Snobrdrkid's WJ Build Thread - Page 307 - JeepForum.com
post #4591 of 6785 Old 07-10-2012, 03:16 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Chris - Yup, sounds good. 9 full threads with the jam nut tight. That should get her pretty dang close. Oh, yeah haha, threads on the axle side thanks for all the help and tips! Ill keep y'all posted tonight. I might take it in for an alignment at some point too.
Larry - oh yeah man, Moog is awesome stuff!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4592 of 6785 Old 07-10-2012, 03:19 PM
Larryftmfw
I can wait to order all new stuff! My a arm bushings in the rear I think are bad : / crap!!!!!
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4593 of 6785 Old 07-10-2012, 03:21 PM Thread Starter
snobrdrkid07
For you since you are lifted sky high. I'd recommend the IRO adjustable a-arm for you. That'd be the best way to go for you.
For me. Since I'm at about 2.5 lift in the rear. I think ill just go with a whole new mopar arm and mopar ball joint all installed for me for 300 bucks. By the time I do the IRO arm for me it'll be near 400 bucks.
-Michael-
post #4594 of 6785 Old 07-10-2012, 03:43 PM
Larryftmfw
Wow that's expensive! Lol I'll look into the adj one thanks!
post #4595 of 6785 Old 07-10-2012, 03:51 PM Thread Starter
snobrdrkid07
Yup, it sucks, but the IRO arm is a great arm for lifts. Mopar arm will work for me. It should still be able to handle 2.5 inches of lift.
-Michael-
post #4596 of 6785 Old 07-10-2012, 04:01 PM
techRob
IRO a-arm is $300 and works for 2.5". why would you waste money on another OEM a-arm only to install the IRO later?
techRob is offline
post #4597 of 6785 Old 07-10-2012, 04:04 PM Thread Starter
snobrdrkid07
Because I can get the OEM a arm with a new ball joint installed and done for 300.
It'd cost me 300 + 50 shipping + 50 install for the IRO arm for me.
I'm not sure what ill do yet, if I do install the OEM one, I won't do the IRO one down the road.
-Michael-
post #4598 of 6785 Old 07-10-2012, 04:09 PM
Larryftmfw
I might just go with bushing for now since I have the a-arm spacer that came with my lift
post #4599 of 6785 Old 07-10-2012, 04:09 PM
ChrisHager
Administrator
ChrisHager's Avatar
You could just throw on some rear long arms and skip doing it in stages...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #4600 of 6785 Old 07-10-2012, 04:12 PM
techRob
why not install it yourself? that's half the fun.
techRob is offline
post #4601 of 6785 Old 07-10-2012, 04:17 PM Thread Starter
snobrdrkid07
Don't get the Omix-Ada bushings. Get mopar bushings.
Going to need some more lift to do long arms. I want to keep it at 2.5 inches for now. Maybe one day do 6.5 inch of 35's and 4.56 gears haha
Way to lazy to do the rear a-arm, that thing is a bit** or at least can be. I don't have the tools for it either. Or a way to get it out if its stuck. Its worth it for 50 bucks man. Haha
-Michael-
post #4602 of 6785 Old 07-10-2012, 05:31 PM Thread Starter
snobrdrkid07
So what's the deal with the bolt on the frame side? I can't find a metric or standard size socket to fit. Its like rounded off??? Wth
-Michael-
post #4603 of 6785 Old 07-10-2012, 06:08 PM Thread Starter
snobrdrkid07
Figure it out. Lol. That was a dummy move.
JKS is in and torqued to ~75 ft pounds.
-Michael-
post #4604 of 6785 Old 07-10-2012, 06:27 PM
Larryftmfw
How's it fit? I would love rear long arms since the kit for it replaces that pos a arm set up! But I don't have the $1,000 lying around lol.
post #4605 of 6785 Old 07-10-2012, 07:25 PM Thread Starter
snobrdrkid07
It fits fine. Got it pretty tuned. 9 threads on the jam nut was right about on the money. Shoot its better then what it was center wise.
Sadly...... there is still a tiny bit of play on the JKS poly bushings when torqued to 80 foot pounds. From the looks, much much less then the stock track bar had play wise. Hitting some bumps it I feel it in the steering wheel and a little shaky but better. Its all better.
I'm going to contact JKS about the poly bushings and see what they say.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
