Snobrdrkid's WJ Build Thread - Page 200 - JeepForum.com
post #2986 of 6785 Old 02-01-2012, 07:30 PM
compcrasher86
Originally Posted by mrJ View Post
The 75 is nice. I may sell mine and go back to it. Hey, you know about this stuff...what do you suggest for headlight bulbs that aren't hid? Hir? Let me know bc I'm ordering tonite
Michaels probably less biased on this because I really dont like anything 4600k+ but if I were to do mine I'd say get a set of silverstars but more importantly get an auxilary headlight harness because the factory one is pretty thin gauge and you lose a decent bit of output in voltage drop across the long thin lengths of wire to the headlights alone. Also any bit of haze on the factory headlights (they all do it eventually) will reduce your output.
Matt
compcrasher86 is offline
post #2987 of 6785 Old 02-01-2012, 08:05 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by compcrasher86
I wish I had an 04 cubby like yours... if you're not afraid to do some plastic trimming it looks soooo clean
also take a look at the Cobra 75 WX ST if you dont wanna mount a CB anywhere out in the open
I like my cute little cubby hole? Hahaha. Ill check that out too.
The new slyvania silver stars XZE or something like that, are brighter the the slyvania ultras. my buddy got 3 sets and like then so far.
Matt, it was a foggy night tonight... I may be changing my fogs to a lower color temp. I have 4500 or 5000 and I may want to go to 4300, I don't want yellow. Maybe 4000k.
Didn't think about how small the wires are for the headlights, they are kinda thin imho too.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2988 of 6785 Old 02-01-2012, 08:16 PM Thread Starter
snobrdrkid07
Final product
-Michael-
post #2989 of 6785 Old 02-02-2012, 12:21 AM Thread Starter
snobrdrkid07
Weekend Plans for the Jeep:
1. Take of the tire size calibration I put on with the super chips. I think that is what is throwing it off. I had adjusted it for the smaller tires on the Overland Rims. Going to put it to stock and see what happens.
2. Going to adjust the transmission cable at the throttle body and see how that goes.
-Michael-
post #2990 of 6785 Old 02-02-2012, 02:07 AM
compcrasher86
I think I finally got mine "almost" perfect, going to loosen it one click because it shifts nice and firm except when its cold its holding first too long. Definitely drives great now. PM me or txt me if you're having problems, I can probably furnish pics if necessary
Matt
post #2991 of 6785 Old 02-02-2012, 07:18 AM Thread Starter
snobrdrkid07
I am going to start but just going one click at a time and seeing what happens. I only currently have 2 complaints with the trans. The 1 to 2 lag when on it pretty hard and then when im in 3rd, and on it pretty good, then press it to the floor, it slams hard into 2nd gear. Like major clutch dump. It only does this when already going hard in 3rd gear. If I was cruising in 4th or 4th locked maintaining speed and floored it, it would kick to 2nd w/o a problem.... if you don't get what I mean. Let me know and ill explain more.
-Michael-
post #2992 of 6785 Old 02-02-2012, 10:12 AM
compcrasher86
Absolutely make completely sure that after each time you adjust it the clip goes back on and locks into place, if that comes off and your cable goes slack itll throw the tranny into full soft shift mode and you can imagine how much itd love that
Matt
post #2993 of 6785 Old 02-02-2012, 10:40 AM Thread Starter
snobrdrkid07
Alright man, I will take a look at the FSM again and follow those instructions. Oh, you mean full SH*T shift mode
I think ill have to video the 3rd to 2nd kickdown that I was describing.
Also, I was going to class last night, and turning out of campus, there is a decent hill. So I was on her good all the way too 70 mph. But once the rpms got to about high 2000's, I felt the Jeep starting to take off. Wooo power band.
-Michael-
post #2994 of 6785 Old 02-03-2012, 07:58 PM Thread Starter
snobrdrkid07
I think I posted this before. Here is a video of the RPM's at Idle and you can see that the gauges are more sensitive to the RPM Fluctuation. My other set did not do this. I think I will like it eventually haha.
Here is another video of the RPM's at Idle when I am clicking the A/C on and then off.
Those videos were both shot in Park. It will idle a little lower when in Driver =/ Which I do NOT like... I wish it would idle at 700-750 all the time.
I took my superchips programmer and set the tire size back to stock and fixed the speedo. It is now pretty much dead on!
-Michael-
post #2995 of 6785 Old 02-03-2012, 10:10 PM
compcrasher86
Well the 42res don't have variable torque converters so no matter what you're going to get an idle dip in gear as it works against the transmission. This is also why the idle is low, so it doesnt fight the tranny too hard and overheat the fluid. My buddy's WK with the 5.7 has a full variable torque converter and it's great, no idle fluctuations at all between gears. Sounds to me like somebody's been driving moms BMW too much and it's spoiling your standards :P
Matt
post #2996 of 6785 Old 02-03-2012, 10:38 PM Thread Starter
snobrdrkid07
Yeah I figured it was putting pressure on the engine when it drive compared to park/neutral. Also a sound point on why the keep the RPM's lower then. Another reason for the POS 42re.
My gosh, Everything I drive is faster then my poor WJ. The Rubicon is even faster flat out. The BMW is awesome, the Mercedes is just super comfy, and the Land Rover is a monster with a lot of power.
-Michael-
post #2997 of 6785 Old 02-04-2012, 12:32 PM
compcrasher86
I'll just leave this here:
Matt
post #2998 of 6785 Old 02-04-2012, 12:34 PM Thread Starter
snobrdrkid07
Matt, that is 4wheeler14, and I have watched all of his videos numerous times... I am jealous.
-Michael-
post #2999 of 6785 Old 02-04-2012, 12:38 PM
compcrasher86
Oh trust me I've PMd the kid and hes somewhere on JF too I'm mad jelly. I think hes got a cutout on his 4.7HO which id definitely have to throw in when i get one :P Ps... Woot 3k post in a build thread
Matt
post #3000 of 6785 Old 02-04-2012, 12:40 PM Thread Starter
snobrdrkid07
Oh trust me I've PMd the kid and hes somewhere on JF too I'm mad jelly. Ps... Woot 3k post in a build thread
Nice on the 3,000th post! (Edit, First on 201st page :P) Yeah I have seen him around here too. I had actually thought that he went to VT at one time, he is our age. I saw a red Overland in the Parking lot with a NJ plate on it. But when I went back to the videos, plates did not match.
It is raining here right now, I do not know if I will get to work on the transmission cable today...
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
