Snobrdrkid's WJ Build Thread - Page 269 - JeepForum.com
post #4021 of 6785 Old 05-18-2012, 10:08 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Could make sooooooo many jokes off that. If only the language/content filter here was the same as pirate4x4 lol.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4022 of 6785 Old 05-18-2012, 11:24 PM
ChrisHager
Administrator
ChrisHager's Avatar
Hey now, its only plastic! Metal chips. Scratched plastic can be covered with bedliner! :-)
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #4023 of 6785 Old 05-18-2012, 11:47 PM
compcrasher86
I could totally understand if you had limited cladding and didn't wanna chip the paint but... Laredo plastic can go through an armageddon and come out unscathed. Even if it does scratch you'll never notice it.
Matt
compcrasher86 is offline
post #4024 of 6785 Old 05-19-2012, 11:51 AM Thread Starter
snobrdrkid07
WJ for Life
Its less that i have to wash too. Also, i am still working on my 04 limited bumpers/cladding
Another note. Drag link isnt moving at all. Yes i did loosen those two things on each end of the link. Then tried to turn it. Nothing. Looks like i will have to just deal with it. And i was forcing pretty good on it. Enough to have metal scraping come off with the pipe wrench. Oh well. Everything else looks solid under there.
-Michael-
post #4025 of 6785 Old 05-19-2012, 12:01 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Fun! At least know you need to replace it when you eventually do TREs. Unfortunately you'll be stuck with a crooked steering wheel until you do. The drag link is cheap, like $25 on Rockauto. Just do it and let it be done.
~Richard
billzcat1 is offline
post #4026 of 6785 Old 05-19-2012, 12:04 PM
robd2003
Spray some PB blaster on it let soak for a while, spray again; repeat till next weekend. Then use pipe wrench. Also try and go both ways with the adjuster sleeve. Typically will free it up.
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #4027 of 6785 Old 05-19-2012, 12:07 PM Thread Starter
snobrdrkid07
WJ for Life
If I do new tie rods, going moog on all 4 ends and will pick up a new tie rod and drag link. Then get it aligned and steering re centered.
Ill pick some of that up the next time I go to a store. Autozone im assuming would have that?? Then will give it another shot.
Did I tell you all about my lug nuts? There where two lugs that would NOT break lose. I ended up getting one JAMMED in my socket.
-Michael-
post #4028 of 6785 Old 05-19-2012, 01:34 PM
ChrisHager
Administrator
ChrisHager's Avatar
Socket in a vice, screw driver through the socket and against the lug nut, hammer against the screw driver. The screw driver may damage the lug nut covering but its probably damaged already looking at the way its stuck...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4029 of 6785 Old 05-19-2012, 01:37 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah I had a screw driver in there and banging it on the ground trying to get it out. That was not enough, you are right, I am going to need something more to get it out. Such as getting it a vise and hammering it out. Thankfully I have a handful of extra lugs. I need to just bite the bullet and order those American Muscle Lugs that are solid. The cap broke and slipped and I am pretty sure that is how it got all jammed up in there.
-Michael-
post #4030 of 6785 Old 05-19-2012, 01:57 PM
99WJdan
I just ordered all new moog tie rod ends and adjusting sleeves for the tie rod and drag link. $203 shipped. I also got a new tensioner. Rock auto has the best prices, but i think autozone/advance price matches.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #4031 of 6785 Old 05-19-2012, 03:14 PM
ChrisHager
Administrator
ChrisHager's Avatar
Have you tried tightening it back on until the socket broke loose. Once it pops, you could switch to the next size down to remove it again.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4032 of 6785 Old 05-19-2012, 03:43 PM Thread Starter
snobrdrkid07
WJ for Life
I have not tried that. Was afraid i was going to manage to break a stud lol.
But that is the correct size socket.... 19 mm.
-Michael-
post #4033 of 6785 Old 05-19-2012, 03:47 PM
ChrisHager
Administrator
ChrisHager's Avatar
If the cap popped off, it'll be an 18 I believe...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #4034 of 6785 Old 05-19-2012, 03:48 PM Thread Starter
snobrdrkid07
WJ for Life
Sorry, lol more detail. The cap, AND lug are stuck in there hahahaha.
-Michael-
post #4035 of 6785 Old 05-19-2012, 04:45 PM
ChrisHager
Administrator
ChrisHager's Avatar
Oh sorry bout that. For some reason. I was thinking the cap popped off.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
