Snobrdrkid's WJ Build Thread - Page 151 - JeepForum.com
post #2251 of 6786 Old 11-05-2011, 06:47 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by robd2003 View Post
Yup, thats what me and the wife did some today after we picked up the radiator.
I am looking for a leather interior swap and a V8 cat back exhuast pipe (because it is bigger)
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #2252 of 6786 Old 11-06-2011, 07:55 AM
robd2003
what color leather, and how much you looking to spend?
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #2253 of 6786 Old 11-06-2011, 11:47 AM Thread Starter
snobrdrkid07
WJ for Life
Gray leather. I have a gray interior. Don't have much budget, college student. It is a want more then a need
-Michael-
post #2254 of 6786 Old 11-07-2011, 07:53 AM Thread Starter
snobrdrkid07
WJ for Life
Some Exhaust questions. From the headers through the two cats to the muffler is 2.5 inch diameter tubing? Then from the muffler to the end is 2.25 inch diameter pipe.
I want to go to the junkyard and get a 2.5 inch v8 exhaust.
I just forget how the exhaust is setup under there. Being away from the Jeep I forget!
-Michael-
post #2255 of 6786 Old 11-08-2011, 03:46 PM Thread Starter
snobrdrkid07
WJ for Life
Alright guys time for a thanksgiving Jeep project. I want to rock lights with LED's
I have a 16 foot 600 white LED strip from eBay and I am going to cut them into 3 separate strips. 1 on each side and one on the front. Then possibly one in the rear if there is enough left over.
I want to have a switch that is single-pole double throw. Basically, I want them to come on with the dome lights but also have the control to turn them completely off and then 'on' whenever I want. I believe that the SPDT switch will do this. http://www.amazon.com/Automotive-Round-Rocker-Switch-Center/dp/B001TQMU5C
Here is a really crude diagram. I am not sure how to wire it all to the "on-off-on" switch. I do not think that I will need a relay or anything like that because the LED's draw so little power.
Diagram below. Any help please?
-Michael-
post #2256 of 6786 Old 11-08-2011, 04:06 PM Thread Starter
snobrdrkid07
WJ for Life
Did some more research. It seems like where I have that "ground" coming of the switch... that should be a "positive" power output to the LED's if I am not mistaken now...
Then I can just ground the LED's to the body or wherever I can get a good ground connection.
-Michael-
post #2257 of 6786 Old 11-08-2011, 04:10 PM
Ljohn221
That sounds about right since I did my exhaust a couple weeks ago
EDIT*: it is 2.5 from the headers to the third cat then 2.25 from the third cat on
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline
post #2258 of 6786 Old 11-08-2011, 04:13 PM
Thomahawk
Thats about right. It could be smart to use a relay and let the dome light and other switch to Control that relay.
Sent from my Iphone4
Buildthread
Thomahawk is online now
post #2259 of 6786 Old 11-09-2011, 09:15 AM Thread Starter
snobrdrkid07
WJ for Life
Even on the v8? or is that for the 6? I though the v8 had 2.5 inch pipe all the way?
To use a relay to keep the draw off the interior light circuit? I still am not sure where I am going to hook them up at yet.
Edit: random but I haven't been getting email notifications about new replies like I was before. They are all really really delayed now.
-Michael-
post #2260 of 6786 Old 11-09-2011, 11:05 AM
Thomahawk
Yes and more convinient, wiring wise, just draw that power wire with fuse and a relay mounted a practical place, then you can wire whatever you want to Control that relay. Just my thoughts on it, you can do this in several ways.
Buildthread
post #2261 of 6786 Old 11-09-2011, 11:15 AM Thread Starter
snobrdrkid07
WJ for Life
I will see if I can draw up a better diagram later and post it up and see what you all think!
-Michael-
post #2262 of 6786 Old 11-09-2011, 01:21 PM Thread Starter
snobrdrkid07
WJ for Life
Here is what I came up with!
-Michael-
post #2263 of 6786 Old 11-09-2011, 01:52 PM
Thomahawk
Thats about as good as it can Get.
Buildthread
post #2264 of 6786 Old 11-09-2011, 02:07 PM Thread Starter
snobrdrkid07
WJ for Life
Hahaha thanks man! I did that on a program called OneNote by microsoft. It is supposed to be used to take notes in class etc.
-Michael-
post #2265 of 6786 Old 11-09-2011, 04:11 PM
JerzeyBoyWJ
2003 WJ
good choice using a relay ..while it takes more time and more wire to run them they are really helpful...also dont forget a fuse
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
