Snobrdrkid's WJ Build Thread - Page 302 - JeepForum.com
post #4516 of 6785 Old 07-02-2012, 08:30 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Made it to Pittsburgh today. Trip went well, just was different getting used to the Jeep. Getting used to the steering wheel move more with some of the bumps because it is tighter. With the springs, shocks, new stiff tie rod ends, higher center of gravity, crappy shocks in the back still. The shocks being to short in the back make the back jump/hop around. (Also I wound not doubt that my lose a** a-arm is not helping, there is so much play, id bet it doesnt help with tracking straight). Its all making it drive different, not bad, but different. Then when I get rear 5100s, and a new a-arm, ill bet that will help.
By the time Matt told me it was all in my head and I was able to calm down and just get used to it. By the end of the trip I had gotten used to it more.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4517 of 6785 Old 07-03-2012, 11:53 AM Thread Starter
snobrdrkid07
WJ for Life
Ordered a Wix Paper filter today of amazon for 17 bucks, free shipping.
Also, I think that hunk of grease that fell on the rim is causing a tiny bit of vibration, probably should wipe that off haha.
-Michael-
post #4518 of 6785 Old 07-03-2012, 12:04 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
You're such an auto-chondriac.
~Richard
billzcat1 is offline
post #4519 of 6785 Old 07-03-2012, 12:05 PM Thread Starter
snobrdrkid07
WJ for Life
Man, you have no idea. I get the worrying from my mom.... *sigh* Plus, the whole entire Rubicon DW situation has scared me too...
-Michael-
post #4520 of 6785 Old 07-03-2012, 12:07 PM
billzcat1
2003 WJ
Are you sure the vibes are from the grease? It could be an aerodynamic effect from the nick in the paint from the hailstorm.
Valve cap fell off! Ohhhhhh the vibes!
Tire pressure 1 psi low! Ohhhh the tire wear, I can feel it!
~Richard
post #4521 of 6785 Old 07-03-2012, 12:11 PM Thread Starter
snobrdrkid07
WJ for Life
Who knows haha. But the reason I went off about the hail was because the way it was blowing onto the windows at first, sounded much worse then it was.
I wish I could just drive it and try to to worry about it so much. I just cant shake the feeling that something bad is going to happen. Its 99% in my head.
-Michael-
post #4522 of 6785 Old 07-04-2012, 09:38 AM Thread Starter
snobrdrkid07
WJ for Life
This time, this 1%, it is not in my head. I got my brother to get in the Jeep and turn the wheel back and forth, no movement in the tie rods. BUT, there was some movement in the track bar bushings.... CRAPPPP. Looks like Ill be putting the JKS bar and kill two birds with one stone. Align the axle and hopefully the JKS bushings will work with out being too soft.
Guess the track bar explains, the noise I am hearing, why there is some slop in the steering, why there is a wobble over speed bumps while going slow.
-Michael-
post #4523 of 6785 Old 07-04-2012, 11:17 AM
SnowLeopard
What do you have the trackbar bolts torqued to? I know I had to tighten mine some to meet specs. They'll loosen up on you a bit a well, seemingly. Or at least they can. It sounds like all the little, niggling issues you're having are issues that come with lifting a Jeep. It's not going to ever drive the same again, and the idea it'll be nicer than factory isn't going to happen. With the OME and Bilsteins my Jeep was waaay different. Not bad, but also not quite as comfy. It did corner better, surprisingly, and took uneven roads and drastically wavy pavement a lot better. There are some mountain roads in Colorado where they just put up a sign saying "Road Damage" where as you have like 2 seconds to slow to a crawl from 30mph+ before it goes all wonky. Those really put the lift to the test, and my Jeep went over such obstacles a lot better than the stock suspension. I'm just trying to say don't ever expect all these little idiosyncrasies to go away. They're par for the course when altering a vehicle. Most everything is pretty darn good about your Jeep. So try to sit back and enjoy it a little. It's one of those times where your issues are small. Rare as those seem to be with our Jeeps. Now you can work on ironing them out at your leisure.
SnowLeopard is offline
post #4524 of 6785 Old 07-04-2012, 12:49 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks man, for trying to keep my head from unscrewing and falling off completely. I am still running the stock track bar at the moment, that's why I was wondering why they are a little loose. Wonder if I can torque down the stock bolts some more? Its not very bad amount of movement but I could see it move a little back and forth when I had someone turning the wheel.
I am still getting used to the steering wheel moving some more with the bumps because of the tighter suspension. Then like I had said, that little wobble in the front that I can feel at real slow speeds is because of the track bar.
You are right, there are still small things to be ironed out. Still need the rear shocks, need the a arm replaced, looks like I need the track bar replaced with the JKS. Then all of that should iron out the kinks.
-Michael-
post #4525 of 6785 Old 07-04-2012, 03:18 PM
billzcat1
2003 WJ
Also look into the IRO track bar. I almost like their design better with the double-jam nut on the adjuster threads, plus the low cost of replacement bushings (plus people never complain about IRO bushings being too soft). Price is the same between them.
~Richard
post #4526 of 6785 Old 07-04-2012, 03:33 PM Thread Starter
snobrdrkid07
WJ for Life
Well here are the options:
1. Put in the JKS bar, deal with the bushings.
2. Get a FIXED IRO track bar for a 2-3 inch lift and just not have to worry about adjusting. I really do not intend on any more lift. Bushings supposed to be better? Cheaper to replace.
3. Adjustable IRO track bar...
In the mean time. Can I tighten the stock track bar bolts more, right now to attempt to help take out some play for the time being while I'm away from home?
Opinions?
-Michael-
post #4527 of 6785 Old 07-04-2012, 03:35 PM
billzcat1
2003 WJ
Did you loosen the track bar bolts and retorque them after the lift was installed?
~Richard
post #4528 of 6785 Old 07-04-2012, 03:38 PM Thread Starter
snobrdrkid07
WJ for Life
No. I didnt have a chance to. :/ The way work feel, power outage, crazy heat. Think that ruined them?
-Michael-
post #4529 of 6785 Old 07-04-2012, 03:41 PM
billzcat1
2003 WJ
Yup. Or at least, gave aged parts the chance to fail by preloading them at your new ride height. All your arms supported by rubber bushing need to be loosened, cycled, and retorqued in their new position for current ride height. Loosen control arms, bounce the suspension, and retighten. This will keep your bushings alive.
~Richard
post #4530 of 6785 Old 07-04-2012, 03:46 PM Thread Starter
snobrdrkid07
WJ for Life
Too late to salvage the track bar bushings? I think they were going before the lift. I had the same clunk before the lift and before the new tie rods. I thought it was the tie rods, I guess it was the track bar going.
Ill have to do all that with the control arms when I get back home. Hope the control arms can survive another 5-600 miles before that happens.
So what do you think about the after market track bar situation?
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
