Snobrdrkid's WJ Build Thread - Page 292 - JeepForum.com
post #4366 of 6786 Old 06-17-2012, 09:04 PM
Larryftmfw
Originally Posted by snobrdrkid07
Ohhhhh okay. Did you start a build thread?
I did, haven't been on it in a while tho lol
Larryftmfw is offline
post #4367 of 6786 Old 06-17-2012, 09:16 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Mine is pretty awesome, a lot of people flock here to chat and stuff
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4368 of 6786 Old 06-17-2012, 09:27 PM
Larryftmfw
I do like yours, lots of good info
post #4369 of 6786 Old 06-17-2012, 09:28 PM
PhantomWJ
2003 WJ
Awesome.....no way....ha ha ha
PhantomWJ is offline
post #4370 of 6786 Old 06-17-2012, 09:36 PM Thread Starter
snobrdrkid07
WJ for Life
Haha thanks, that is what it is here for.
Get out :P
-Michael-
post #4371 of 6786 Old 06-17-2012, 11:07 PM
PhantomWJ
2003 WJ
Get out :P
No.
post #4372 of 6786 Old 06-18-2012, 03:35 AM
Larryftmfw
No.
Lol
post #4373 of 6786 Old 06-18-2012, 08:25 AM Thread Starter
snobrdrkid07
WJ for Life
No.
Okay then.
-Michael-
post #4374 of 6786 Old 06-18-2012, 08:39 AM Thread Starter
snobrdrkid07
WJ for Life
So more or less back on topic here.
The second set of 3/4 inch spacers will be here today. I may go rent those spring compressors from Auto whatever. Take it and just put it on, then jack the jeep up so the coil will hopefully just fall out and make it easier.
Also getting the rear IRO sway links today. Will do both at the same time, makes the most sense. Since I am only sitting at about 1.5 inches of lift in the rear, the additional 3/4 spacer should give me around 2.25 inches of lift in the rear. Around 21.25 hub to fender.
-Michael-
post #4375 of 6786 Old 06-18-2012, 09:50 AM
PhantomWJ
2003 WJ
at that height you probably wont need the coil spring compressor, but it will most certainly help....just jack up the body as high as you can and drop one side at a time...
post #4376 of 6786 Old 06-18-2012, 10:00 AM Thread Starter
snobrdrkid07
WJ for Life
You are correct that i dont need them. BUT even at full droop (with shocks and sway disco'd) it is still a bit** because I still have to use force to compress the spring to get it in there. So the compressors will just make it overall easier. This will be the 4th time doing this. Lol.
-Michael-
post #4377 of 6786 Old 06-18-2012, 10:19 AM
ChrisHager
Administrator
ChrisHager's Avatar
You could do like I did and just squeeze the spring with your hands. If you're like me, you should be able to mash them down to about 4" tall.
HA! Really though, I just let the axle droop and jacked up the opposite side from where I was working. That gave me tons of room.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4378 of 6786 Old 06-18-2012, 10:36 AM
PhantomWJ
2003 WJ
I know wath you mean...it isn't my first rodeo, or 4th...at any rate, to each their own....
Or, like mentioned above....use the hands to compress them
post #4379 of 6786 Old 06-18-2012, 10:49 AM Thread Starter
snobrdrkid07
WJ for Life
When i put the jeep on jack stands and drop the axle, one side lower at a time. It pops out the breather hose and blah blah blah. I just figured itd be easier to keep them at compressed length, and then drop the axle etc.
-Michael-
post #4380 of 6786 Old 06-18-2012, 10:52 AM
99WJdan
I got a spring compressor when I put my 3/4 spacers in. It was actually more work to use the compressor then it was to jack the other side of the axel up. Only time I can see a spring compressor being better would be if it was a air spring compressor. Those ones you get that you have to tighten are junk.
Did you get the ome hd springs or the medium ones? I got 2.75" with the hd springs. Not sure why you would only get 1.5" with yours unless they were mediums or you have the upcountry springs already.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
