Snobrdrkid's WJ Build Thread - Page 308 - JeepForum.com
post #4606 of 6786 Old 07-10-2012, 06:28 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
I also did a full lock break test. Holy crap. My friend who was in the Jeep with me, who is a big car person too. This is what he said, "holy f****** sh** man I was not expecting that at all!" "That was ridiculous!"
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4607 of 6786 Old 07-10-2012, 06:59 PM
99WJdan
Yeah theres a small amount of play in my bushings too. I even cranked them down with a impact.
Whats the full lock brake test?
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4608 of 6786 Old 07-10-2012, 07:03 PM Thread Starter
snobrdrkid07
I'm not sure what I am going to do as of now other then contacting JKS.
Rephrase. Slamming the brakes as hard as I can test and see what happens. Like a panic stop. Was able to lock the tires up on rough asphalt. I'm impressed so far. They are still breaking in too.
-Michael-
post #4609 of 6786 Old 07-10-2012, 07:10 PM
99WJdan
Oh haha. Gotcha. Im interested to see what jks says about the bushings. Mine are not moving a good bit, but just enough to be visible. The play in the bushings and the steering gear box is whats giving me vibrations in the steering wheel I think the only solution is the kor bushings, and from what I heard, they are worth it.
99WJdan is offline
post #4610 of 6786 Old 07-10-2012, 07:12 PM
Larryftmfw
I can't get my brakes to lock ever, iv tried, maybe your abs isn't 100%? And there will always be some play with the bushings, there alittle soft to absorb the energy created when you hit bumps and all.
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4611 of 6786 Old 07-10-2012, 07:28 PM Thread Starter
snobrdrkid07
Yeah, ill give them a call or email tomorrow and ill post up what they say.
Chris just installed the KOR bushings into his JKS and will give them a workout tomorrow. He will probably post back here and let us know too.
To my knowledge the brakes are supposed to lock up and kick on ABS to prevent lock up.
I thought they were supposed to be TIGHT.
-Michael-
post #4612 of 6786 Old 07-10-2012, 07:34 PM
Larryftmfw
Tight to a certain extent, get someone to turn the wheel and take a video of the play and post it!
post #4613 of 6786 Old 07-10-2012, 07:52 PM Thread Starter
snobrdrkid07
I should have done a video but I didn't think of it at the time. Ill do that, soon, hopefully.
-Michael-
post #4614 of 6786 Old 07-10-2012, 08:23 PM
Larryftmfw
Lol get it done! : P tomorrow I get new plugs and than get to put in that tre! I'm excited! I might replace that other upstream 02 sensor! I think once I get my steering fixed it's time for a aftermarket exhaust!
post #4615 of 6786 Old 07-10-2012, 08:30 PM Thread Starter
snobrdrkid07
Hahaha okay okay, ill get a video soon.
It feels really good to get stuff done to the jeep haha.
-Michael-
post #4616 of 6786 Old 07-10-2012, 08:33 PM
Larryftmfw
Yes it does!
post #4617 of 6786 Old 07-10-2012, 08:38 PM Thread Starter
snobrdrkid07
Yup.
Next is figuring out why I have some slight vibes (still with the new track bar) in the jeep. Not sure if tires, or track bar or what. Possibly front d.s.?
-Michael-
post #4618 of 6786 Old 07-10-2012, 08:40 PM
Larryftmfw
Yup.
What's the condition of your u joints? Also maybe your tries need to be re balanced? There's so many possibilities but you've covered a lot with replacing the tre's so that helps
post #4619 of 6786 Old 07-10-2012, 08:42 PM Thread Starter
snobrdrkid07
U joint looks good on the axle and the C.V. joint is okay. Hasn't blow up yet. Could be tire out of balance, but is also started after the lift...
-Michael-
post #4620 of 6786 Old 07-10-2012, 08:43 PM
Larryftmfw
Maybe your camber is off alittle, how bad are the vibes? From my research it seems with lifts ds vibes are very common when lifting our jeeps
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
