Snobrdrkid's WJ Build Thread - Page 121 - JeepForum.com
post #1801 of 6786 Old 09-07-2011, 01:47 PM
WJHype
I'm sure the trusted companies that make cold air intakes do some sort of testing to guarantee that their products improve performance. Otherwise it would stupid and people would not buy them as often.
WJHype is offline
post #1802 of 6786 Old 09-07-2011, 01:51 PM Thread Starter
snobrdrkid07
Yea people like K&N would have to be doing something like that!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1803 of 6786 Old 09-07-2011, 02:09 PM
Thomahawk
Yes problebly,
Hmmmm, but dont you Think Chrysler did the exact same thing with their intake? Or do you Think they just threw the resonator box and everything in There to reduce torque, hp, and Performence, If they could make it Even better, more simple and cheaper?
Dont you Think Chrysler actually did put Even more into this vehicle specific intake Than KN That Are almost the same for all engines?
Dont you Think Chrysler used more engineers, time, testing and so on Than a small company like KN?
No offence just asking as i Think.
Buildthread
Thomahawk is offline
post #1804 of 6786 Old 09-07-2011, 02:34 PM Thread Starter
snobrdrkid07
Probably so... K&N did dyno runs and posted the numbers where the K&N CAI performs better
-Michael-
post #1805 of 6786 Old 09-07-2011, 03:09 PM
WJHype
Originally Posted by Thomahawk View Post
Yes problebly,
I understand where you are coming from. You could ask the same question for many other aspects of the Jeep too though. There is always going to be aftermarket products that will improve a car's performance.
WJHype is offline
post #1806 of 6786 Old 09-07-2011, 03:50 PM Thread Starter
snobrdrkid07
I honestly think that is would be pretty cool to question Chrysler and K&N about this. Anyone want to call or email the two companies?
-Michael-
post #1807 of 6786 Old 09-07-2011, 06:50 PM
WJHype
I don't think they would bother to reply. If the K&N CIA dyno proves better performance then it's settled. K&N filters do bring in some dirt and dust into your throttle body though. The stock air box doesn't bring in hardly any dirt, dust, etc. that's probably why it comes that way from the factory. It's a safer choice.
WJHype is offline
post #1808 of 6786 Old 09-07-2011, 07:17 PM Thread Starter
snobrdrkid07
Dyno Pulls for the 4.0 http://www.knfilters.com/dynocharts/57-1526_dyno.pdf
Dyno for the 4.7 http://www.knfilters.com/dynocharts/57-1513_dyno.pdf
-Michael-
post #1809 of 6786 Old 09-07-2011, 09:06 PM
straty1987
i dont know if you guys found this page on wjjeeps http://www.wjjeeps.com/fipk.htm and http://www.wjjeeps.com/performance.htm#47
mopar made a CAI like K&N did
The FIPK was designed to promote performance in fuel injected stock engines by creating air filtration with the least resistance in air flow.The benefit of low resistance air filters can be felt directly in throttle response. In addition to the filter, these kits have uniquely designed adapters
alos a reason for the box in the stock air set up is to keep the sound down.
the guy who made the Brian Stroud's RamIT cold air intake did a few track runs with his 4.7. stock, with K&N, K&N no shield, ramit and showed the resets. was on JU back in 05 i believe.
Chrysler will not have any info for you unless you talk to the designer and even then since it old Chrysler they might not touch the subject.
straty1987 is offline
post #1810 of 6786 Old 09-07-2011, 11:14 PM Thread Starter
snobrdrkid07
Good info! Thanks! I have seem the WJ Jeeps info!
I didn't think anyone would really be willing to give out info ha
-Michael-
post #1811 of 6786 Old 09-08-2011, 03:22 AM
Thomahawk
^^^X2, good info. So the resonator is just for keeping the sound down, then it makes more sense.
Have you guys seen the Airaid hose from stock box to TB? That Way you can keep the stock box and still have the fresh air in from the grill and cut out the resonator box and length between the airfilter and TB.
Edit: i have noe Bern looking into the KN gen2 FIPK CAI, it seems like a pretty goodwill Way to Go. I may choose this route.
Buildthread
post #1812 of 6786 Old 09-08-2011, 08:02 AM Thread Starter
snobrdrkid07
If I do anything for my intake, its will be a KN Gen 2 FIPK CAI... (maybe with an amsoil 6x9 cone filter)
-Michael-
post #1813 of 6786 Old 09-08-2011, 12:16 PM
straty1987
lol i have the K&N for the 4.7 and the ram it just never put it in, got a greate deal used under $150 for the 2 unites and a extra filter. I want to get the amsoil 9" cone filter and pre filter just its around $100 and keep buying other jeep things. keep saying when i clean the TB will put it on and never have. one good thing i can say about K&N is that you have a lifetime warranty and they wil nto go nuts asking question. i have revived new fi,lter from them since i said the one was worn and the metal mesh had a small notch.
stock K&N and 9" amsoil
this is what the K&N looks like on the 4.7 with a pre filter
post #1814 of 6786 Old 09-08-2011, 02:17 PM Thread Starter
snobrdrkid07
Nice pictures thanks!
Many people say that K&N gums everything up... I had a throttle body cleaning done with about 50,000 miles on the K&N filter (Yea we have cleaned it and re-oiled many many times in those years) and the throttle body was not bad at all according to the mechanic who I trust. Personal friend who works at/on Jeeps.
-Michael-
post #1815 of 6786 Old 09-08-2011, 04:19 PM
straty1987
I think its form over oiling
I found his original thread on the ram it http://www.jeepsunlimited.com/forums...T+cold+air+kit
the guy Dino Savva is a HP typer of person and post good info. did the info on the wjjeeps on HP and this http://www.jeepsunlimited.com/forums...d.php?t=351500
this is what teh Brian Stroud's RamIT cold air intake look liek on the 4.7. if i get a bigger amsoil filter i cant use but i can make a bigger one from pvc pluming
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
