Snobrdrkid's WJ Build Thread - Page 310 - JeepForum.com
post #4636 of 6785 Old 07-11-2012, 10:11 AM
Larryftmfw
Originally Posted by snobrdrkid07
Now that the front is much tighter with the new track bar. The rear feels like total trash (because it is) with the a-arm being toasted. Next priority.
So does mine, it clunk so much it's annoying
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4637 of 6785 Old 07-11-2012, 12:08 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
WTH, how often does this jam nut come lose?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4638 of 6785 Old 07-11-2012, 12:19 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Not very often. Get it nice and snug.
~Richard
billzcat1 is offline
post #4639 of 6785 Old 07-11-2012, 12:25 PM Thread Starter
snobrdrkid07
WJ for Life
Update. Jam nut was tight, should be after I got it veryyy tight last night. Must be a Jeep thing, because now when I turn the wheel back and forth. I still here what I always have a little clunk going back and forth. I don't know what happened to the other sound I was hearing that was out of the ordinary, weird.
-Michael-
post #4640 of 6785 Old 07-11-2012, 12:33 PM
Larryftmfw
Did the sleeves in the track bar fit the bolts snug? My mount for the track bar on the body side is so messed up, the hole has wallerd out from the loose track bar so I need a shop to weld it
post #4641 of 6785 Old 07-11-2012, 12:38 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah the bolts and bolt holes were all good. I didn't see anything that'd cause concern. No places were it would have been bowed out or anything like that.
-Michael-
post #4642 of 6785 Old 07-11-2012, 12:42 PM
ChrisHager
Administrator
ChrisHager's Avatar
I wrote an initial review of the KOR bushings HERE in my build thread. I think the bushings are nice but they are revealing that I have some other issues somewhere. Because the JKS bushings were much softer, I'm guessing they were dampening some shimmy...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4643 of 6785 Old 07-11-2012, 12:56 PM
billzcat1
2003 WJ
Check the steering box and intermediate shaft. The intermediate shaft in particular.
~Richard
post #4644 of 6785 Old 07-11-2012, 01:08 PM
Larryftmfw
What in particular should he be Checking
post #4645 of 6785 Old 07-11-2012, 01:14 PM
billzcat1
2003 WJ
For play between components. The intermediate shaft is just two pieces of square tubing, one fit inside the other. With non-serviceable u-joints on both ends - these are all likely culprits when everything else is new.
~Richard
post #4646 of 6785 Old 07-11-2012, 01:30 PM
Larryftmfw
How easy are these to replace?
post #4647 of 6785 Old 07-11-2012, 01:55 PM
Larryftmfw
I started pulling my spark plugs and they don't look bad
post #4648 of 6785 Old 07-11-2012, 02:02 PM Thread Starter
snobrdrkid07
WJ for Life
Billz - I will add the intermediate shaft to the list of things to check over.
The jam nut is tight, I know the tie rods are tight, the only thing left is the track bar bushings have some play in them. Chris had just said that the JKS bushings were absorbing some of a shimmy for his case. Then when Chris put in KOR bushings he had more wheel shimmy. So I will also wait to see what he says for his shimmy.
But for me I wonder what could be causing vibes at 45+ mph. The steering wheel wont move the steering wheel back and forth (maybe a TINY bit) to give you an idea of how little these vibes are, you can just feel them throughout the Jeep. It feels like DW but it won't get to full out DW, again thankfully. I do not know what else to do to track down those vibes. It concerns me because it feels like the vibes are coming from the axle (like they would for DW) and putting tons of stress on the components. etc. I am not sure what to do.
-Michael-
post #4649 of 6785 Old 07-11-2012, 02:16 PM
99WJdan
Get to a good speed where the vibrations are noticeable then let off the gas. Does the vibrations go away or become less dramatic?
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4650 of 6785 Old 07-11-2012, 02:17 PM Thread Starter
snobrdrkid07
WJ for Life
Ohhhh, I do not know. What would a yes or no mean?
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
