Snobrdrkid's WJ Build Thread - Page 211 - JeepForum.com
post #3151 of 6785 Old 02-22-2012, 12:57 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by compcrasher86
How do you figure that? Stock specs are 190/210? Don't think the superchips could add more than 10hp
Stock is 195 hp and 230 ft pounds at its peak.
Superchips adds 25 hp and 25-28 torque
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #3152 of 6785 Old 02-22-2012, 12:58 PM
compcrasher86
Jeeeeeezusssss I gotta get me one of them. Ever figure that's why ur mileage is suffering lol? If my WJ can hold OD on the highway with 33s I promise I'll shut my mouth about it lol. I'm thinking shift kit this summer cus it's cheap
Matt
compcrasher86 is offline
post #3153 of 6785 Old 02-22-2012, 01:03 PM Thread Starter
snobrdrkid07
Then when I add a K&N CAI and then a new exhaust that will really make the superchips come out and play. Superchips also refines the transmission. So they say. Haha
Mpg is probably my driving more or less, because its either heavy stop and floor city or really moving the brick fast on the highway. I don't ever get to cruise at 55 or 60 on flat ground haha. (Which I can get 24 mpg out of that)
-Michael-
post #3154 of 6785 Old 02-23-2012, 04:24 PM Thread Starter
snobrdrkid07
There are double cardon drive shafts at a local yard for 75 bucks. I want to get one. Cause I know I am going to blow out my rzeppa joint when I put the springs on. Probably could find a yoke there too.
Was reading the WJ F&Q's and it said that the rear shock bolts need to be torqued to 85 ft-lbs... So I need to go redo those. I am getting some clunking in the rear again. Tightening the shock bolts fixed it, but I guess I did not get them tight enough the first time.
-Michael-
post #3155 of 6785 Old 02-24-2012, 07:00 AM
compcrasher86
I put upwards of 100ft lbs on em... Don't think they were the culprit though. Are you running BPEs in the front? I found out my noise was actually coming from the front. Go figure huh
Matt
post #3156 of 6785 Old 02-24-2012, 10:46 AM Thread Starter
snobrdrkid07
Holy **** that is alot of torque. I think I am going to run them with some washers in the rear to help compress the bushings. What size are the bolts?
I am not running BPE's. Also im 90% sure I have clucks in the rear and in the front. But the rear is more noticeable and more frequent.
-Michael-
post #3157 of 6785 Old 02-24-2012, 11:00 AM
compcrasher86
Yeah I don't like loose components. Never will thou find a loose component on my front end it's the little things that prevent DW. I still feel like its looming on the horizon hence why I'm upgrading a bunch of stuff and doing all the ball joints this summer. I oughta look at getting a torque wrench eventually. I'm on a campus bus right now that's DW'ing and it sucks
I have no clue what size the rear bolts are I just remember they take a 15mm socket.
I thought my clunks were completely from the rear till I rocked the jeep from outside and then realized they were coming from the front have a buddy rock the jeep by the roof rails while you walk around looking for the noise/play.
Matt
post #3158 of 6785 Old 02-24-2012, 11:04 AM Thread Starter
snobrdrkid07
Nope they are never good when things are loose. I have my front end looked at frequently and it is all in good shape. For now at least. Haha, DW bus, sounds like a blast.
Hmmm. Ill Google around.
I think my rear may be the shocks for sure, but also the a -arm or just the shocks. Don't know yet. Hoping its just the shocks. Roof rails are not a good place to rock the jeep on. I've ripped one out before (well dad did) and we had to like silicone or expoxy the bolt back in there. They are lose enough as it is.
-Michael-
post #3159 of 6785 Old 02-24-2012, 01:21 PM
compcrasher86
Guess they had budget cuts in the later years haha mine feel like they're "bolted to the frame" lol
Matt
post #3160 of 6785 Old 02-24-2012, 02:00 PM Thread Starter
snobrdrkid07
Stupid roof rails. Your rails don't move at all when you put pressure on them?
-Michael-
post #3161 of 6785 Old 02-24-2012, 09:22 PM Thread Starter
snobrdrkid07
Yay!
-Michael-
post #3162 of 6785 Old 02-24-2012, 09:52 PM
Cowboyup94
Originally Posted by snobrdrkid07 View Post
Yay!
do you really like the mud flaps?
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline
post #3163 of 6785 Old 02-24-2012, 09:58 PM Thread Starter
snobrdrkid07
Everyone be hating on the mud flaps! Haha
-Michael-
post #3164 of 6785 Old 02-24-2012, 10:30 PM
alwaysHI
2003 WJ
thats the dirtiest i've ever seen your WJ...haha. looks like someone had a blast ah!
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #3165 of 6785 Old 02-24-2012, 10:36 PM Thread Starter
snobrdrkid07
Hahaha. It probably was. I had to go wash it off too. Lol.
Got some good scratches on it. They will probably wax/buff out.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
