Snobrdrkid's WJ Build Thread - Page 283 - JeepForum.com
post #4231 of 6786 Old 06-13-2012, 10:05 AM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by billzcat1
Most alignment shops won't touch an adjustable track bar. Standard shops will limit themselves to the factory adjustments only. If you need the control arms adjusted for pinion/caster then you need to pre-qualify the shop on whether they do that work.
Right, that is why I had said we took the Rubicon to a specialty shop, they do adjustable control arms, track bar etc. And why it also cost about 100 dollars haha. The place is called Bert's alignment. They have an excellent rep around my area. All the places that do lifts around here send it all to Bert's to be aligned.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4232 of 6786 Old 06-13-2012, 10:39 AM
99WJdan
Most shops around me charge $75 for a alignment. I go to a offroad shop tho to get my alignment, $100 and they adjust everything including trackbars.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4233 of 6786 Old 06-13-2012, 02:17 PM Thread Starter
snobrdrkid07
So i have been getting kinda ticked off with my AC drain. I don't know if it clogged or what!? It will drip onto my rubber floor mat. My carpet does not get wet and the seal between the drip pan and the body is good. No leaks there. Here are some pictures.
Normal drip under passenger side by front tire
But it is also dripping here??? Looks like it is going through the frame rail. Which to me is stupid because of rust....
But i am not sure why it is dripping under the area between the front and rear door...
I want to drill a hole
There. But i dont know if that is the best idea yet.
-Michael-
post #4234 of 6786 Old 06-13-2012, 02:35 PM
Larryftmfw
My damn starter crapped out on me today
Larryftmfw is offline
post #4235 of 6786 Old 06-13-2012, 03:59 PM Thread Starter
snobrdrkid07
Sounds like a Jeep. Just Empty Every Pocket.
Did it just stop working? Battery is okay?
-Michael-
post #4236 of 6786 Old 06-13-2012, 04:03 PM Thread Starter
snobrdrkid07
Well after finding more pictures online. I was able to find my a/c drain outlet. It was hiding behind some big wire looms. I put some rubber hose on it to divert all the water away from the frame rails. Because how it sits stock. The water is able to run on the bottom of the outlet and back to where the seal is on the firewall/body. So with this tube all the water should divert right to the ground and should stay out of the frame rails. Pics will come later.
-Michael-
post #4237 of 6786 Old 06-13-2012, 04:41 PM
Larryftmfw
Battery is good, it just crapped out
post #4238 of 6786 Old 06-13-2012, 05:00 PM Thread Starter
snobrdrkid07
That is awesome. =/ Any wires pop off? Or is just clicking?
-Michael-
post #4239 of 6786 Old 06-13-2012, 05:06 PM
Larryftmfw
No, I beat ot with a wrench and it worked after that lol
post #4240 of 6786 Old 06-13-2012, 05:18 PM Thread Starter
snobrdrkid07
Ah I guess the solenoid got stuck?
-Michael-
post #4241 of 6786 Old 06-13-2012, 05:35 PM
Larryftmfw
That's what I'm thinking
post #4242 of 6786 Old 06-13-2012, 08:18 PM Thread Starter
snobrdrkid07
"Tap the Starter" hahaha
-Michael-
post #4243 of 6786 Old 06-13-2012, 08:29 PM
Larryftmfw
I did and she fired right up
post #4244 of 6786 Old 06-13-2012, 08:30 PM Thread Starter
snobrdrkid07
That is the type of fix that is awesome.
Do you have any pictures of your front pinion angle?
-Michael-
post #4245 of 6786 Old 06-13-2012, 08:38 PM
Larryftmfw
Not yet and my front ds is still off. I'm guessing my starter should still be replaced?
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
