Snobrdrkid's WJ Build Thread - Page 232 - JeepForum.com
post #3466 of 6785 Old 03-21-2012, 11:02 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by compcrasher86
Yupp you could definitely get faster starts by replacing the following... factory is 6ga the thicker the better. I did 2ga but 1/0 would be even better:
Starter to positive battery terminal
Engine block ground (passenger side down low between the alternator and the oil filter lengthwise) to the battery negative terminal
You really think it can be much better then that?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #3467 of 6785 Old 03-21-2012, 11:15 PM
compcrasher86
yeah... ill take a vid once i upgrade my block ground. Only reason my starts arent drastically better is cus i ran outta wire and left that one a 6ga...
Matt
compcrasher86 is offline
post #3468 of 6785 Old 03-21-2012, 11:15 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah I would like to see that! I honestly didn't think it could get all that much better. I thought what mine did was fine haha.
-Michael-
post #3469 of 6785 Old 03-21-2012, 11:18 PM
compcrasher86
Problem is... the starter can draw hundreds of amps of current, its just for a short amount of time so the factory 6ga are "safe" but imagine not having that restriction why do you think ur amp wiring is twice as thick as ur starter... continuous draw
Matt
post #3470 of 6785 Old 03-21-2012, 11:29 PM Thread Starter
snobrdrkid07
WJ for Life
True story, makes me wish I did not do all that work on the factory cables. Then at the same time I wish I took that 350 spent on the rear axle and bought a Dana 44a LSD...
-Michael-
post #3471 of 6785 Old 03-22-2012, 12:04 AM
compcrasher86
For $350 you coulda definitely got a d44a vari lol!
Matt
post #3472 of 6785 Old 03-22-2012, 12:17 AM
JerzeyBoyWJ
2003 WJ
thats how much mine was including shipping
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #3473 of 6785 Old 03-22-2012, 12:29 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah man. Im kinda mad now.
Ughhhh makes me feel worse lol.
-Michael-
post #3474 of 6785 Old 03-22-2012, 12:32 AM
JerzeyBoyWJ
2003 WJ
sorry man ..the d35 isnt worth putting money into ..i mean i havnt changed the fluid in it since 09 ..and im not even sure if the PO ever did
post #3475 of 6785 Old 03-22-2012, 12:35 AM Thread Starter
snobrdrkid07
WJ for Life
So right. I don't know why I didn't think of it before. The one side was leaking bad enough where it needed immediate attention. I needed it to drive to school with and didn't have any other option to fix it right then and there. I still wanna swap eventually.
-Michael-
post #3476 of 6785 Old 03-22-2012, 02:35 PM
Cowboyup94
So you do have the fog switch, and the fog light indicator light, and the wires. But no actual lights?
No sir. haha so I will be looking for a set at the U pull it. ROADTRIP!
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #3477 of 6785 Old 03-22-2012, 02:37 PM Thread Starter
snobrdrkid07
WJ for Life
Yeah dude do it! We added fog lights to my Jeep after we bought it actually. We had bought the whole Mopar Kit (I bet that was expensive) back in 2004.
All you need is the housings and mounting kit for your bumper?
-Michael-
post #3478 of 6785 Old 03-22-2012, 03:08 PM
Cowboyup94
i just need the housings with the bulbs of course. The mounts and what not all exist behind the covers you see on most jeeps. I think before I do the install I will paint my cladding black also I will use the extremely bright sylvanias for the fogs.. I love them in my headlights.
JEEP
post #3479 of 6785 Old 03-22-2012, 03:14 PM Thread Starter
snobrdrkid07
WJ for Life
I can't remember back to 2004. But IIRC we had to put in mounting brackets for the round 2004 fog lights. But I could be wrong. It was forever ago.
I have 9005 slyvania ultra's in my fogs.
-Michael-
post #3480 of 6785 Old 03-22-2012, 03:26 PM
JerzeyBoyWJ
2003 WJ
whens your lift going on?
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
