Snobrdrkid's WJ Build Thread - Page 120 - JeepForum.com
post #1786 of 6785 Old 09-06-2011, 11:50 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
That is pretty much what mine looks like too! It is a really big PIA!!!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1787 of 6785 Old 09-06-2011, 11:55 PM
JerzeyBoyWJ
2003 WJ
i put in my .75 spacers in the front today...and cant really tell a difference?? hah
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #1788 of 6785 Old 09-07-2011, 12:24 AM
Ljohn221
Lol fail
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline
post #1789 of 6785 Old 09-07-2011, 12:28 AM
JerzeyBoyWJ
2003 WJ
Originally Posted by Ljohn221 View Post
Lol fail
yeah hahah ...kinda shows how much the RC lift sagged...cause its supposed to be 3.5 in the back and now the front is completely level ...you can kinda tell ..you just gotta double look
post #1790 of 6785 Old 09-07-2011, 05:54 AM Thread Starter
snobrdrkid07
LOL that is kinda of fail. I noticed on mine and there was a measured difference and my front LCA went out of parallel to the ground afterwards.
-Michael-
post #1791 of 6785 Old 09-07-2011, 06:15 AM
Thomahawk
So, Whats the best springs at stock or 1-2" lift height That Are most resistant to sagging?
Buildthread
Thomahawk is online now
post #1792 of 6785 Old 09-07-2011, 06:51 AM Thread Starter
snobrdrkid07
Any Spring that is not stock (that I know of) has a higher spring rate (meaning stiffer). But honestly the main reason for WJ sagging is the rubber isolators crushing over time.
-Michael-
post #1793 of 6785 Old 09-07-2011, 06:55 AM
Thomahawk
Ok, That makes sense, i just cant decide If i am going for new springs or just isolators. Also springs with higher spring rate Will improve road manners but Will reduce comfort, dont want it to be too stiff either.
Buildthread
post #1794 of 6785 Old 09-07-2011, 06:59 AM Thread Starter
snobrdrkid07
Ok, That makes sense, i just cant decide If i am going for new springs or just isolators. Also springs with higher dpring rate Will improve road manners but Will reduce comfort, dont want it to be too stiff either.
Isolators are always a good choice. OME springs has a really nice road handling ride and a comfortable ride. They seem to be a good balance between the two. Especially with the bilstien shocks paired with them. Ask Kolak about spring rates. He knows the more technical aspect about them (or I would assume)
For my lift at one point, I was looking at 2" BDS coils. Hearing good things about them
-Michael-
post #1795 of 6785 Old 09-07-2011, 07:11 AM
Thomahawk
Thought i could Ask YOU, seems like you know EVERYTHING. Ha ha ha 
Buildthread
post #1796 of 6785 Old 09-07-2011, 07:33 AM Thread Starter
snobrdrkid07
Hahahahaha. Well I COULD look it up HOWEVER, I'm sitting in chem class. Trying to balance jeepforum and notes haha.
-Michael-
post #1797 of 6785 Old 09-07-2011, 07:42 AM
Thomahawk
I Will find out myself, no woories, close your app man, and focus on your studies.
Buildthread
post #1798 of 6785 Old 09-07-2011, 07:53 AM Thread Starter
snobrdrkid07
Tehehe. I'm out of class now and have an hour break until the next one. I do know that there are 3 types of OME for the WJ, light/medium/heavy. Ill look for the numbers to each and try to compare them to stock, and other company springs
-Michael-
post #1799 of 6785 Old 09-07-2011, 01:02 PM
Thomahawk
^^^X2 i Really want to see, What do you guys Think about plenum size of the intake theory, i know people have tried it out at BMW's before and Dyno shows That stock can be better over CAI due to larger plenum....
Ok, i Will answer My own question. Ha ha ha
Posted by MWF:
There is a link between plenum length/volume and the powercurve of an engine, longer usually means better torque and shorter better top end power. So it can be beneficial on some engines to have longer and more complex systems.
On top of that you have the issue of turbulance vs laminar flow, some filters can create massive amounts of turbulence which in turn create dead spaces and vortexes in the induction system which actually reduce flow overall.
Buildthread
post #1800 of 6785 Old 09-07-2011, 01:42 PM Thread Starter
snobrdrkid07
Posted by MWF:
Ohhh. Well I don't know if anyone on Jeepforum has done that much extensive research/testing!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
