Snobrdrkid's WJ Build Thread - Page 289 - JeepForum.com
post #4321 of 6785 Old 06-16-2012, 10:04 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Thanks for the pics. The original tie rod and drag link are .125 wall so there's a pretty decent improvment in wall thickness.
Can you do an ID measurement on them? That's what the prongs are for that are above the display, near the in/mm button. If it's too late, that's ok too.
~Richard
billzcat1 is offline
post #4322 of 6785 Old 06-16-2012, 10:16 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Is this it?
I would also like to point out that the 'grey' part of the sleeve, the main part, that the ID does not change at all and that the thickness of the tubing is significantly more in the center where there are no threads.
Edit: My calculations give the main part of the sleeve a wall thickness about 0.23 inches! It is tapered down on the ends, BUT the inside is the same ID all the way through. They are very thick!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4323 of 6785 Old 06-16-2012, 10:21 PM
billzcat1
2003 WJ
Perfect.
~Richard
post #4324 of 6785 Old 06-16-2012, 10:22 PM Thread Starter
snobrdrkid07
WJ for Life
Great! I added some more info above in case you missed it.
-Michael-
post #4325 of 6785 Old 06-16-2012, 10:26 PM
billzcat1
2003 WJ
So you have 1.376 OD on the main body with .906 ID (or more in the non-machined center). Looks like .235-wall tubing. It's probably .25-wall tubing, just the ends are bored to accommodate stock-type TREs.
That's a HUGE improvement over the stock .125-wall tubing. I'll be getting this for sure when I do the TREs. This is a note-worthy upgrade for both tie rod and drag link and should not only improve feedback, but also durability on the vulnerable tie rod. Now the JKS is .375 wall-tubing so it's not quite THAT burly, but still a mod worth doing.
~Richard
post #4326 of 6785 Old 06-16-2012, 10:51 PM Thread Starter
snobrdrkid07
WJ for Life
Shoot man, it is DOUBLE the factory stuff. I am very pleased to hear this news, you can not go wrong for freaking 20 bucks! While it may not be as thick as the JKS it is still pretty dang awesome for a tenth of the price! Shoot this is probably already overkill. But, if it is worth doing, it is worth OVER doing! Glad I could help out.
Those numbers varied slightly with 1.375 OD and 0.900 ID being the average. Those numbers apply to both the Tie Rod sleeve and Drag Link.
-Michael-
post #4327 of 6785 Old 06-16-2012, 11:01 PM
Larryftmfw
Very nice! There moog tre's right?
Larryftmfw is offline
post #4328 of 6785 Old 06-16-2012, 11:03 PM
alwaysHI
2003 WJ
Originally Posted by snobrdrkid07
IRO 3 Inch rear sway links will also be here on Monday, thank you AlwaysHI!
Hahah you welcome!
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #4329 of 6785 Old 06-16-2012, 11:28 PM
PhantomWJ
2003 WJ
Yeah, JKS bars still get bent; mine got bent.
It is a good thing I did not buy it new, it came with axles, cause I would not want to spend that much money for it to bend.
PhantomWJ is offline
post #4330 of 6785 Old 06-16-2012, 11:36 PM
billzcat1
2003 WJ
Originally Posted by snobrdrkid07 View Post
Just a quick tip from the ex-machinist in me - When measuring the thickness of just about anything (especially wall thickness on a tube like this), only use the beveled tips of the caliper. That's where the calipers will be most precise for you. Use the thumbwheel and apply light pressure - you'll be able to make those calipers flex a lot if you use too much pressure.
As for the OD - all raw stock runs oversized. So if you need a 1.375" part, you buy 1.375" stock which measures out at a nominal 1.380". Moog just left the body in the original mill finish - no need to turn it down. It would only add cost with no added benefit.
~Richard
post #4331 of 6785 Old 06-17-2012, 09:13 AM Thread Starter
snobrdrkid07
WJ for Life
All Moog TRE's and adjusting sleeves.
Originally Posted by alwaysHI
Hahah you welcome!
Well thank you too. The first package to come to me from Hawaii ever!
How in the world did it get bent??
-Michael-
post #4332 of 6785 Old 06-17-2012, 09:25 AM Thread Starter
snobrdrkid07
WJ for Life
Thanks for the tip with the Calipers, good to know.
Hmm, did not think of that but that makes perfect sense.
-Michael-
post #4333 of 6785 Old 06-17-2012, 02:46 PM Thread Starter
snobrdrkid07
WJ for Life
Question. When I hit a bump it makes the Jeep go off track some (mostly when not holding the steering wheel) anything I can do about this? Caster issue or TRE issue? I have not installed my new Moog TRE stuff yet. That has been my only complaint so far with the new lift.
Second, Is ~4" of up travel on the front shocks too little? The space from the axle to bump stop is about 4" as well. So, going full bump would be fully compressing the shocks and hitting the bump stops. I don't know is DD'ing will cause it to have that much uptravel. Was just wondering what you all thought. I am not too concerned about it at the moment.
-Michael-
post #4334 of 6785 Old 06-17-2012, 02:49 PM
Larryftmfw
My jeep does the same thing, kind of feels like the front end goes light? Could be the tre's
post #4335 of 6785 Old 06-17-2012, 02:51 PM Thread Starter
snobrdrkid07
WJ for Life
It just seems like I am having to correct it more then I did previously. I do seem to get the same feeling too.
MAYBE it is because my steering wheel is off center and its throwing ME off thinking to go straight to hold the wheel straight but I can currently do that. But that doesn't really explain the 'lighter' feeling in the front.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
