Snobrdrkid's WJ Build Thread - Page 290 - JeepForum.com
post #4336 of 6785 Old 06-17-2012, 03:04 PM
Larryftmfw
Originally Posted by snobrdrkid07
It just seems like I am having to correct it more then I did previously. I do seem to get the same feeling too.
MAYBE it is because my steering wheel is off center and its throwing ME off thinking to go straight to hold the wheel straight but I can currently do that. But that doesn't really explain the 'lighter' feeling in the front.
Mine is off too lol I'm going to do the tre's and If that doesn't fix it I'll be upgrading to a Durango steering box
Larryftmfw is offline
post #4337 of 6785 Old 06-17-2012, 03:57 PM
99WJdan
Mine does it too. I think is has something to do with the track bar not being completely parallel to the drag link? Something with the geometry of the steering components.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4338 of 6785 Old 06-17-2012, 04:05 PM
PhantomWJ
2003 WJ
All Moog TRE's and adjusting sleeves.
Well thank you too. The first package to come to me from Hawaii ever!
How in the world did it get bent??
Mall crawling....web wheeling...ha ha ha...sarcasm
I don't remember, either Ocatillo wells or Calico....probably a big rock....fortunately I have a stock tie rod to replace it with....its cheaper to replace it with stock parts, at least this part is....
PhantomWJ is offline
post #4339 of 6785 Old 06-17-2012, 04:49 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
That a direct swap?
Hmmm you did the moog upgrade already right? Those two not being parallel does apparently cause bump steer from what I've heard
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4340 of 6785 Old 06-17-2012, 04:52 PM Thread Starter
snobrdrkid07
WJ for Life
The Moog sleeve was only like 25 bucks man.
-Michael-
post #4341 of 6785 Old 06-17-2012, 04:54 PM Thread Starter
snobrdrkid07
WJ for Life
All cleaned up!
-Michael-
post #4342 of 6785 Old 06-17-2012, 05:06 PM
PhantomWJ
2003 WJ
Really, as In the whole bar? Good to know.
post #4343 of 6785 Old 06-17-2012, 05:09 PM Thread Starter
snobrdrkid07
WJ for Life
Heck yeah man. The really long tie rod sleeve was like 25 and the the drag link was like 23. Check out rockauto.com. that is where i got my stuff at.
-Michael-
post #4344 of 6785 Old 06-17-2012, 05:26 PM
PhantomWJ
2003 WJ
Cool. I didn't know they were that cheap. I bought a used spare tie rod for $40 with good TREs....
post #4345 of 6785 Old 06-17-2012, 05:32 PM Thread Starter
snobrdrkid07
WJ for Life
Thats not bad. What type of tie rods?
-Michael-
post #4346 of 6785 Old 06-17-2012, 05:39 PM
PhantomWJ
2003 WJ
I dunno...stock....whatevrr was equipped with a stock tie rod...
post #4347 of 6785 Old 06-17-2012, 05:42 PM Thread Starter
snobrdrkid07
WJ for Life
Gotcha. Didn't know if it was after market or something like that.
-Michael-
post #4348 of 6785 Old 06-17-2012, 05:55 PM
99WJdan
yeah i did the moog upgrade. Defiantly tightened my steering up, but it needs an alignment. The threads on the moog tres vs stock are different i believe. It still tracks straight, but i have horrible tire wear now (ordering new tires soon). Plus my steering wheel is off centered. An alignment should fix everything once and for all. Not sure about bump steer tho, you would need to mess around with the geometry and that can get expensive.
99WJdan is offline
post #4349 of 6785 Old 06-17-2012, 06:12 PM Thread Starter
snobrdrkid07
WJ for Life
Anything suspension is gonna be expensive. Ughhhh. It sounds like you need a serious alignment. Why would you wait???
-Michael-
post #4350 of 6785 Old 06-17-2012, 07:10 PM
Larryftmfw
So when my jeep is sitting still I can only turn the wheel a quarter of a turn before it gets so stiff it won't turn, I'm guessing my ps pump is shot
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
