Snobrdrkid's WJ Build Thread - Page 306 - JeepForum.com
post #4576 of 6786 Old 07-09-2012, 10:13 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yep. Off-center steering wheel is proof your track bar is toast.
You could take about 0.010" of the length of the JKS metal sleeves and it would be a perfect fit. Just a light touch with a grinder. But few people have the skill to make it come out nice and flat in doing so. By the time you get it flat, you're too short. I would just install it and crank the bolts down good and tight like everyone says to do and see where you're at. It wouldn't be vastly popular if everyone had major issues with it.
~Richard
billzcat1 is offline
post #4577 of 6786 Old 07-09-2012, 11:12 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Right, I knew something had to be doing that. Yay for toast track bar. Theoretically, nothing that I could have been done to the steering wheel by unbolting and bolting the track bar back could have done that.
I had a suspicion that it'd be a very extreme amount to grind off. So ill let it be and just try to get the JKS in there. What torque did you put the bolts at?
I guess you only really hear about a product is when people have to b**** and complain. XD
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4578 of 6786 Old 07-09-2012, 11:16 AM
billzcat1
2003 WJ
Well, try it at 75 (spec). See how it works out.
After that I just got in there with the breaker bar and reefed on it. If your stock bolts are in poor shape I wouldn't recommend reefing too hard.
~Richard
post #4579 of 6786 Old 07-09-2012, 11:21 AM Thread Starter
snobrdrkid07
WJ for Life
Ill give that a shot.
When I pulled the axle side bolt, looked okay just a little rust on one side. Speaking off, did you read my note on the axle side bolt being tapered?
The frame side bolt looked fine. The parts that were exposed.
-Michael-
post #4580 of 6786 Old 07-10-2012, 09:43 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by snobrdrkid07 View Post
Chris, did you order KOR bushings?
I did indeed order them. They have been sitting on the counter for over a month (apparently, storing jeep parts on the kitchen counter is not something that makes wives happy - write that down).
I'm actually planning on installing them tonight. I haven't had time to mess with it with the wedding/honeymoon and what not. We just got back in from Jamaica Sunday night which means I should now have some time for the jeep! I'm going on a camping/rafting trip this weekend and driving 3.5 hours away so I figured I'd spend the week trying to get everything in order. I'll let you know how they turn out!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4581 of 6786 Old 07-10-2012, 10:11 AM Thread Starter
snobrdrkid07
WJ for Life
Oh that's right, I remember now haha. Ill write that down
Interested to see how the KOR bushings do when you get a chance to put them in. Man, i swear Kevin is making a killing on the mark up on that set. I think I am going to set my track bar the same length as yours. I think a 1/4 inch of lift difference is well, not that much haha. I would think that the JKS will have much less slop then my current bar does. Hopefully. Congratulations on the wedding/honeymoon by the way.
How did you manage to get the frame side bolt of? Any tips or what did you do exactly? Do you need to put a wrench on the back side or can you just take the nut off?
Other then re-centering steering wheel, everything else should still be okay?
-Michael-
post #4582 of 6786 Old 07-10-2012, 11:17 AM
ChrisHager
Administrator
ChrisHager's Avatar
Thanks for the congrats!
The frame side bolt is a pain. They say you can pop out the bump stop. With that out of the way, it's no big deal. I haven't gotten mine out and wonder how hard it will be to install it back in. I usually remove the nut (with a wrench on the other side) then slide the bolt out while mushing the bump stop a bit. It's not easy but it works. Maybe someone else can chime in, perhaps before I go through the process again tonight!
Everything else should be OK besides the steering wheel becoming off center.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4583 of 6786 Old 07-10-2012, 11:56 AM
billzcat1
2003 WJ
You have to squeeze the bump stop really hard to get it past the barbs that hold it in. Once it is out, clean it and grease it, it will be very easy to reinstall and remove again if needed in the future.
~Richard
post #4584 of 6786 Old 07-10-2012, 12:20 PM Thread Starter
snobrdrkid07
WJ for Life
I've got a buddy who will hopefully come over tonight to help me do the track bar. I'm probably running on borrowed time with the stock one. Hopefully we can get it out and get the new track bar in.
Ill keep the bump stop tip in mind, along with that method of getting the bolt out. Would it be okay if I turned the wheels almost all the way to one side to get the pitman arm out of the way while I get to the frame side bolt? Any issues with doing that? I can get my big bar in there with the pitman arm out of the way.
I also put in my rear shocks, easy as pie compared to this track bar issues lol. Rides so much better. Can't wait when the rear shocks are broken in a bit. Another check mark on my list. Feels good to get things done! The 5100s were only a tad longer then my stock shocks?
Also I remember we were talking about garage heights and roof racks. My garage opening is 82 inches. Seems small to me. Its better tight anyway
ForumRunner_20120710_142007.jpg   ForumRunner_20120710_142017.jpg   ForumRunner_20120710_142028.jpg
-Michael-
post #4585 of 6786 Old 07-10-2012, 01:11 PM
ChrisHager
Administrator
ChrisHager's Avatar
I just measured mine last night as well! Unfortunately, I was on the phone when I measured it so I can't quite remember what I came up with . I *think* it was 82.5" to the lowest point.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4586 of 6786 Old 07-10-2012, 01:43 PM Thread Starter
snobrdrkid07
WJ for Life
Oh okay hahaha. You think it'd be okay to have the wheels turned when I do the track bar so the pitman arm will be out of the way?
-Michael-
post #4587 of 6786 Old 07-10-2012, 01:50 PM
ChrisHager
Administrator
ChrisHager's Avatar
I doubt it really matters which way the wheels are pointed when you replace the track bar. Take one out and slap the next one in.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4588 of 6786 Old 07-10-2012, 01:57 PM Thread Starter
snobrdrkid07
WJ for Life
I didn't think so either. Just wanted to ask, another opinion is always good. Like I said I am doing the same length as you for the track bar, Chris. I'm actually at 2.75 inches of lift in the front.
Hoping this track bar will be the last piece to the puzzle. Then re center steering wheel and hope for the best.
-Michael-
post #4589 of 6786 Old 07-10-2012, 02:02 PM
ChrisHager
Administrator
ChrisHager's Avatar
That should be good. I'm right at 2.75" as well.
Edit: I'm sure you know this but I did it wrong the first time - the threaded end goes at the axle side. Once you get it set, throw a tape on and check to see if you are centered. You may decided to spin it one way or the other to dial in the axle just right. Once you're happy with it, tighten 'er down. Make sure the jam nut is good and tight too. Mine worked loose and creates an interesting *thunk* when you turn.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4590 of 6786 Old 07-10-2012, 02:07 PM
Larryftmfw
Talk about heavy duty!!!!
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
