Snobrdrkid's WJ Build Thread - Page 171 - JeepForum.com
post #2551 of 6785 Old 12-02-2011, 10:28 PM
SnowLeopard
Bilsteins instead of Skycrapper. Just get something worth it. This is a long-term project for you, but you're not in a position to continually spend money on your Jeep. So save up to do it right as you can. Everyone wants to cheap out on shocks, but there seems no point. If you can't afford to mod your Jeep, then you can't afford to mod your Jeep. Be ready for all the extra, unanticipated complications that may result as well.
Now I'm wondering what the difference is between 5100's and 5125's. A few extra dollars? LOL
SnowLeopard is offline
post #2552 of 6785 Old 12-02-2011, 10:52 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Hopefully, I can get some Christmas money. I am not putting the lift on until break anyway. So I will see how it goes. I agree with that too. I can afford 5100's right now but that wouldn't be the smarted thing to spend the 300 bucks on right now.
I am not sure on what the difference is. I would like to find out.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2553 of 6785 Old 12-02-2011, 10:55 PM Thread Starter
snobrdrkid07
Took the Jeep for a spin tonight. The Idle seems to be normal: Engine warm, in Drive, AC on, fan on 3/4 and idles right at about 600 RPM's... does that seem low? For me that seems low. When I let of the brake now too, it really doesnt move until I hit the gas a bit... It used to have a little more 'umph' when it was just in drive with no gas no break. Maybe I am just paranoid... But the Jeep seems to have lost some of its 'umph' even for the 6 banger. Again, probably paranoid.
Taking it out tomorrow to do some shopping and running around.
-Michael-
post #2554 of 6785 Old 12-03-2011, 12:16 AM
compcrasher86
I think you're getting yourself all paranoid. The i6 is a pretty well balanced engine but it idles nowhere near as smooth and quiet as its v8 counterparts. Also there shouldn't be any OOMPH when you let off the brake, mine will just roll forward slowly up to like 5-6mph if I remember correctly. Then again if you have to give it gas to get rolling then something is wrong (torque converter slip, dragging brake caliper, etc)
Matt
compcrasher86 is offline
post #2555 of 6785 Old 12-03-2011, 12:22 AM Thread Starter
snobrdrkid07
I thought I was going crazy.
Yeah when I let off the brake it will start moving like normal. (I think I was on a hill. Not used to the higher elevation and all the hills!!)
SEE what HAPPENS when I didn't have my Jeep for all that TIME!?!?! I lost my marbles!
-Michael-
post #2556 of 6785 Old 12-03-2011, 12:30 AM
SnowLeopard
Idle varies with the 4.0, also. Mine is at around 500 rpm once it gets warmed up. It's always been that way for the 4 1/2 years I've had it. Cleaned the TB and IAC, full tune-up, new fuel-pump. No idea what's up. If it were the TPS, I'd think I'd have wilder symptoms. Ah well, it doesn't die or anything, just idles rough. It's gotten rougher over the years, too. Then I probably could use new motor mounts. Of course, if I could get an idle of 600rpm, it'd probably smooth things out considerably. 600 sounds normal for a 4.0. They're all quirky buggers though. I think they're all women who've been reincarnated as a Jeep motor to make up for not letting their men mod their Jeeps in a former life.
post #2557 of 6785 Old 12-03-2011, 12:40 AM Thread Starter
snobrdrkid07
I think if it idled at 500 and it would really rough. When mine idles at 700-750 at time, it is much better then like 600 ha. I keep expecting to feel like it is off when it is running. Which is setting that standard way too high!
Yeah mine doesn't show any signs of dying or anything like that (knock on wood)
It is just not as smooth as modern engines, as that has been stated. I will have my Jeep enthusiastic and mechanic friend at Va Tech look at my Transmission and Engine Motor mounts and see how they are.
-Michael-
post #2558 of 6785 Old 12-05-2011, 12:33 AM Thread Starter
snobrdrkid07
What my friends call me in the 4x4 club at VT
-Michael-
post #2559 of 6785 Old 12-05-2011, 09:40 AM
Thomahawk
Ok, whats the WS for?
Buildthread
Thomahawk is offline
post #2560 of 6785 Old 12-05-2011, 09:44 AM
compcrasher86
It's a J, Mr. WJ lol
Matt
post #2561 of 6785 Old 12-05-2011, 09:46 AM
Thomahawk
Oh Ok, then i see, lol!
Mr WJ it is.
Buildthread
post #2562 of 6785 Old 12-05-2011, 10:05 AM Thread Starter
snobrdrkid07
Yeah that is my new name! hahah
-Michael-
post #2563 of 6785 Old 12-05-2011, 10:07 AM
Thomahawk
Ok Mr WJ, time to change your username?
Buildthread
post #2564 of 6785 Old 12-05-2011, 10:10 AM Thread Starter
snobrdrkid07
I don't think I will, everyone knows my current username. LOL! I'll add it somewhere.
-Michael-
post #2565 of 6785 Old 12-05-2011, 10:12 AM
Thomahawk
Good choice, Snobrdrkid is quite cool.
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
