Snobrdrkid's WJ Build Thread - Page 190 - JeepForum.com
post #2836 of 6786 Old 12-31-2011, 08:30 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Yeah I think that the STOCK WJ headlights were a lot easier to aim then these projectors ha. I do not think they are perfect but they are lower... When should I am them? with a full tank of gas or what? It seems that when it is Empty the nose will be much lower.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2837 of 6786 Old 12-31-2011, 08:44 PM
compcrasher86
I always do half tank but I think FSM recommends full tank. I forgot you got the projectors yeah they're never fun to adjust
Matt
compcrasher86 is offline
post #2838 of 6786 Old 12-31-2011, 08:58 PM Thread Starter
snobrdrkid07
FFF I will probably have to do them again. Put them down a little bit more and then do the left/right adjustment again.
-Michael-
post #2839 of 6786 Old 12-31-2011, 11:16 PM Thread Starter
snobrdrkid07
Happy New year from Snobrdrkid! Listening to the police scanner and all the stupid stuff people are doing!
-Michael-
post #2840 of 6786 Old 01-01-2012, 02:02 PM
Ljohn221
Ooo police scanner?
Dear Santa.....
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline
post #2841 of 6786 Old 01-01-2012, 02:05 PM Thread Starter
snobrdrkid07
Originally Posted by Ljohn221 View Post
Ooo police scanner?
Dear Santa.....
It is an app for my droid. They use radiorefernce.com as the live audio stream.
-Michael-
post #2842 of 6786 Old 01-01-2012, 02:30 PM
Ljohn221
Oh nice. I might put a scanner in my next car along with my new radar detector
Ljohn221 is offline
post #2843 of 6786 Old 01-01-2012, 02:31 PM Thread Starter
snobrdrkid07
Virginia is lame and you can't have radar detectors!
-Michael-
post #2844 of 6786 Old 01-01-2012, 07:01 PM Thread Starter
snobrdrkid07
So the engine is running kinda crappy while idling still. I am not sure what else it could be. Sometimes it will idle towards 750 rpms and run pretty smooth (for the I6). Then sometimes it will idle towards 600 and will run really rough and shake the Jeep and make everything rattle.
I noticed that both my PCV valves on the valve cover are leaking and loose and there is oil all around them, especially the one on the rear. Could this affect the idle?
-Michael-
post #2845 of 6786 Old 01-01-2012, 07:36 PM
compcrasher86
What you may think is loose and leaky might actually be normal... I've never felt one with a nice tight fit. I don't think that's what's messing with your idle. On my XJ in the past I found a broken engine ground strap that attached to one of the valve cover bolts and when I replaced it my idle got so much better. Basically gives the sensors a better reference for what the proper ground is...
Matt
post #2846 of 6786 Old 01-01-2012, 07:40 PM Thread Starter
snobrdrkid07
So that is interesting, what should I do about them? I mean I can move it all around...
Where would this ground wire be on the WJ? Im gonna try anything and replace anything I can to get this thing running better.
-Michael-
post #2847 of 6786 Old 01-01-2012, 07:42 PM
compcrasher86
I'll go check mine out on my wj to figure out where they are when it's light but maybe just something to check on. They should be fine in their locations just check if any of them look heavily corroded or broken.
Have you sea foamed the jeep before?
Matt
post #2848 of 6786 Old 01-01-2012, 07:44 PM Thread Starter
snobrdrkid07
Thank you! That would be really nice!
I have not sea foamed it because you have to change the oil and replace the spark plugs??
-Michael-
post #2849 of 6786 Old 01-02-2012, 02:09 PM Thread Starter
snobrdrkid07
I really want to do seafoam but I am really hesitant to do it. I was just thinking of doing it through the brake booster line??
-Michael-
post #2850 of 6786 Old 01-03-2012, 09:43 PM Thread Starter
snobrdrkid07
double post
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
