdrkid07
WJ for Life
Ill see what more torque does. Lol
I know man, you gotta do it to, cause ill forget to video it!
-Michael-
post #4688 of 6785 Old 07-12-2012, 07:33 PM
99WJdan
Get the kor bushings and sleeves. Torque them down helps for a little but it will eventually work its way loose.
I run my stock tires at 33psi. I use to put 35psi in them but i would get more vibrations once they warmed up (i fill my tires in the morning before work).
If you can, find a shop that balances with road force an uses a "finger" mount opposed to the cone. The finger mount actually mounts where the lug nuts go where as the cone just mounds to the hub. It makes a difference. And watch the machine to make sure it zeros out. Sometimes it takes awhile and I know techs are lazy haha.
Some places do free alignment checks. You could always double check your alignment to be on the safe side or go to a offroad shop who actually know what they're doing.
You would be surprised how much of a difference a properly balanced tire and alignment can change the way a vehicle drives.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4689 of 6785 Old 07-12-2012, 08:17 PM Thread Starter
snobrdrkid07
WJ for Life
I wrote an email to JKS tech support about the bushings.
I am looking to order the KOR bushings. Should I get just the 4 bushings or do I need the sleeves and bolts too??? Kevin's site said that with the JKS I can just use my original sleeves. They said only to get the new sleeves and bolts if my track bar was wallowed out. Which I do not think it is.
I'll be so happy if my little problem is being caused by the track bar and this will fix it.
Still going to get the tires rebalanced and see if I can get them to do an alignment check and check pressure. Thanks everyone
-Michael-
post #4690 of 6785 Old 07-12-2012, 09:10 PM
ChrisHager
Administrator
ChrisHager's Avatar
FWIW, I only used the bushings. My JKS sleeves fit snug into the KOR bushings...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #4691 of 6785 Old 07-12-2012, 09:11 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks Chris, that was what I was hoping. Because I did not want to have to drill out the holes just in case I ever have to go back. Did you put any grease on them or just pop them in and go?
-Michael-
post #4692 of 6785 Old 07-12-2012, 09:40 PM
ChrisHager
Administrator
ChrisHager's Avatar
I didn't put any grease on them. There may have been some left over Liquid Wrench on them but other than that, nuthin'.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4693 of 6785 Old 07-12-2012, 09:42 PM Thread Starter
snobrdrkid07
WJ for Life
Okay, was just wondering. My JKS bushing were squeaking over speed bumps. Haha
-Michael-
post #4694 of 6785 Old 07-13-2012, 04:30 AM
99WJdan
If your holes are wallowed out then you need the sleeves.
99WJdan is offline
post #4695 of 6785 Old 07-13-2012, 08:16 AM Thread Starter
snobrdrkid07
WJ for Life
If the bolt was moving around that'd mean the hole was loose? Because the bolt looks nice and tight.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
