Snobrdrkid's WJ Build Thread - Page 282 - JeepForum.com
post #4216 of 6785 Old 06-12-2012, 08:49 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by Larryftmfw View Post
6.5 long arm, the worst was the t-case
Yup, that is a big lift. Custom driveshaft or stock double cardon? Front adjustable long arms? Which brand lift?
I am not sure if even the front stock double cardon driveshaft can handle that much lift.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4217 of 6785 Old 06-12-2012, 08:58 PM Thread Starter
snobrdrkid07
WJ for Life
Update, in preparation to do as many pictures/measurements as I can with the MOOG TRE's compared to factory I bought a digital set of Calipers to get very precise measurements! Since I will be going away and having all the brakes/tie rods done for me while I am gone, there may be lacking side by side photos. However, I will ask to keep all the parts and still get measurements on the factory stuff and photoshop side by side if need be.
I will be getting these numbers:
1. Weight, OD (on the middle and outer section, they differ), ID (threads), and thickness of the material of the tie rod sleeve AND the drag link.
2. I want to to get weights of the Moog TRE's aswell as the thickness of them
3. Anything else?
I did a little test for fun and on the bathroom scale the tie rod sleeve was about 14 pounds mines the locking brackets. With all the hardware and the sleeve, I would guess close to 16 pounds!
-Michael-
post #4218 of 6785 Old 06-12-2012, 09:32 PM
Larryftmfw
It's the iro, and it's the shaft that's all u joints. Non adj front long arms
Larryftmfw is offline
post #4219 of 6785 Old 06-12-2012, 09:34 PM Thread Starter
snobrdrkid07
WJ for Life
Well there is no adjustment in caster if your long arms are not adjustable? I don't think. Unless, no wait a minute, there is caster adjustment with the IRO 3-link setup. That gold bracket should be caster adjustment.
Did you mean IRO front driveshaft?
-Michael-
post #4220 of 6785 Old 06-12-2012, 09:37 PM
Larryftmfw
Iro lift, and yea caster is adj.
post #4221 of 6785 Old 06-12-2012, 09:41 PM Thread Starter
snobrdrkid07
WJ for Life
Okay okay, makes sense now. SO to keep your caster where it needs to be, that means that the pinion angle on the diff side is going to be steep. Kinda surprised that the axle side didnt go first. That is if your caster is in spec. Maybe it is time to go to a double double driveshaft?
-Michael-
post #4222 of 6785 Old 06-12-2012, 10:03 PM
Larryftmfw
What's that look like?
post #4223 of 6785 Old 06-13-2012, 07:37 AM Thread Starter
snobrdrkid07
WJ for Life
I am not an expert on that amount of lift and such. BUT a double double cardon driveshaft is a driveshaft with two u-joints on each side. So, what you have at your t-case would ALSO be at the axle side too. I do not remember many people needing this though. That is why I am conflicted here.
-Michael-
post #4224 of 6785 Old 06-13-2012, 08:05 AM
Larryftmfw
Yea, iro said that my style driveshaft would be more than able to handle this lift! So I'm thinking it was improperly aligned
post #4225 of 6785 Old 06-13-2012, 08:21 AM Thread Starter
snobrdrkid07
WJ for Life
Do you have any alignment specs from your last alignment?
-Michael-
post #4226 of 6785 Old 06-13-2012, 08:54 AM
Larryftmfw
Not sure, the shop charged me 75$ just because it's lifted.... I'm never going back there
post #4227 of 6785 Old 06-13-2012, 09:57 AM Thread Starter
snobrdrkid07
WJ for Life
Well there is a place that I have taken the Rubicon too and it was 100 bucks. But they specialize in lifted vehicles and Jeeps. With lifted Jeeps/vehicles I would feel thatd be necessary. But, with my WJ for example, i dont have adjustable caster or adjustable trackbar in, so i still feel a regular alignment shop can handle it.
-Michael-
post #4228 of 6785 Old 06-13-2012, 09:58 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Sounds like the pinion angle was the problem. Alignment shops will set caster with no concern for pinion angle. Voila, driveshaft is toast. Shouldn't need a double-double, those are actually very hard to balance and not get vibes from since each end has so much more free travel than a single joint when combined with a center slip joint.
~Richard
billzcat1 is offline
post #4229 of 6785 Old 06-13-2012, 10:00 AM
billzcat1
2003 WJ
Most alignment shops won't touch an adjustable track bar. Standard shops will limit themselves to the factory adjustments only. If you need the control arms adjusted for pinion/caster then you need to pre-qualify the shop on whether they do that work.
~Richard
post #4230 of 6785 Old 06-13-2012, 10:00 AM Thread Starter
snobrdrkid07
WJ for Life
Ahh, so I was on the right track with Pinion angle. So you think they set it up to factory caster, which would se the pinion angle to pretty much parallel to the ground. So in turn that would be a pretty steep angle at the axle side.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
