Snobrdrkid's WJ Build Thread - Page 244 - JeepForum.com
post #3646 of 6785 Old 04-08-2012, 08:52 PM
robd2003
Ah okay, im used to just seeing one fan. My 03 I had came with the hydaulic drivin fan which was tits at cooling it down. Sounded like jumbo jet. Ha, and our 02 that we have now only has the Efan. But i also dont have the tow package either.
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #3647 of 6785 Old 04-08-2012, 08:53 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Hahaha, I am sure it is just as loud as the mechanical fan is! But I like having both if the e-fan were to die on me.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #3648 of 6785 Old 04-08-2012, 08:58 PM
robd2003
Yeah my efan died out of town when we went to eat. let it sit a few days after we limped it home, tore apart the front end and diagnosed everything, threw it back together and no problems. This was in a 30min time span
Jeeps:
robd2003 is offline
post #3649 of 6785 Old 04-08-2012, 09:15 PM Thread Starter
snobrdrkid07
WJ for Life
The 4.0 is much more forgiving with an overheat. I had mine start creeping past 210 on the beach when I was pushing hard. At the time my mechanical fan clutch was dead and the e-fan was not able to keep up.
-Michael-
post #3650 of 6785 Old 04-08-2012, 09:16 PM
compcrasher86
ahhh, thats another +1 for the V8 WJs... Hydraulic fan, that thing is a beast!!! I want
Matt
compcrasher86 is offline
post #3651 of 6785 Old 04-08-2012, 09:17 PM Thread Starter
snobrdrkid07
WJ for Life
This is a -1 for the v8... less forgiving then an overheat. But my mechanical and e-fan do the job.
-Michael-
post #3652 of 6785 Old 04-08-2012, 09:24 PM
compcrasher86
-1 for the i6 for having a crappy e-fan relay design that will just fail without warning and allow for overheat. And I wouldnt want to overheat my i6 in any circumstance simply because I do not trust the 0331 head just as much as I dont trust the alluminum 4.7 heads. I do agree the overheat with the v8 thing is a big nono but if everything is maintained and you're not doing something horribly wrong... there shouldnt be any overheating.
Matt
post #3653 of 6785 Old 04-08-2012, 09:27 PM Thread Starter
snobrdrkid07
WJ for Life
While I will agree about the e-fan being crap haha. Like I said, when my mechanical fan clutch was dead, the e-fan could not keep up on the beach. Granted it was 95 degrees, AC blasting, and my foot down hard on the beach.
Eww I forgot, the 2001's with that crappy cast...
I will also agree, there should not be a reason for overheating unless something is wrong with it. Under normal conditions you should be fine with the 4.7
-Michael-
post #3654 of 6785 Old 04-08-2012, 09:28 PM
robd2003
I overheated the 4.7once with no problems afterwards to my surprise, guess luck of the draw
Jeeps:
robd2003 is offline
post #3655 of 6785 Old 04-08-2012, 09:28 PM Thread Starter
snobrdrkid07
WJ for Life
It probably depends on the severity and duration...
-Michael-
post #3656 of 6785 Old 04-09-2012, 01:20 AM
robd2003
True.
Tonight I managed to install the addcco rear sway bar from my first jeep.
It handles amazingly on highway and off ramps
Jeeps:
robd2003 is offline
post #3657 of 6785 Old 04-09-2012, 01:43 AM
compcrasher86
robd what are your suspension mods... she sure doesnt look stock from your avatar but your sig and Jeep info say otherwise. I'm curious because I was always interested in the addco but was nervous of adding it to a lifted Jeep. I know it stiffens the feel out alot but I'm not sure if... on a lifted Jeep with higher center of gravity... this puts it at a higher risk of lifting a tire and possibly flipping. With my OME's I've tested I can still... in normal conditions.... lose traction without getting near that "ohhh shhhhh we're going over" point
Matt
post #3658 of 6785 Old 04-09-2012, 07:29 AM
robd2003
My avatar was my 03 V8 I had, it was lifted 4" with rc-x components, and 265/70R17 m/t's which measured almost 33's. It handled a lot better on highway, but off road really did limit about 3 inches of flex, when I get a chance this week ill take a pic of stock jeep flex on my log without swaybar and with sway bar so you see the difference.
I never once felt tippy offroad with it either.
Jeeps:
robd2003 is offline
post #3659 of 6785 Old 04-09-2012, 07:54 AM
compcrasher86
Awesome... How was that bar on the road while lifted? Michael I know this is in your build thread but it's relevant because you're going to be gettin one of these inevitably
Matt
post #3660 of 6785 Old 04-09-2012, 07:58 AM Thread Starter
snobrdrkid07
WJ for Life
Everyone that regularly posts here knows that this has turned into a discussion about elements about my Jeep and Jeep related Tech. Which is completely fine with me! And that's so true, im sure ill end up getting on.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
