Snobrdrkid's WJ Build Thread - Page 240 - JeepForum.com
post #3586 of 6785 Old 04-03-2012, 01:26 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I had thought about just having to unbolt one side and leave the other connected. The sway bar would just move with the one side. For next time!
We were actually out there for a trail clean up before we actually go to wheeling for the same reason, to keep the property owner happy.
Oh no, that is really really pathetic, cruel, and just horrid. I would not be going near there again. Pictures looked like a blast, and the front disco'd
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #3587 of 6785 Old 04-03-2012, 06:26 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Actually, I could only get one side off on that trip. After that I got discos since I couldn't get the passenger side off without laying on my back in the dirt. Having one side discoed was not very effective as the passenger side still couldn't droop effectively. So I don't recommend that setup. What would be ideal would be to get ahold of an AntiRock like we were discussing last week, just that no one has figured out how to make it work yet. And it's pretty expensive to be the guinea pig.
~Richard
billzcat1 is offline
post #3588 of 6785 Old 04-03-2012, 09:50 AM Thread Starter
snobrdrkid07
WJ for Life
I just watched the AntiRock sway bar video on Currie's website. It looks really cool and basically gives more flex over stock, which is the plus side obviously, but what I did not like is how they said that it is not as stiff as the stock bar, which it can't be to give more flex. But, I don't think I could run that because it is a lighter bar, and I need all anti-sway with the Jeep. I could go with an electronic lock/unlock sway bar.
How is only connecting one side limit travel on one side? I would have thought that just letting one side off, would be fine. Theoretically be no limit on the travel? Or I could get some JKS Quick Disco's and call it a day!
-Michael-
post #3589 of 6785 Old 04-03-2012, 10:31 AM
billzcat1
2003 WJ
It's still connected to the body. The sway bar end links don't freely pivot, and as the bar rotates with axle travel, the arc it makes restricts motion. Disconnecting one side kills the advantage of having a sway bar without having the flex of being disconnected. Trust me, it didn't work out very well. Slightly better than connected, but no, just no.
I had both the JKS and the Rough Country discos. The JKS's clunked a fair bit after only 3000 miles. When I asked JKS how I could fix it (after trying many different things) they told me "thanks for your money go piss up a rope" more or less. The RCs were defective right out of the box but RC did make it right. Then the crush sleeves they came with crushed, the hardware is all garbage, the links much too long for 3" lift and the design poor. Neither is a great option but I'm making do with the RCs.
Now that I've fixed all the issues with the RCs, they actually work very well. Clunk free for 10k so far and the geometry is fixed for better ride + handling.
~Richard
post #3590 of 6785 Old 04-03-2012, 10:39 AM Thread Starter
snobrdrkid07
WJ for Life
Oh true, I can see what you are saying now. I was thinking that with one side disco'd that the other would have a longer range of travel seeing how the other side was not limiting it at all. But the way to go is to get both side disco'd. Just get some on board air and an impact gun with me so I can quickly take off the links!
Ew, I hate clunking. I do remember reading about you modifying the front links from RC and making due with them. That disappoints me that JKS would have that low of quality, then the customer service just shot out the rest. Especially because JKS is not cheap. Does IRO have a front disconnect link? If I had time, tools, and material, I'd like to try to fab some QD's with some heim joints or something with some sort of disconnect method that I could come up with.
-Michael-
post #3591 of 6785 Old 04-03-2012, 12:02 PM
billzcat1
2003 WJ
Well, you DO get a little longer travel with one side discoed, just not enough to make much difference.
Yeah the JKS were a little spendy for them to tell me, "Yup, Jeeps get driven hard, things are going to clunk" meanwhile they have 3000 miles on them and have never been wheeled on...and if they had, they would have be disconnected. I sold them to "CantFocus" for less than 50% retail, he has no issues with them. I can't explain that one.
I used to make end links for VW/Audi and MINI applications back when I ran my business. I used Heim joints with LH/RH threads like a jackscrew and then used aluminum hex stock for the body of the link. Voila, you can dial out the pre-load in your sway bars. Testing quickly turned them from a "Hey I can make a popular product" to "I'll make these on-demand for track applications only". Here's the thing...
Heim joints are a bad idea if you want clunk-free. There's no way to make them movable without also giving them slack to rattle. You need some sort of ball joint and/or rubber bushing setup to dial out the NVH. They also are not sealed, they will pick up tiny grit particles which will wear the socket. The greaseable ones are a little better, and the Teflon-lined ones are better still, but they are extremely spendy and still wind up wearing out. And when they do wear out, they aren't serviceable. The RCs are actually fairly smartly designed there, as long as you can work around their deficiencies.
Now if Currie would hurry up and make some tiny Johnny joints, that would be ideal. I have a lot of respect for the JJ, they have solved all the problems I had with Heim joints 8 years ago.
~Richard
post #3592 of 6785 Old 04-03-2012, 12:16 PM Thread Starter
snobrdrkid07
WJ for Life
For the little amounts of wheeling that I do, I can live the stock bar, for now.
As for the JKS QD's, I could not tell you what was going on with them! But that does seem pretty odd, then to have the other person not have an issue? Maybe he already has other clunks and noises from his Jeep?
So Heim joints are a metal on metal ball and socket type joint. While the Johnny Joints are the same principal but with a rubber bushing in them to minimize if not reduce the movement/clunks. Currie has some sweet products, have been browsing around their webpage.
As for the RC QD's it seems like the stuck with the "KISS" method, which usually works out for the better. On the bottom they have a simple bushing that mirror's the stock design. While on the top, the have what looks to be a mini TRE. Seems like it would work without a problem
I have an idea that just popped in my head, could you take the stock links, and replace one the bolts with a "king-pin" so you can just pull it out for QD purposes? Or would that be too lose and cause noise?
-Michael-
post #3593 of 6785 Old 04-03-2012, 12:36 PM
billzcat1
2003 WJ
You've got it on both the RC discos and the Currie JJs.
You're thinking of "lynch pin" not kingpin. A kingpin is something totally different used in place of ball joints on heavy duty axles.
There have been more than a few ZJ guys who did the DIY disconnects using a lynch pin, they eventually all end up clunking. But then again, the sway bar mount on the ZJ axles are a single-shear tab on the bottom, it gets put under different load than WJ links do. But there's the problem of the metal sleeve in the OEM sway bar bushings - If you don't have a torqued bolt holding it in place, the metal sleeve will rattle on the lynch pin constantly.
Teraflex has disconnects as well but they never seem to get mentioned (probably because Teraflex is kind of a non-entity for the WJ community). I wonder how well they work? They seem more similar to the JKS without being adjustable.
http://www.teraflex.biz/wj-grand-cherokee-swaybar-disconnects-2-4-inch-lift.html
They claim silent function. I wonder what material they use for the end bearings/bushings.
~Richard
post #3594 of 6785 Old 04-03-2012, 12:44 PM Thread Starter
snobrdrkid07
WJ for Life
Awesome.
I have not heard of that term before. I was thinking "king-pin" because I think that is what you call the pin that holds the ball mount in the trailer receiver. I wonder if you get a tighter bushing to replace the stock bushing with the metal sleeve and just shove a lynch pin in there. Again just tossing some ideas for some cheap ideas.
You are totally right, Teraflex did not even cross my mind. Those are pretty cool too, but ~3x the cost of RC. It looks as if you can pull all 4 pins and just take them off completely and then do something to tie up the bar.
-Michael-
post #3595 of 6785 Old 04-03-2012, 12:50 PM
billzcat1
2003 WJ
Originally Posted by snobrdrkid07 View Post
Awesome.
That's a hitch pin, silly! But I see what you're getting at.
I think the RCs would work out. Just buy two 1/2-20 dies and shorten them about 3-4" for a stock height WJ. Mount them on the outside of the sway bar, not inside, replace the stupid crush sleeve with some suitable steel, or even the sleeves from the JKS kit (they will sell you the individual parts), add washers to the upper joint where it meets the sway bar. Essentially, do everything I did but make it shorter. If you do eventually go down this road let me know I can give you more in-depth pointers.
~Richard
post #3596 of 6785 Old 04-03-2012, 12:56 PM Thread Starter
snobrdrkid07
WJ for Life
For some reason I have always called it a king-pin... I don't know where I picked that up from. Same difference?
For budget reason, I would probably consider those, even thought I am NOT a fan of RC. I wouldn't be getting them until after the OME HD's get put on and I get my Bilsteins. Those are the big summer plans so far. Get OMEs/Bilsteins. I also have a brand new JKS TB but I am not sure if I need to put them on or not. Like you said, as the time comes, we can discuss in more depth on what to do with them.
-Michael-
post #3597 of 6785 Old 04-03-2012, 01:10 PM
billzcat1
2003 WJ
Better get your order in for Bilsteins now!
~Richard
post #3598 of 6785 Old 04-03-2012, 01:28 PM Thread Starter
snobrdrkid07
WJ for Life
Aren't those back-ordered like crazy right now?! Do you know what is going on with them?
Did you change your JKS bushings? Or had an issue with your stock JKS bushings? (For your TB)
-Michael-
post #3599 of 6785 Old 04-03-2012, 01:44 PM
billzcat1
2003 WJ
Just backordered. Same thing when I bought mine a year ago.
I kept the original JKS bushings. They were plenty firm, to the point I had to use a vice to get the center sleeve into the bushings. I've had no issues.
~Richard
post #3600 of 6785 Old 04-03-2012, 01:46 PM Thread Starter
snobrdrkid07
WJ for Life
Dang it, hopefully in the next month or so they will start getting all the orders filled. I won't be ordering until the summer.
Oh very nice. I have heard that people had issue with the JKS bushings being to soft.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
