Snobrdrkid's WJ Build Thread - Page 311 - JeepForum.com
post #4651 of 6785 Old 07-11-2012, 02:26 PM
99WJdan
Originally Posted by snobrdrkid07 View Post
Ohhhh, I do not know. What would a yes or no mean?
A yes can be multiple things. CV joints, worn tires, suspension components, ect. Thats what mine is doing. As soon as I let off the gas, the shaking in the steering wheel decreases dramatically. I replaced CV joints back in October so I don't think they are going out again (although I do have a click/pop noise when turning/braking sometimes, not sure where that is coming from). Only suspension components that I have not replaced are ball joints. And my tires are extremely worn. Seams like the more worn the tires get, the more it shakes so for me, I'm replacing the tires and getting it aligned to see if that helps.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4652 of 6785 Old 07-11-2012, 02:32 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I'm still wondering if my front drive shaft could be a culprit, didn't think of CV shafts. But the drive shaft would be a more constant vibe. Mine currently seem irregular at times. Not sure of the ball joints, but it wasn't causing an issues before. The tire balance was not an issues before the lift so it should not be an issue after the lift?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4653 of 6785 Old 07-11-2012, 02:38 PM
99WJdan
Do you have the cv-cv type driveshaft? Replaced mine with one from Carolina Driveshaft, double cardan. It helped a good bit with wheel vibrations. Believe it or not, there was actually a time I was driving back to college going 70-75mph with no vibrations or noises.
99WJdan is offline
post #4654 of 6785 Old 07-11-2012, 02:41 PM Thread Starter
snobrdrkid07
WJ for Life
I've got the single u-joint at the axle and a rzeppa trash at the t-case. I did here a significant pop from what sounded like the front d.s. when I was wheeling on the beach.
Bringing this over from Chris's thread that I posted.
This is what I got going for me right now.
- All new tie rods
- new tie rod sleeves
- new track bar and bushings (new track bar didn't seem to get rid of vibes)
- tires were balanced before the lift (no issues)
- JUST got it aligned. And nothing should have messed with toe.
- Ss is still tight
What left is:
- ball joints
- drive shaft
- c.v. joint.
-Michael-
post #4655 of 6785 Old 07-11-2012, 02:44 PM
99WJdan
You have it easy then without converting the diff to a ujoint flange. Is the boot torn?
99WJdan is offline
post #4656 of 6785 Old 07-11-2012, 02:49 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah. That will help if I have to switch. Pulling the front d.s. will be an easy yes/no on "did that fix the vibes?" But I really don't think that will be it, won't be that easy hah
-Michael-
post #4657 of 6785 Old 07-11-2012, 04:06 PM Thread Starter
snobrdrkid07
WJ for Life
I'm riding in my friends lifted 4runner and its all in check. But the same feeling I'm feeling in my jeep is happening in his 4runner. Making me think that I MIGHT be over thinking this.
Then again I over some bumps its rock solid and others it will give a little wobble still.
-Michael-
post #4658 of 6785 Old 07-11-2012, 06:36 PM
Larryftmfw
I for the life of me can't get this stupid tre that connects to the pitman arm
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4659 of 6785 Old 07-12-2012, 05:24 AM Thread Starter
snobrdrkid07
WJ for Life
What's wrong?
-Michael-
post #4660 of 6785 Old 07-12-2012, 06:00 AM Thread Starter
snobrdrkid07
WJ for Life
Also, that'd be a no on the vibes going away when letting off the gas and coasting. They are still there. Butter zone seams to be around 50 to about 60. I may just need more caster?
-Michael-
post #4661 of 6785 Old 07-12-2012, 06:38 AM
Larryftmfw
What's wrong?
It's stuck lol, after 178,000 miles it's no wonder. I also noticed the boots for my other ones are cracked and all..
post #4662 of 6785 Old 07-12-2012, 07:43 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah I guess that will do it. Were you able to get it off?
-Michael-
post #4663 of 6785 Old 07-12-2012, 07:57 AM
Larryftmfw
Not yet
post #4664 of 6785 Old 07-12-2012, 09:08 AM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by Larryftmfw
Not yet
Oops. :/
-Michael-
post #4665 of 6785 Old 07-12-2012, 10:33 AM Thread Starter
snobrdrkid07
WJ for Life
Well I'm left with a few options here. I'm still getting those little shaky beginning of DW feeling is the 50 ish MPH range. I was thinking about getting adjustable lower control arms to get a ton more caster.
Or, just going back to my stock springs and shocks. I just can't deal with DW on a vehicle that I have to drive every day and commute 5 hours back and forth with to college. I just am not sure what to do.
I don't know guys. :/
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
