Snobrdrkid's WJ Build Thread - Page 198 - JeepForum.com
post #2956 of 6785 Old 01-27-2012, 01:08 PM
JerzeyBoyWJ
2003 WJ
you can comp are making me want one now ...the trim and needles are the same color as my jeep!
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #2957 of 6785 Old 01-27-2012, 01:11 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
I am selling the one that I just got. Link in sig? you want it? LOL. It has 75k miles on it.
I am selling it because I am going to get one with the same mileage as the one I have now. I actually just bought a second one that has 101K miles on it. LOLOL
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2958 of 6785 Old 01-27-2012, 01:13 PM
JerzeyBoyWJ
2003 WJ
i have 155xxx miles on my jeep ..about to hit 156 haha...unless i can find a shop around me to reflash the cluster
post #2959 of 6785 Old 01-27-2012, 01:16 PM Thread Starter
snobrdrkid07
I couldn't find anyone to flash it around here. So that's why im selling it. Just going to keep it simple and match the mileage and not worry about it.
-Michael-
post #2960 of 6785 Old 01-27-2012, 02:00 PM
compcrasher86
Mines only off by 700 miles in the upwards direction so I'll take my next two drives home from school with the old cluster in so it equals out
Matt
compcrasher86 is offline
post #2961 of 6785 Old 01-27-2012, 02:04 PM Thread Starter
snobrdrkid07
Yeah man you got lucky with that one. That is a pretty good deal right there. That is why I ordered the the second one with 101,000 on it haha.
-Michael-
post #2962 of 6785 Old 01-27-2012, 04:17 PM
straty1987
have to go to jeep dealer to get it done.
have you consider just swapping the white parts and bulbs?
straty1987 is offline
post #2963 of 6785 Old 01-27-2012, 04:21 PM Thread Starter
snobrdrkid07
I called the Jeep dealer and they have to hold the Jeep and send it off somewhere to get reprogrammed and then send it back and I get my Jeep back, that is not going to work in my time frame and they wanted way too much money.
The parts are not swapped able like you are suggesting because it is the Overland Cluster with the Electorlumincent lights.
My solution is to sell the one I currently have (with 75K miles on it) and buy one that has the same mileage that I currently have so there won't be an issue. Solved haha!
-Michael-
post #2964 of 6785 Old 01-27-2012, 04:38 PM
straty1987
you can open it up, look into this http://www.wjjeeps.com/gauges.htm#WHITE
post #2965 of 6785 Old 01-27-2012, 04:42 PM
straty1987
kind of what the ricers do but dose give a better look over original black.
http://www.ebay.com/itm/99-04-JEEP-G...sories&vxp=mtr
i had the Electorlumincent in my 02 limited and like it allot so now when i look at 99-01 and laredos, SE, fredoms, and ect the dash looks bad to me but i know it can be a simple mode.
post #2966 of 6785 Old 01-27-2012, 05:33 PM Thread Starter
snobrdrkid07
The problem as to why I can not pull them out and swap them over, is because the circuit board on the Overland gauges has a pigtail for the electrolumincent that the basic circuit board does not have. So yes, I can take them out, but would have to way to hook up the back light.
Seen those before, but just not the same as the stock overland set! haha
-Michael-
post #2967 of 6785 Old 01-27-2012, 07:32 PM Thread Starter
snobrdrkid07
Second Overland Cluster will be here on Wednesday.
Was reading about my Rubicon, that thing is such pure BEEF. The NSG370 MERCEDES Transmission with a 1st gear of 4.46:1 haha. Then the Transfer Case: NVG 241OR RockTrac with 4:1 Low with a built in SYE . The the Dana 44's. Makes we want to DD the Rubicon again. =/
I did not know that the 6 speed was a Mercedes based transmission though!
-Michael-
post #2968 of 6785 Old 01-30-2012, 02:43 AM
compcrasher86
My buddy has an 05 TJ sport... Here's the catch, it's got the NSG370 6 speed, and a rear dana44 limited slip... Pretty sure front is a 35. Completely stock. Fancy that, and his parents refuse to let him lift it while he lives under their roof. What a shame. That being said do you really need the crawling ratio and beefy tranny for DDing . The 6-speed is hella fun though, if only the wj was standard... If only. Might have to talk to agitated pancake about some of the stuff he did to stick swap his wj... I could be the first to do it with an i6.... Then I could toss an ax15 back there. Nahhhhhhh too much work
Matt
post #2969 of 6785 Old 01-30-2012, 11:28 AM Thread Starter
snobrdrkid07
I see what more information was added.
Front is a 35 and not a 30?? Sounds like me and WJ, with the parents refusing to let me lift it, Because Dad had such a slue of problems when the Rubi was lifted. Running Almost 3000 rpms at 70ish MPH!!! I DD'd the Rubicon for a whole year, and that first gear took off like a rocket launcher. The CRAWL on that thing is INSANE... 4.36:1 first gear 4:1 4low the 4.11:1 in the axle... So I am not 100% sure on how that gears down but, is that but those multiplied out is like 71.68:1 But that would be the reduction in the axle shaft technically, so I think I need to factor in the tire size thing. Matt, if you know how to do that, the tires are 245/75/16.
Agitated Pancake does some awesome work for sure. But, for me personally, it pains me too see a WJ that is beat to hell, haha. Again, does some awesome fab work.
I almost wish that six speed manual in the Rubi was a tiptronic Automatic with like like a sport mode where you can make it a manual while offroading but have it as an Automatic when DD'ing. Those Ratios would be killer if an auto and then a Locking Torque converter for my OD would be SWEET!
-Michael-
post #2970 of 6785 Old 01-30-2012, 11:56 AM
smunns
No Jeep has a Dana 35 front axle. It's a Dana 30, and the TJ Rubicon Dana 44 front axles are nothing more than a Dana 44 with Dana 30 outers.
smunns is offline
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
