Snobrdrkid's WJ Build Thread - Page 158 - JeepForum.com
post #2356 of 6785 Old 11-20-2011, 07:12 AM
Thomahawk
Originally Posted by snobrdrkid07
Okay does it matter that it idles better when in park then drive?
No, clean it, atleast remove the air intake, turn the Throttle plate and have a look in there.
Buildthread
Thomahawk is offline
post #2357 of 6785 Old 11-20-2011, 07:39 AM
mrJ
2002 KJ Liberty
What's the best cleaning solution for the IAC?
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #2358 of 6785 Old 11-20-2011, 07:46 AM
Thomahawk
Throttle body cleaner, i used carburator cleaner.
Be sure you hold that IAC with the plunge downwards when you spray it, so the sollution doesnt Goes inside the IAC itself.
Wjjeeps have a good write up on TB cleaning.
Buildthread
post #2359 of 6785 Old 11-20-2011, 09:00 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
So far I've taken off the resonator and exposed the throttle body. removed the throttle cables as well.
Was able to get the iac wire off and the wire closest to the driver's side. Yet to get the last one off with a yellow plug.
The throttle body is def dirty. I bought throttle body and air intake cleaner and plan on spraying that all in the throttle body (after its off the jeep) the taking out the iac motor and cleaning the plunger and cleaning the iac housing.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2360 of 6785 Old 11-20-2011, 09:06 AM
Thomahawk
Before and after pics? Or it didnt happen, lol
Buildthread
post #2361 of 6785 Old 11-20-2011, 10:03 AM
compcrasher86
When I did my TB honestly I just took the whole damn thing off took all the sensors off and went at it with cleaner and an old tooth brush. Got so much carbon out plus I didn't have to hear the Jeep whine and struggle to start with all the cleaner sitting in the intake.
Matt
compcrasher86 is offline
post #2362 of 6785 Old 11-20-2011, 10:20 AM Thread Starter
snobrdrkid07
WJ for Life
That is exactly what I intend to do. When I can get that one last damn wire off. then ill be able to take the whole thing off and clean it out
-Michael-
post #2363 of 6785 Old 11-20-2011, 11:50 AM Thread Starter
snobrdrkid07
WJ for Life
Ok guys I am having a really tough time cleaning the crap of the iac. Help!
-Michael-
post #2364 of 6785 Old 11-20-2011, 12:07 PM
mrJ
2002 KJ Liberty
Soak and toothbrush son
mrJ is offline
post #2365 of 6785 Old 11-20-2011, 12:10 PM Thread Starter
snobrdrkid07
WJ for Life
I've been spraying it with the TB cleaner and trying to use a toothbrush. I just don't want to be hard on it. Im basically trying to not even use enough force to move the plunger....
-Michael-
post #2366 of 6785 Old 11-20-2011, 12:16 PM
Thomahawk
Its no problem if you move the plunger, i was also afraid of that, cleaned it and forgot, fickled with it and pulled it out.
Aaaaahhhhh, no no no.
It was no problem, just put it back, disconnect battery for a while, it Will relearn itself, no prob...
Buildthread
post #2367 of 6785 Old 11-20-2011, 12:20 PM
mrJ
2002 KJ Liberty
Maybe one of this handheld steamers. I know my buddy cleans his percolators with one and it works really well
mrJ is offline
post #2368 of 6785 Old 11-20-2011, 12:34 PM Thread Starter
snobrdrkid07
WJ for Life
I've gotten the tip pretty clean. The shaft has some good amounts of carbon left on it.
That makes me feel way better.
-Michael-
post #2369 of 6785 Old 11-20-2011, 12:35 PM Thread Starter
snobrdrkid07
WJ for Life
Now I can't get the iac back in the hole.... wtf
-Michael-
post #2370 of 6785 Old 11-20-2011, 12:36 PM
Thomahawk
No prob man, happy to help. 
Buildthread
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
