Snobrdrkid's WJ Build Thread - Page 110 - JeepForum.com
post #1636 of 6785 Old 09-01-2011, 08:06 AM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by JulietheJeep
If you replaced the fuse the only thing I could think of is the control wire that goes to your headunit? or make sure it is grounded properly. I tried to touching my ground to some metal and that didn't cut it I had to screw it down.
The WJ in that video you found is 4.0. haha makes me a little more proud to own one
Yea if the fuse is good. Id check the ground and then the lead amp turn on wire. Where is the amp? My audio guys told me never to put amps under seats. Do you have a volt meter? If so get that out make sure you're getting around 12.5 to 14 volts coming back there
Yea it was. The 4.0 has got some low end torque baby!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1637 of 6785 Old 09-01-2011, 08:26 AM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by Ljohn221 View Post
Here you go
Also, which red wire is ground? that would be confusing as a mofo for me! Are you sure those are not backwards?
-Michael-
post #1638 of 6785 Old 09-01-2011, 08:33 AM
Ljohn221
Haha ya it's not backwards. The power is the one on the end
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline
post #1639 of 6785 Old 09-01-2011, 08:37 AM Thread Starter
snobrdrkid07
WJ for Life
Right in your picture there are two red wires coming of the power splitter and right to your amp?
-Michael-
post #1640 of 6785 Old 09-01-2011, 09:24 AM Thread Starter
snobrdrkid07
WJ for Life
Alright so here is what I got going on under the Jeep driveshaft wise. Care to explain hahaha!
IMG_20100915_235105.jpg   IMG_20100915_235125.jpg   IMG_20100915_235135.jpg   IMG_20100915_235155.jpg   IMG_20100915_235205.jpg
-Michael-
post #1641 of 6785 Old 09-01-2011, 09:26 AM Thread Starter
snobrdrkid07
WJ for Life
And again this is what I am looking to buy.
-Michael-
post #1642 of 6785 Old 09-01-2011, 09:33 AM
JerzeyBoyWJ
2003 WJ
pretty much all you need to buy is the yoke for the transfer case ...i bought the one for the axle cause i wanted a stronger tie down for the u-joint
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #1643 of 6785 Old 09-01-2011, 09:38 AM Thread Starter
snobrdrkid07
WJ for Life
The guy on flea bay didnt mention anything about this fitting with a WJ however he did say that it was 31 inches long and extends about 4 inches.
Edit: Jerzey, thank you for all your help! I really appreciate it! I am going to email the seller and see if he will knock the price down some. Do you all think that it is worth the money to upgrade to a double cardon from a rezeppa?
-Michael-
post #1644 of 6785 Old 09-01-2011, 11:51 AM
JerzeyBoyWJ
2003 WJ
deff worth the money..im pretty sure thats the same driveshaft i have in my garage ..its a little bit shorter from my carolina one ..but it will still work (one of the reasons why i still have it)...esp. with you maybe in the future getting a 3 inch lift
post #1645 of 6785 Old 09-01-2011, 12:42 PM Thread Starter
snobrdrkid07
WJ for Life
For 65 shipped that isn't bad?? What are you doing with your extra front driveshaft?
everyone says that the rzeppa blows up even with a little bit of lift... that is right isn't it?
-Michael-
post #1646 of 6785 Old 09-01-2011, 04:39 PM Thread Starter
snobrdrkid07
WJ for Life
This WJ be on 42's
-Michael-
post #1647 of 6785 Old 09-01-2011, 05:37 PM
Thomahawk
I dont know anything about this driveshaft upgrade, been reading alot around it but dont see the benefits If your stock aint broken (yet).
I may need to study this myself cause i Get some minor vibration when i hit 75-80mph, i have new front axles cv's and everything Else seems to be ok, so then its broken down to front drive shaft or yokes....
Offcourse If you need some new parts, upgrades or stronger parts Are allways welcome and preferd over stock.
Whats the main differences between rezzeppa and double cardon?
Buildthread
Thomahawk is offline
post #1648 of 6785 Old 09-01-2011, 05:46 PM Thread Starter
snobrdrkid07
WJ for Life
The driveshaft that is for sale has upgraded joints meaning it has the double cardon. the Rezzeppa joints just fail more and have almost no tolerance for a lift
This will show you a rzeppa joint and a double cardon rendering.
Universal joint, i.e. u-joint
The double cardon has more tolerances and is generally stronger.
-Michael-
post #1649 of 6785 Old 09-01-2011, 05:47 PM
alwaysHI
2003 WJ
Thomahawk,
rezeppa utilized CV joints on both ends of the driveshaft, as double cardan is u-joints. U-joints allow the driveshaft to be at a more severe angle, yet still easily do the job...to put it simply.
Snobrdkid, the drive shaft you have now is the same as mine and many others. It'll handle up to a 3.5" lift at the most.
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #1650 of 6785 Old 09-01-2011, 05:52 PM Thread Starter
snobrdrkid07
WJ for Life
Originally Posted by alwaysHI View Post
Thomahawk,
You think that I should get that drive shaft and get a the yoke for the t-case? 60 for shaft shipped and the yoke was like 60 bucks. All together a 120 dollar ish upgrade.
I think my rzeppa joint at the t-case is making some noise cause when i have it in 4x4 i am hearing some whine or something.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
