Snobrdrkid's WJ Build Thread - Page 109 - JeepForum.com
post #1621 of 6785 Old 08-30-2011, 04:17 PM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Thomahawk View Post
Its like 1-2-2-3-4-5
The first 2 gear is for up shift the second for down shift.
I have read someplace here at JF That the 545RFE actualy can have up to 8 gears physicly, 2 backwards and 6 forwards but Chrysler never Made Any program for That as far as i know.
I would be like R1-R2-1-2-3-4-5-6
Ahhh that was what I was wondering... if they could make it go 1-2-3-4-5-6.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1622 of 6785 Old 08-30-2011, 04:20 PM
Thomahawk
I believe they could and its possible with the physics and gears That allready Are in the Trans, but they didnt make the program for the TCM to work That What, but Yes!
Buildthread
Thomahawk is offline
post #1623 of 6785 Old 08-30-2011, 04:30 PM Thread Starter
snobrdrkid07
They totally should have done that!
-Michael-
post #1624 of 6785 Old 08-31-2011, 10:36 AM
Thomahawk
Hey man! Have you Seen or heard of the new huricane Katia That coming towards US east coast?
Buildthread
post #1625 of 6785 Old 08-31-2011, 10:42 AM Thread Starter
snobrdrkid07
Good morning, nope, I haven't. I'm currently sitting in calculus class.
-Michael-
post #1626 of 6785 Old 08-31-2011, 11:11 AM
JulietheJeep
I hear it's just going straight up to canada and by then it'll just be a little storm.
Steel Blue WJ named Julie.- R.I.P. Julie the Jeep
Another Steel Blue WJ named Jenn.
3" IRO Lift, Bilstein 5100s, 32s, Roof basket
JulietheJeep is offline
post #1627 of 6785 Old 08-31-2011, 11:34 AM Thread Starter
snobrdrkid07
It is really really far out too! who knows where it is going to go!
-Michael-
post #1628 of 6785 Old 08-31-2011, 09:08 PM Thread Starter
snobrdrkid07
Found a cool
skip to 1:15 cause before that nothing happens, and then when you get to the end, notice them model, the mirrors, and the paint.
-Michael-
post #1629 of 6785 Old 08-31-2011, 11:01 PM
Ljohn221
Having a problem with my amp and figured you could help. So I redid some wiring with the new wire I got then when I plugged it all back in, my small amp didn't work so I saw the fuse was blown so I replaced it and still nothing. The amp just won't turn on but the other amp which is connected to the same power source and signal wire works fine. Even tried switching wires between the amps and still nothing. Did I like fry the amp or something? Thanks for any input you can provide
Check out my 1999 WJ build>
http://www.jeepforum.com/forum/f22/ljohns-1999-wj-build-forum-1188750/#post11260881
Ljohn221 is offline
post #1630 of 6785 Old 08-31-2011, 11:38 PM Thread Starter
snobrdrkid07
Some amps have multiple fuses? Actually almost all amps have multiple fuses. I'd start there. Is there any pictures that you can post here? Pictures always help.
I am pretty sure that my sub amp has 4x25 amp fuses.
-Michael-
post #1631 of 6785 Old 08-31-2011, 11:42 PM Thread Starter
snobrdrkid07
I have a quick and kinda simple question. I have been looking at THIS on eBay and I want to know if this will work on my WJ and what else I would need to make it work. My current front drive shaft has a single cardon joint at the axle and a rezeppa or CV style at the trasfer case. I am assuming I need a new yoke at the t-case end? How hard is that to install and how much money?
Actually is it even worth upgrading to a double cardon? Is this a fair price for that shaft? 45+25 shipping.
Thanks for your input!
-Michael-
post #1632 of 6785 Old 08-31-2011, 11:46 PM
Ljohn221
Mine only has one 25 it's a 320w
Ljohn221 is offline
post #1633 of 6785 Old 08-31-2011, 11:47 PM Thread Starter
snobrdrkid07
Make and Model on the amp?
EDIT: My sub amp only has 2x30amp fuses.
-Michael-
post #1634 of 6785 Old 09-01-2011, 12:33 AM
Ljohn221
Here you go
Ljohn221 is offline
post #1635 of 6785 Old 09-01-2011, 08:18 AM
JulietheJeep
If you replaced the fuse the only thing I could think of is the control wire that goes to your headunit? or make sure it is grounded properly. I tried to touching my ground to some metal and that didn't cut it I had to screw it down.
The WJ in that video you found is 4.0. haha makes me a little more proud to own one
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
