Snobrdrkid's WJ Build Thread - Page 278 - JeepForum.com
post #4156 of 6785 Old 06-07-2012, 08:44 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
1. Old shocks, when unbolted, didnt cause the jeep to raise up or anything like that.
2. The new shocks are for this amount of lift and have about 3 inches of up-travel left along with 4 or so inches of down-travel
My guess as to why they gave me some more height is because they take so much force to compress that that upward force is taking a little bit of weight of the springs and causing more lift. I had to heave half my weight on them to get them to compress
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #4157 of 6785 Old 06-07-2012, 10:04 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yeah, that's actually normal for Bilsteins. Since they are a high-pressure monotube (and take a good 75lbs+ to compress) they actually do provide more than passive damping. They provide a little additional spring rate to the assembly and improve roll stiffness as well.
~Richard
billzcat1 is offline
post #4158 of 6785 Old 06-07-2012, 10:16 AM
ChrisHager
Administrator
ChrisHager's Avatar
Hmm. Makes sense in that aspect! I'm always learning something! Haha
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #4159 of 6785 Old 06-07-2012, 12:44 PM Thread Starter
snobrdrkid07
WJ for Life
Yup! Very nice to get rid of that bouncy front end!!! So that means I need to get the rear 5100's ASAP to bring the back end back up some. Rear is sitting .5 inch lower. I hope the front will settle in some more and come down from that 3" inch lift height or I might need to think of some other options to get that lower.
The rear springs do take the trailer weight well. Only sag about 5/8 with the unloaded trailer on them. Impressed by that.
-Michael-
post #4160 of 6785 Old 06-07-2012, 01:54 PM Thread Starter
snobrdrkid07
WJ for Life
If these dont tighten up my steering.... Holy crap this stuff is BEEFY
ForumRunner_20120607_155124.jpg   ForumRunner_20120607_155139.jpg   ForumRunner_20120607_155158.jpg   ForumRunner_20120607_155245.jpg   ForumRunner_20120607_155303.jpg
-Michael-
post #4161 of 6785 Old 06-07-2012, 02:41 PM
PhantomWJ
2003 WJ
SWEET! That WILL solve some problems...
PhantomWJ is offline
post #4162 of 6785 Old 06-07-2012, 03:13 PM
billzcat1
2003 WJ
Nice. Thanks for confirming that they are greaseable.
~Richard
post #4163 of 6785 Old 06-07-2012, 04:20 PM Thread Starter
snobrdrkid07
WJ for Life
I didnt have any problems with the steering. I could feel the bumps in the steering and i didnt like that. On some of the big bumps I could feel it wobble for a 1/2 second and didnt like that at all. My steering stabilzer is pretty new and aftermarket. Then i figured that the tie rods have 105k on them and are probably getting close to their end. Especially how I drive. So i am hoping that all these new parts will take care of that. If i ever have a lick of death wobble... i am just going to be pissed.
No problem. They fittings arent in obviously but they came with the grease fitting, a new nut and cotter pin.
-Michael-
post #4164 of 6785 Old 06-07-2012, 08:29 PM Thread Starter
snobrdrkid07
WJ for Life
So I get this right the first time. Wanted to double check with you all.
-Michael-
post #4165 of 6785 Old 06-07-2012, 08:31 PM
compcrasher86
Just so you know (and I've stressed this before), you'll be feeling the bumps a whole lot more with these moog components. You won't get any wobbling or shaking but don't expect to float over bumps. Stiffer steering components means more gets transmitted through the linkage and to your steering wheel. I personally like the extra feedback. You'll get used to it and it feels a lot better.
Also an SS is just there to mask bad components, according to my roommate a steering linkage in perfect condition shouldn't need an SS. That's how I figured out I had bad components to begin with, took off my SS. Wanna experience DW full out uncontrollable? Take your SS off grip your wheel hard and hit a bump at an angle. Okay no don't do that you'll wanna drive your jeep to a used car lot and sell it on the spot lol....
Matt
compcrasher86 is offline
post #4166 of 6785 Old 06-07-2012, 08:35 PM Thread Starter
snobrdrkid07
WJ for Life
I think they is a difference between feeling the bumps like I did when it was stock height. Compared to now where I feel the bump in the wheel and it wobbles for a split second. That is what I want to get rid off. That half second of wobble oh s*** moment. If I feel the bumps okay not a big deal. Just dont want ANY wobble feelings. Dealt with that enough with the other Jeep. Does that make sense what I said? Feeling the bumps in the steering wheel versus the wobble feeling?
No, I am good, I don't ever want to experience DW in my WJ. Because you are right, it would be going back to stock. That is for sure.
-Michael-
post #4167 of 6785 Old 06-07-2012, 08:42 PM
billzcat1
2003 WJ
False. On our Jeeps, a steering stabilizer is necessary to prevent death wobble. The track bar/steering geometry can easily develop a resonant motion side-to-side merely on the bushing compliance and suspension travel. Voila, death wobble. This is specific to vehicles with a solid axle, coil springs, and recirculating steering arrangement. The steering stabilizer damps those vibrations and impacts to prevent the resonance from forming. Even stock JKs experience death wobble from undersized components.
Now on an IFS car with rack & pinion, a steering damper is unnecessary. A great many cars are shipped without them, although the driving experience is certainly more pleasant with it installed.
I also agree, heavier (stiffer) steering components give better feedback and the increase in unsprung weight can make a palpable difference in ride. I certainly felt a difference installing the JKS tie rod, even with original TREs.
~Richard
post #4168 of 6785 Old 06-07-2012, 08:52 PM Thread Starter
snobrdrkid07
WJ for Life
I did not know that it was 100% necessary but that does make sense. Even stock height Jeeps can still get DW.
So what you mean by stiffer is that it gives a more responsive and sportier type steering? Will this new stuff help get rid of that slight wobble that I have on the big bumps?
-Michael-
post #4169 of 6785 Old 06-07-2012, 09:07 PM
billzcat1
2003 WJ
I wouldn't say sportier. I would say more confident, more direct. The nature of the recirculating box steering arrangement doesn't lend itself to sportiness. I was actually surprised by the change from the JKS TR though. I wasn't expecting a notable difference from just doing the tie rod. It makes you realize how much flex there is in the OEM thin-tube tie rod. The new TREs will probably help more with the wobble than anything else.
Regarding steering stabilizers: I was feeling way too much steering wobble, and bumps were too harsh in the wheel. Hit a bump, have to correct the steering. All the TREs tested out ok by hand and my track bar has maybe 10k on it. Put the Moog STB on it, now it just rolls over bumps like a steamroller. Like the Jeep is flattening out the world. Made a huge difference over the OEM SS.
~Richard
post #4170 of 6785 Old 06-07-2012, 09:09 PM
ZB_WJ
I just spent 113 hours reading your build. Lol jk
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
