Snobrdrkid's WJ Build Thread - Page 242 - JeepForum.com
post #3616 of 6785 Old 04-05-2012, 11:19 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Originally Posted by snobrdrkid07 View Post
About to hit BUY NOW Jeep!!!
KBB valued at 17,200!
Don't do it man! You already have a blue one!
~Richard
billzcat1 is offline
post #3617 of 6785 Old 04-06-2012, 04:44 AM
compcrasher86
But... But... V8
Go ahead Michael.. Press the button... DO IT bahaha if I had 15 grand layin around man.
Matt
compcrasher86 is offline
post #3618 of 6785 Old 04-06-2012, 08:02 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I like the blue, even though it does show scratches! :P
Originally Posted by compcrasher86 View Post
But... But... V8
Yeah let me just pull that 15-16 thousand out of my other off-shore account
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #3619 of 6785 Old 04-06-2012, 08:04 PM Thread Starter
snobrdrkid07
WJ for Life
Went shopping for the Jeep.
Bought some washer to compress the rear shocks.
Some wire loom for the trans cooler lines
zip-ties
wire hangers
bucket
sponge
scratch-x 2.0
-Michael-
post #3620 of 6785 Old 04-06-2012, 10:43 PM
billzcat1
2003 WJ
For a specific area (where it is rubbing/chafing?) Or just "for good measure"?
If you need to protect a single area, wrapping it in friction tape is a much better idea. Another idea is to take the next size up hose, slit it lengthwise, and install over the tube you are protecting. Zip tie it in place.
I hate wire loom. On a hose like that I'd imagine it doing more harm than good.
~Richard
post #3621 of 6785 Old 04-06-2012, 10:47 PM Thread Starter
snobrdrkid07
WJ for Life
Um, I just bought it because I saw it. I routed them pretty well to where there isn't any rubbing. I thought about using it as just a good measure type deal.
What is this friction tape? Just another coating to wrap the rubber hose in?
-Michael-
post #3622 of 6785 Old 04-07-2012, 02:31 AM
compcrasher86
guilty as charged I suggested wire loom. Never had any problems with it and it was just to avoid sharp edges and metal on rubber contact. I also wrapped densely in electrical tape afterwards myself. Never had any problems before the tranny cooler hose is pretty thick and strong it just needs protection from sharp abrasion
Matt
post #3623 of 6785 Old 04-07-2012, 08:12 PM Thread Starter
snobrdrkid07
WJ for Life
LAWL, I have not worked on MY Jeep today. I was helping a friend out all day today, we made his truck SHINE! Tomorrow I am getting to the Jeep. I really dont have any areas where it is rubbing. It may have just been an impulse buy.
-Michael-
post #3624 of 6785 Old 04-07-2012, 11:01 PM
billzcat1
2003 WJ
Friction tape is a cloth-based electrical tape with a gummy adhesive. It's what gets used by OEMs to wrap original wiring harnesses. Much more durable than electrical tape. It's similar to the grip tape you use on tennis rackets, hockey sticks, etc. I used some in a few places on my winch wiring harness for additional abrasion resistance (2 ga doesn't make sharp curves real well). Where it touches on the license plate (when the winch is mounted) has actually worn away the license plate, not the tape.
You can use it if you want to, but I've never seen an OEM use additional protection around flexible lines like that. Especially when you consider that your lines are fiber-reinforced pressure-rated hoses. Anything that is sharp enough to cut or pinch your trans cooler lines is just going to cut right through the wire loom (which is substantially weaker than the cooler lines).
So there's my thoughts on it.
~Richard
post #3625 of 6785 Old 04-07-2012, 11:31 PM Thread Starter
snobrdrkid07
WJ for Life
Thanks man for explaining! Sounds like some tough stuff. I think I will return it, I don't need it and you are right. Because the lines are braided and aren't even really rubbing on anything.
I do plan on fixing the shocks tomorrow by adding some washer to get hopefully get them to stop clunking around.
-Michael-
post #3626 of 6785 Old 04-08-2012, 12:27 PM
robd2003
Anyways. Back to MY Jeep. I've been having some weird noise when accelerating hard for a brief second. I was messing around the other day and heard it again. Wonder what the heck it was, figuring it was the transmission about to explode. Since I really didn't want to accept that answer. I went looking around and found this...
That would be the mechanical fan hitting the metal backing of the e-fan.
Im confused as to why you have an e-fan AND mechanical fan?
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #3627 of 6785 Old 04-08-2012, 01:16 PM
Cowboyup94
I wouldn't even waste my time or money.
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #3628 of 6785 Old 04-08-2012, 01:32 PM
billzcat1
2003 WJ
The 4.0s with towing package had an E-fan as well as a supplemental mechanical fan. The bigger concern is "why is it hitting?" My money's on motor mounts.
~Richard
post #3629 of 6785 Old 04-08-2012, 02:09 PM Thread Starter
snobrdrkid07
WJ for Life
Beat me to it, exactly. Both came with the tow package
Bingo, my mechanic took a look at them and they were "cracking" but not in dire need of replacement at the time (over spring break was short on time). I am going to have the two engine mounts, and trans mount replaced this summer. It will only hit if I brake stand or floor it from a stop.... hehe
-Michael-
post #3630 of 6785 Old 04-08-2012, 03:52 PM Thread Starter
snobrdrkid07
WJ for Life
Got some work done on the Jeep today. Starting off with the rear shocks. Well, I found the problem. The bolt that goes through was smaller then the metal sleeve on the shock. There was not much that I could do, and with that being said, I do not thing jamming the washers in there would have helped either. Soooo, while I had the tire off, broke out the good old torque wrench and got them down to 85 foot pounds. With hopes (since the metal sleeves have teeth on each side) that torquing them down will bite into the metal sleeves and keep them in once place, the in turn keeping the bushing from moving, and the eliminating the clunk, which I think it did!
Next off I glued on my lug nuts with some super glue... Haha, rephrase, I glued the "caps" back on to the lug nuts themselves. It is just a PIA when they fall off because then a 19 mm socket is too lose. So hopefully that will solve that issue. If not, back to the junkyard for more!
Ran around today too and returned and bought a few things. Took back the wire loom stuff, also took back the scratch -x 2.0, did not work well enough for 10 bucks. Then went to lowes and bought a 5" 1/2" drive extension and a 19mm 1/2 drive socket and torqued the lugs down to 105-110 ft pounds. All in a good few hours time, minus the bashing of the fingers when a socket slips off the bolt and the wrench and your hand goes right into the disk and caliper. OUCH.
Decent Fuel Econ today with a random Odometer shot.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
