Snobrdrkid's WJ Build Thread - Page 177 - JeepForum.com
post #2641 of 6785 Old 12-12-2011, 10:13 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by straty1987
i think with a 2" spacer and the coil isolator your at max restraint with spacers.
oh when you pop off your front springs be prepared for the lower coils isolator mount point to break. it happens to allot of people when taking off the springs.
Gotcha man.
When I did the front spacers, the metal under the lower coil iso was actually in decent shape. I've seen some that have been completely rusted out.
Sent from my Droid 3 using JeepForum App
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2642 of 6785 Old 12-13-2011, 12:55 PM Thread Starter
snobrdrkid07
Okay, my dad is saying that you do not have to take the diff cover off to the change the oil. He says and thinks that there is a drain plug at the bottom of the diff in addition to the top plug where you fill it. Meaning we don't have to take off the diff cover...
Who is right here? I don't think that there is a drain plug on the 30/35.
-Michael-
post #2643 of 6785 Old 12-13-2011, 01:59 PM
Thomahawk
My front 35 does not have that, it also an advantage to open it, so you Get to clean out gear and magnets, and also inspect/have a look at the gears.
Buildthread
Thomahawk is offline
post #2644 of 6785 Old 12-13-2011, 02:08 PM Thread Starter
snobrdrkid07
There is only dana 30's in the front if all the jeeps...
I didn't think there was drain plugs.
-Michael-
post #2645 of 6785 Old 12-13-2011, 02:08 PM
compcrasher86
Tell your dad hes wrong lol. Only way to get the fluid outta a 30/35 is pulling the cover or siphoning it out with a pump through the fill hole. I would advise pulling the cover so as tomohawk said you can inspect the diff, clean it out real nice, clean the magnet, and do a fresh coat of RTV on the cover (or a lubelocker if you're feeling fancy). PS, its gunna be messy and if it hasnt been done in a while its gunna smell lol.
Matt
compcrasher86 is offline
post #2646 of 6785 Old 12-13-2011, 02:14 PM Thread Starter
snobrdrkid07
Haha yes! I didn't think that there was drain plugs. Alright, so pull it, clean it out, scrape rtv, redo rtv, bolt up, and refill.
-Michael-
post #2647 of 6785 Old 12-13-2011, 02:19 PM
compcrasher86
Yeah, I usually have a can of brake cleaner on hand and spray the gunk off the cover and the inside of the diff, then make sure it dries out real nice and its clean. The second you crack that cover loose its going to waterfall down so be ready for it. Dont skimp on scraping the RTV and get a nice bead when you put it back on, do circles around the holes, etc. Like this, but usually I'd be a little more generous with the RTV.
And usually what I do is try and get the cover on right after I do the RTV, put it on straight dont let it slide around or you'll smear the bead, and bolt it up snug and then let it sit for 30min-hr before pouring the diff fluid in just in case some seeped in to the housing you want to let it stick and dry first.
Matt
post #2648 of 6785 Old 12-13-2011, 02:22 PM Thread Starter
snobrdrkid07
Alright man thanks, that looks good. Will do! There was a thread on the brake cleaner thing in the diffs. Some say yes and some say no... I don't think it is going to hurt anything ha.
-Michael-
post #2649 of 6785 Old 12-13-2011, 02:24 PM Thread Starter
snobrdrkid07
100,000 Mile Service/Inspection
Well I am going to be coming up one the big 100,000.
What service/maintenance do you all think I should be looking to do?
In the last 10K miles this is what has been done/fixed/replaced:
  1. Transmission fluid/filter
  2. Spark Plugs
  3. Fuel Filter
  4. Throttle Body Cleaning
  5. Soon to be Diff Fluid
What I think that needs to be looked at:
  1. Front rotors, its been 50K miles
  2. front pads
  3. TRE's i think they may be orginial
  4. rear a arm ball joint i know is toast...
  5. anything else?
  6. coolant flush
  7. power steering fluid
  8. brake fluid
-Michael-
post #2650 of 6785 Old 12-13-2011, 04:31 PM
Thomahawk
You are right, my bad/mixup.
Other than that i Think Comp nailed it above, also you Will never Get all fluid and dirt out either with the siphone metode.
Buildthread
post #2651 of 6785 Old 12-13-2011, 04:43 PM Thread Starter
snobrdrkid07
No problem, the Dana 35 is in the rear with the 6's.
Yeah I will make sure that we pull the cover.
-Michael-
post #2652 of 6785 Old 12-13-2011, 05:06 PM
straty1987
yea only drain plug in WJ is for motor oil and rad.
if your going to offroad and can afford it get you diff covers before you change the oil.
  2. Spark Plugs
  3. Fuel Filter
  2. front pads
  5. anything else?
  6. coolant flush
  8. brake fluid
[*]Front rotors/front pads. if its driving go and the pad wear is even leave them. [*]TRE's. if your going to lift and get an alignment might aw well change them before you get a DW. moog greasable upgrade [*]rear a arm ball joint i know is toast. if its toast u need to fix that[*]coolant flush i wold not flush just drain out old fluid and pour in new fluid. might have build up n if you flush might case a leak. [*]power steering fluid. always a good to do . [*]brake fluid if you do the pads why not, but not a bad idea if you have the time
check the valve cover, PCV, air filter, rear pads. i think you covered most things
straty1987 is offline
post #2653 of 6785 Old 12-13-2011, 08:47 PM Thread Starter
snobrdrkid07
Alright I will be doing the following over break for sure:
1. Diff Fluid with Mobile 1 Full synthetic 75w-140 (and probably some RTV)
2. Check the breaks, (if they are okay, wait to do fluid.)
3. Check the power steering fluid.
4. Get the A-arm ball joint replaced
5. Check out the TRE's (If needed will get MOOG)
6. Coolant drain (maybe)
What do you check on the valve cover? What is the PCV Valve?
The air filter and the rear pads were done with in that 10K miles too, I had forgotten.
-Michael-
post #2654 of 6785 Old 12-13-2011, 08:52 PM
mrJ
2002 KJ Liberty
Sweet. Doin my diffs in a couple months when I get new covers
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #2655 of 6785 Old 12-13-2011, 09:03 PM
compcrasher86
You forgot about the transfer case Also the motors for the washer bottle might as well be drain plugs, they pop right out with a twist and a pull. Dont get me started on blinker fluid.
1. Diff Fluid with Mobil 1 Full synthetic 75w-140 (and probably some RTV)
1. Sweet, Mobil 1 is hella expensive I've never been let down by the higher end Valvoline line... just sayin lol.
3. In addition to checking PS fluid if mom has an old turkey baster she doesnt want anymore use it to suck out most of the fluid from the reservoir and refill to the proper line with fresh fluid. To a couple full lock to lock turns, repeat. Your fluid wont be perfect but a nice improvement and easy enough might as well.
4. Hah I love how you said "get" it replaced. If mine gives me trouble its off to the shop, no patience for that POS
5. I'd wait for the TREs unless you can perfectly measure the length/position of the old ones, otherwise you'll need an allignment before the lift. Do em right before the lift... hell do em during the lift, and get the allignment right after
6.I'm going to be doing that too, but going to probably switch over to the new Zerex G05... yours should already have G05 in it (clearish yellow colored)
Matt
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
