Snobrdrkid's WJ Build Thread - Page 231 - JeepForum.com
post #3451 of 6785 Old 03-19-2012, 08:58 AM
99WJdan
Originally Posted by snobrdrkid07
I don't even know what it is. Floored it a few times (once warmed up) to see if I could reproduce it, couldn't get it do it. So I don't even know.
Yeah Billz really had some eye opening data. Going to be picking up my Wix paper filter soon! Haha.
You sure it wasn't just the belt slipping? See if you can see "shiny" parts on the belt. The belt could have been wet for a second and slipped. If it was the trans there isn't much you could do other then a fluid/filter change without getting into a rebuild.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #3452 of 6785 Old 03-19-2012, 09:04 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
That would make sense actually. That quick jump in rpms can cause it to slip on the crank for a quick second. Because to my knowledge the only thing that puts power to the belt is the crank. So if break the belt, you loose alternator, water pump, power steering, a/c, and I think that is it. That does seem like it would make the sound and have a reason to describe it. the trans actually seems to be working well. Kicking down better. Highway speeds, dumping it down to 3rd gear has gotten really smooth ans then going back into 4th has gotten pretty smooth too.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #3453 of 6785 Old 03-19-2012, 10:09 AM
compcrasher86
Yeah as in if you belt breaks you'll know because buhbye power steering in which case pull over ASAP and shut jeep off and do not drive.
Matt
compcrasher86 is offline
post #3454 of 6785 Old 03-19-2012, 10:12 AM Thread Starter
snobrdrkid07
WJ for Life
Yeah that would not be fun. I went out to the Jeep and from what I could see. There are not any cracks in the belt, nor does it appear all that shinny... To me at least.
Yeah no power steering sounds really really crappy. I have had the Jeep rolling down the driveway to move it and no power breaks sucked a**
EDIT: Such an idiot... should have taken some pictures. Oh well
-Michael-
post #3455 of 6785 Old 03-19-2012, 11:56 AM
99WJdan
Didnt you change the trans fluid recently too? Mine shifts better after a fluid change too. I went through some water once and caused the belt to slip and i lost power steering for a minute. It was horrible. Now i have a bad bearing/pulley so it has a nice little tick. Pretty sure its the tensioner. I knew i should have replaced it when i replaced the water pump.
99WJdan is offline
post #3456 of 6785 Old 03-19-2012, 11:58 AM Thread Starter
snobrdrkid07
WJ for Life
There is only about 10.5K miles on the fluid and filter. I guess it broke it all in after all that time.
I need to give it all another look. But until it breaks there is not much I can do about it haha.
-Michael-
post #3457 of 6785 Old 03-19-2012, 12:01 PM
99WJdan
As long as theres no cracks or noticeable wear you should be good. Could just have been a random act.
99WJdan is offline
post #3458 of 6785 Old 03-19-2012, 12:03 PM Thread Starter
snobrdrkid07
WJ for Life
I did not see anything like that I do not think. Must have just be a random fluke. I guess it is just a Jeep thing. I need to get underneath of it again and check the rear seals and the diffs to make sure they are staying sealed. Also check the one bolt again that came loose.
-Michael-
post #3459 of 6785 Old 03-21-2012, 08:09 PM
Cowboyup94
Remember awhile ago I asked how to turn the fog lights on because I was pretty sure my jeep came with them but now their non existance...
well I remembered to check and I do in fact have the switch and the icon pops on the gauge cluster also I have the wiring... So something occured with the PO that the cheapest way out was to just put the bumper on without the fogs..
Going out friday to take a look around the salvage yard to see what I can find!
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #3460 of 6785 Old 03-21-2012, 08:28 PM Thread Starter
snobrdrkid07
WJ for Life
So you do have the fog switch, and the fog light indicator light, and the wires. But no actual lights?
-Michael-
post #3461 of 6785 Old 03-21-2012, 08:37 PM Thread Starter
snobrdrkid07
WJ for Life
Here Matt this is for you!
-Michael-
post #3462 of 6785 Old 03-21-2012, 09:17 PM Thread Starter
snobrdrkid07
WJ for Life
Crappy video of the HID's on the road
-Michael-
post #3463 of 6785 Old 03-21-2012, 10:38 PM
amremt408
how long does your jeep idle at 1000 rpms for?
5.9 ZJ... 4.5" Rubicon Express short arms. Bridgetone REVO 2's... 265/75/16.
2004 WJ... OME HD coils, Bilsteins shocks, JKS adj track bar, MOOG SS, ADDCO rear sway bar with ext., Bridgestone REVO 265/70/17.
amremt408 is offline
post #3464 of 6785 Old 03-21-2012, 10:42 PM Thread Starter
snobrdrkid07
WJ for Life
Actually it was down to about 650 (which is normal with the a/c on) after like a few minutes (2ish) because it was like 75 degrees outside today. When it is cold (like 20 degrees) it will stay around 1000 rpms until the engine coolant starts warming up.
-Michael-
post #3465 of 6785 Old 03-21-2012, 10:57 PM
compcrasher86
Originally Posted by snobrdrkid07 View Post
Yupp you could definitely get faster starts by replacing the following... factory is 6ga the thicker the better. I did 2ga but 1/0 would be even better:
Starter to positive battery terminal
Engine block ground (passenger side down low between the alternator and the oil filter lengthwise) to the battery negative terminal
Matt
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
