Snobrdrkid's WJ Build Thread - Page 305 - JeepForum.com
post #4561 of 6785 Old 07-08-2012, 12:09 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
If the JKS doesnt work. I am going IRO. Not before leaving the JKS company some words of mine.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4562 of 6785 Old 07-08-2012, 12:15 PM
Larryftmfw
I'm not to happy either, I torqued and used lock tight on the hardware for my quick disconnects and after 2 weeks it all fell apart, the clips broke too. It's going to cost me about 40$ to get the new hardware I need
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline
post #4563 of 6785 Old 07-08-2012, 12:16 PM Thread Starter
snobrdrkid07
WJ for Life
Were those the JKS Quick disco's?
-Michael-
post #4564 of 6785 Old 07-08-2012, 12:45 PM
Larryftmfw
They were
post #4565 of 6785 Old 07-08-2012, 01:13 PM Thread Starter
snobrdrkid07
WJ for Life
Okay. I don't know what to do about it. Ill just give the JKS a try and see what happens.
-Michael-
post #4566 of 6785 Old 07-08-2012, 04:00 PM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by ChrisHager
I just got around to counting threads and measuring the track bar. With the jam nut tightened, I have 9 full threads showing from the bottom of the track bar. Also, I'm at 32 & 5/8" from eye to eye. That should get you pretty close!
57 pages ago on mobile. Bringing it back to the front for reference soon.
Chris, did you order KOR bushings?
-Michael-
post #4567 of 6785 Old 07-08-2012, 07:47 PM Thread Starter
snobrdrkid07
WJ for Life
Well, the JKS bar was a no go for tonight. Was able to get the axle side bolt out. But could not get the frame side to budge. I need a cheater bar for my ratchet as I could not get my torque wrench up there because of the pitman arm. Ideas?
-Michael-
post #4568 of 6785 Old 07-08-2012, 07:48 PM
alwaysHI
2003 WJ
I got my torque wrench up there but put it above the pitman arm and pulled down
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #4569 of 6785 Old 07-08-2012, 07:50 PM Thread Starter
snobrdrkid07
WJ for Life
Problem was that I couldn't get in there because I was running an 18 mm deep well socket to a 3/8 to 1/2 adapter then to the torque wrench. I don't have a 18 mm deep well 1/2 socket.
-Michael-
post #4570 of 6785 Old 07-08-2012, 08:03 PM
alwaysHI
2003 WJ
Ahh that's a different problem. Go borrow one from one of your friends if they got, if not, it's time to invest in one
Build Thread -
SOLD
alwaysHI is offline
post #4571 of 6785 Old 07-08-2012, 08:15 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah that was the issue. I think it would have fit if the reducer was out of the equation. Just another added frustration with lifting.
I went out and drove it around the block after putting that axle side bolt in, felt even shakier then before... great. Also I moved the steering wheel while the axle side TB bolt was out, and now the steering wheel is off center when I put the stock bar back. I did not know that would happen?
Oh, a note on the axle side bolt, it is two different diameters. Near the head of the bolt it is a little thicker and closer to the the threads, a little smaller in diameter. I stuck it in the JKS sleeve and could tell that that was contributing to the movement in the sleeve. Or maybe because it was not tight? But I thought that to be a interesting thing to point out.
-Michael-
post #4572 of 6785 Old 07-08-2012, 08:21 PM
alwaysHI
2003 WJ
When you moved the steering wheel you probably shifted the axle a smudge throwing it out of alignment slightly
Build Thread -
SOLD
alwaysHI is offline
post #4573 of 6785 Old 07-08-2012, 08:22 PM Thread Starter
snobrdrkid07
WJ for Life
But I thought that the same length TB wouldn't do that? I was expecting a change if I had put a different length TB in (aka the JKS). But, I thought even if it did shift, the stock TB would bring it back to where it was?
-Michael-
post #4574 of 6785 Old 07-08-2012, 08:46 PM
Larryftmfw
Hmm strange maybe your bushings shifted?
post #4575 of 6785 Old 07-08-2012, 08:46 PM Thread Starter
snobrdrkid07
WJ for Life
I know right? That does not seem right? Bottom line is that JKS needs to go in ASAP
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
